foo_audioscrobbler 1.4.7
Reply #768 – 2010-02-01 12:18:17
Hi, i would like to use a remapping feature of audioscrobbler, but it doesn't look to work properly for me. I listen to radio and the words in track titles there are separated with underscores, so I've tried to use something like [$replace(%title%,'_', )] but audioscrobbler still sends the title with underscores. I have even tried to put some constant string in mapping field, like "aa" but audioscrobbler still sends the original title to last.fm. Maybe someone have ideas how such remapping could be done? I have almost the same problem. The only difference is, I'm getting a bunch of excessive underscores as a bonus. Doesn't actualy make that much of a difference. Should be solved with $trim. Only if the remapping functions worked... With the replaced and excessive characters last.fm doesn't recognise the tracks properly, which makes this plugin (and even foobar) kinda useless to me. I basicly got it to scrobble internet radios. I would realy appreciate some ideas. Not that I can't live without this, but would be nice if it worked . The field remappings seem not to work for me either. I also listen to a radio stream and want to correct the information that is sent with the %title% field. I tried $left(%title%,$sub($strstr(%title%, | ),1)) to cut the title before the first appearance of the pipe character. Further, I tried to set a constant value for test purposes like hydroban did. Didn't do the job as well. I must add, that I use foobar with crossover under Ubuntu, but I think that is not the reason.
