Topic: foo_uie_playlists_dropdown (Read 494633 times) previous topic - next topic
Reply #200
Just a Heads-Up on this latest version.  I installed it a couple of minutes ago, and lost all my buttons on the configuration provided by Lucky Luciano, Black Glass.
Had me worried for a bit, but I just deleted the new version of pulldown and reinstalled the next to last version, and my buttons were back!
Close call for me.....
Reply #201
Dear friends. Please, if someone know how to ... explain me how to write te right script for "Playlist duration" in drop down menu, which will show duration in days, hours, minutes.
for example
01.  All Music Library    766 songs,  2 days,  2 GB
02.  Switchfoot              26 songs,  5 hours,  400 MB
03.  Rock                      6 songs,  55 minutes,  80 MB
I allready know how to do everything else, but not the length of playlist. Is it possible at all?
Jan
Reply #202
'%length%'
elevatorladylevitateme
Reply #203
'%length%'
I know, that I'll need to use the %length% syntax, but I don't know how to format playlist length into only days, only hours and only minutes, as is shown in my example.
J
Reply #204
the development of this component has stopped? the latest one is a year ago...
Reply #206
That's a pitty. I'm working on a Foobar skin and it is a pitty, that it seems to be impossible, to display the playlist length like iTunes do.
http://hron.fei.tuke.sk/~perhac/files/foo.png
J
It's far from impossible, just no one has told you exactly how to do it yet.
(hint: Read this page)
If you can't be bothered to learn some TAGZ, then you'll probably be more happy going back to iTunes.
Reply #207
I do not want to return to iTunes anymore.
The %length% format is [HH:]MM:SS.
The problem is, that if I do this
$ifgreater($div(%length%), 3, $div(%length%) minutes, $div(%length%) hours)
(why "3"? ), I get the length of playlist in only hours or in only minutes.
But the problem is, that I do not how to get length in only days, only hours a and only minutes.
J
Reply #208
I've got it.
$if($strstr(%length%,d),$div(%length%) days,$ifgreater($sub(%length%), 10:00, $div(%length%) minutes, $div(%length%) hours))
Reply #209
 good. wasn't that better than me giving it to you?
[edit]you must not have playlists with Weeks yet.
Reply #210
This plugin causes errors for me.  Whenever I try to play a song, I get a R6025 error: pure virtual function call.
Here's a list of my other plugins, if it helps
Core (2007-04-20 15:36:34)
    foobar2000 core 0.9.4.3
foo_albumlist.dll (2007-04-20 15:34:58)
    Album List 3.2.0
foo_audioscrobbler.dll (2007-05-13 14:23:40)
    Audioscrobbler 1.3.6
foo_browser.dll (2007-03-23 16:53:12)
    Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]
foo_cdda.dll (2007-04-20 15:34:44)
    CD Audio Decoder 2.1.1
foo_common.dll (2006-03-11 19:23:55)
    Common services 0.1
foo_comserver2.dll (2006-07-31 20:13:20)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2007-04-20 15:34:28)
    Converter 1.0.1
foo_cwb_hooks.dll (2007-06-12 15:14:24)
    cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]
    Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]
foo_dbsearch.dll (2007-01-25 21:58:48)
    Database Search 1.4
foo_discogs.dll (2007-04-28 22:22:18)
    Discogs Tagger 1.0
foo_dsp_std.dll (2007-01-19 19:36:56)
    Standard DSP array 1.0
foo_freedb2.dll (2007-01-22 13:07:44)
    freedb Tagger 0.5.2a
foo_infobox.dll (2006-10-09 09:17:12)
    Special file info box 2.0.4
foo_input_shorten.dll (2007-01-22 13:05:40)
    Shorten decoder 0.4.2a
foo_input_std.dll (2007-04-20 15:34:22)
    FLAC Decoder 1.1.0
    Standard Input Array 1.0
    WMA Decoder 1.1
foo_lnk.dll (2006-03-11 19:24:54)
    Shell link resolver 1.1
foo_lyricsdb.dll (2006-07-19 23:45:52)
    foo_lyricsdb 0.0.7 beta 4
foo_masstag.dll (2007-04-20 15:33:44)
    Masstagger 1.6
foo_navigator.dll (2006-11-04 15:56:28)
    Navigator 0.6
foo_playcount.dll (2006-09-16 17:55:54)
    Playback Statistics 1.3.2
foo_playlist_manager.dll (2007-01-22 13:05:12)
    Playlist Manager 1.0.2
foo_playlist_tree.dll (2007-04-03 11:40:00)
    Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]
foo_pqview.dll (2006-03-13 00:23:29)
foo_random.dll (2006-03-13 11:35:03)
    Randomized playlist entry 1.2.3
foo_rgscan.dll (2007-04-20 15:33:22)
    ReplayGain Scanner 2.0.2
foo_run.dll (2006-06-15 22:08:10)
    Run services 0.3.2
foo_tradersfriend.dll (2007-01-25 22:34:04)
    Live Show Tagger 0.6.1
foo_ui_columns.dll (2006-11-22 08:05:24)
    Columns UI 0.1.3 beta 1v7
foo_ui_panels.dll (2007-06-12 12:28:20)
    Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]
foo_ui_std.dll (2007-04-20 15:33:14)
    Default User Interface 0.9acc
foo_uie_albumlist.dll (2007-06-08 09:58:42)
    Album list panel 0.2.2
foo_uie_lyrics.dll (2007-03-12 09:32:45)
    Lyric Show Panels 0.3.1.1
foo_uie_peakmeter.dll (2007-07-05 11:41:34)
    Peakmeter Panel 0.0.3.1
foo_uie_queuemanager.dll (2006-12-17 03:21:36)
    Queue manager panel 0.2.3
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_vis_egoh.dll (2007-03-12 22:30:28)
    Egoh Spectrum analyser (uie) 1.1.2
foo_utils.dll (2007-01-22 13:05:00)
    Playlist Tools 0.5.9
Reply #211
Fitret, what OS are you running? Also, are you using Panels UI, or Columns UI?
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Reply #213
I'm using Panels UI and Windows Vista 32-bit.
That might be the problem right there then. This component doesn't work in vista unfortunately . Try this version of the component, and see if it works for you: http://xx0r.be/uploads/foo_uie_playlists_dropdown.rar
It may be the one you already have however. Also, it might be a conflict with Panels UI and this component. Does it work fine in Columns UI?
Reply #214
That version appears to work!!  Thank you.
Edit: I spoke too soon.  It crashes on exit.  I'm kind of tired now so I'm headed to bed, but tomorrow I'll try it out with Columns UI.
Reply #215
This component might have not been recompiled after some needed Vista workarounds were introduced to the SDK. The author seems to be MIA, so..
Reply #217
Is that supposed to mean anything?
Reply #218
Anyway to change the border color of the drop down menu?
for example
The white around the grey border is kind of annoying, I know the white comes from the windows theme but is there any way to change that?
Reply #219
Afraid not, but it has been frequently asked for.
Unfortunately, it seems work on this component has stopped.
Reply #220
First Panels UI stops being worked on, now this
Reply #221
Hi. I've made some improvements to this component, you can grab it here:
Playlists Dropdown
Just remember to download version 0.6 alpha 4. Beware that this is alpha, so it would be advisable to make backup of your playlists and config before using it. The component requires at least 0.9.4 core and Columns UI 0.2.0 beta 1. Please report any problems with this version. Here's small changelog:
    Playlists Dropdown v0.6 alpha 4[/li][li]Handy playlists reordering by dragging them with middle-mouse-button pressed (while listbox is open)[/li][li]Reorganized context menu: separate menu for playlist items (RMB click inside ComboBox) and separate for default Columns UI actions ("Show caption / Lock panel ... / Preferences") - RMB click on "drop down" button or border of ComboBox[/li][li]2 new Context Menu actions: Move Up / Move Down[/li][li]Fixed bug in %_text%, %_selected_text%, %_back% and %_selected_back% fields - now they can be used inside $set_style() functions[/li][li]Custom sorting working again[/li][/list]
      Playlists Dropdown v0.6 alpha 3[/li][li]Recompiled with newer SDK (Vista compatibility)[/li][li]Added %incontrol% field, so now it is possible to e.g. show total number of playlists only in the control, not the list[/li][/list]
      @spaceships: unfortunately, this is how Windows renders ComboBox control and there is no easy way to change this.
      Reply #222
      nice!
      Reply #223
      Thanks a lot for the Vista compatibility!  I was digging this thread up after upgrading unhappily to find it not working.
      Reply #224
      Well, my foobar crashes sometimes when track automatically changes or when i close foobar while a song is playing. I created a topic about this in support forum and someone said playlistdropdown is causing this and adviced me to post this here, so i'm posting it here.
      Link to original thread in support forum
      Moderation: Replaced crash log with link to the original topic.
