Topic: foo_audioscrobbler 1.4.7 (Read 928290 times) previous topic - next topic
Reply #576
I am still getting the 'Previous submission still in progress' error. Here's my console output:
Watching: E:\More of My Documents\Music
Startup time : 0:03.576812
Audioscrobbler: Handshake successful.
Opening track for playback: "http://netcast6.kfjc.org/"
Audioscrobbler: Skipping track due to missing artist or title info.
DNS error (11001)
DNS error (11001)
Playing
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\01 Heavy Friends.mp3"
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\02 Korosu.mp3"
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\03 Dyna-Soar.mp3"
Audioscrobbler: Submitting track...
Audioscrobbler: Submission succeeded.
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\04 Wareruride.mp3"
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\05 Soft Edge.mp3"
Opening track for playback: "E:\More of My Documents\Music\Boris\Heavy Rocks\06 Rattlesnake.mp3"
DNS error (11001)
DNS error (11001)
Location not parsable: "E:\More of My Documents\Music\RARs\Gaseneta.rar", reason: Unsupported file format
Location not parsable: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\Gaseneta - Sooner Or Later.txt", reason: Unsupported file format
Location not parsable: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\cover.jpg", reason: Unsupported file format
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\01. Live.mp3"
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\02. Untitled.mp3"
Reopening played file after update: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\02. Untitled.mp3"
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\03. Untitled.mp3"
Audioscrobbler: Previous submission still in progress
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\04. Untitled.mp3"
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\05. Untitled.mp3"
Reopening played file after update: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\05. Untitled.mp3"
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\06. Untitled.mp3"
Reopening played file after update: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\06. Untitled.mp3"
Properties dialog refresh: 0:00.000089
Properties dialog display refresh: 0:00.030459
Opening track for playback: "E:\More of My Documents\Music\Gaseneta\Sooner Or Later (Japan 1978)\07. Live.mp3"
edit: Also, if I disable 'submit tracks from dynamic sources' will that exclude foo_lastfm_radio as well?
Reply #577
I doubt that this is a problem of foo_audioscrobbler. The DNS errors before submitting are more pointing in the direction of a not very reliable internet connection.
No, foo_lastfm_radio are treated as local files.
Reply #578
I think the DNS errors are related to kfjc.org, at least they only seem to happen when I listen to that. I'm on a university connection so it should be OK. 1.3.16 works fine for me, but I still get those DNS errors with KFJC so presumably it's not from foo_audioscrobbler? I don't think the problem can be caused by internet radio anyway, I turned off scrobbling of radio stations because KFJC doesn't provide track info.
Also: would you be able to add the option to change when each track is scrobbled please? I seem to remember the official client gives the option of between 50-100% of a song, it would be nice to be able to extend it.
Reply #580
Hi!!
I'm still having problems with this component, in the console this is the behaviour:
Opening track for playback: "M:\Musica\Ordenados\[The Killers]\Sam's Town\05 [The Killers] For Reasons Unknown.mp3"
Audioscrobbler: Submitting 4 cached tracks...
Audioscrobbler: Connection error
Opening track for playback: "M:\Musica\Ordenados\[The Killers]\Sam's Town\06 [The Killers] Read My Mind.mp3"
Audioscrobbler: Submitting 5 cached tracks...
Opening track for playback: "M:\Musica\Ordenados\[The Killers]\Sam's Town\08 [The Killers] Bones.mp3"
Audioscrobbler: Submitting 6 cached tracks...
Opening track for playback: "M:\Musica\Ordenados\[The Killers]\Sam's Town\09 [The Killers] My List.mp3"
Audioscrobbler: Submitting 7 cached tracks...
Opening track for playback: "M:\Musica\Ordenados\[The Killers]\Sam's Town\10 [The Killers] This River Is Wild.mp3"
The below link contains the packets captured in the the above process, I had used wireshark to capture them :
http://www.mediafire.com/?wjmji1jyzjm
Ready Steady Go
Reply #581
I'm still getting
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Source
with 1.4.1. There is one item in the cache and i can't get rid of it.
Reply #582
I'm still getting
You should be able to reset the cache via 'Preferences > Tools > Audioscrobbler > Reset Page'.
Reply #583
I'm getting the same error as fooilicious
and I have 124 tracks in cache from foo_dop.
Is there a way to scrobble them (eg. reverting to an old version)? Because I would not like to reset the cache and lose these scrobblings.
Reply #584
Hi, I'm getting the same error as TomBarlow, with "dynamic sources" checked:
Watching: C:\Users\ROMAIN\Music
Album list panel: tree generated in : 0:00.000268
Startup time : 0:00.276032
Opening track for playback: "http://scfire-dtc-aa01.stream.aol.com/stream/1048"
This was done on a fresh install of foobar2000, right after I added foo_audioscrobbler.
Reading the log, you can see what I did:
- Listened to a few songs on a web radio (radio paradise)
- Stopped playback
- Listened to a few more songs on the same radio
The error occurred the second time I started listening to the radio.
I tried to empty the cache with the "Reset page" button but it didn't help, I was still getting the error.
After restarting foobar2000, it worked again.
That's too bad, because I was delighted with this new feature
Reply #585
I never tried a downgrade (only upgrading versions) but I think it should also work. You delete the component, start foobar, the program is going to say that the component was deleted, you say that you want to keep the settings, then close foobar, put the version you want, start foobar again and your scrobbles (hopefully) will still be there in cache.
I also have sometimes problems with the plugin but I think the problem is in last.fm, because sooner or later all the scrobbles are sended.
Reply #587
my first post here...
I'm having the 'Previous submission still in progress' message in the console. All the files I play are stored locally (i.e., not from dynamic sources).
But what's odd is if I close FB2K, reopen, go to the Audioscrobbler config section and click "Submit":
Audioscrobbler: Submitting 8 cached tracks...
I don't think this is caused by DNS problems. In my opinion, probably caused by some hanging function inside the plugin... I don't know if it internally has a timeout and resubmits (reconnects) to last.fm but it may be a solution.
Reply #588
"Audioscrobbler: Previous submission still in progress"
It just stopped working, again.
I had no problems at all when you released new version but it started to do this again, without warning.
No iPod-imported plays + newest Foobar in use and newest audioscrobbler.
edit: started to work when removing from components folder and deleting settings and placing it back in there.
Reply #589
It happens for me occasionally (for example yesterday). Restarting foobar helps but I loose all tracks after the one that hangs submission process (newer tracks aren't cached at all)
Reply #590
Would it be possible to allow the end user to toggle what percentage of the song must be listened to before it is submitted? I believe the official last.fm program can do this, and I would like to be able to set it to requiring 100% of the track to be played, rather than the 50% I think it is now, before it is submitted.
Reply #591
Has anyone had issues with double-scrobbling when scrobbling streamed songs? I don't know if it's a problem with the component or something else.
Basically, the issue is this: I use one copy of foobar2000 (installed with the "portable" option) to run an online radio stream. I then use my "normal" install of foobar to listen to the stream when I want to scrobble what it's playing. (The stream is for an IRC channel I run and streams 24/7, so I don't want to scrobble all the time; that wouldn't be accurate or statistically fair, but sometimes I do like to listen in and run "requests" for the guys.)
I've noticed lately that songs show up on my Last.fm profile twice, about one minute apart. I don't recall this happening until a couple days ago, so I'm a bit confused as to what would be causing this. foo_audioscrobbler is installed with the "portable, stream copy", but NOT installed with the "normal, listening" copy.
Does anyone have any suggestions on where I can start looking to peg this down?
EDIT: It just happened again as I was writing this. I wonder if the plugin is somehow detecting the song multiple times.
EDIT 2: Upon closer inspection of the console output, foobar is indeed detecting the tracks multiple times, which foo_audioscrobbler is then submitting to last.fm. Would the console be displaying output from both instances of foobar?
Reply #592
foobar2000 0.9.6.6 portable + foo_audioscrobbler 1.4.1
this happens to me after I've stop (or pause, don't remember) foobar and listen 3 tracks on last.fm in web browser
Opening track for playback: "M:\Muzyka\Metal\Iperyt\2005 - Particular Hatred\01 - The Black Emperor.mp3"
Opening track for playback: "M:\Muzyka\Metal\Misery Index\2006 - Discordia\01 - Unmarked Graves.mp3"
Opening track for playback: "M:\Muzyka\Metal\Misery Index\2008 - Traitors\01 - We Never Come In Peace.mp3"
Reopening played file after update: "M:\Muzyka\Metal\Misery Index\2008 - Traitors\01 - We Never Come In Peace.mp3"
Opening track for playback: "M:\Muzyka\Metal\Misery Index\2008 - Traitors\02 - Theocracy.mp3"
Opening track for playback: "M:\Muzyka\Metal\Misery Index\2008 - Traitors\03 - Partisans Of Grief.mp3"
Opening track for playback: "M:\Muzyka\Metal\Misery Index\2008 - Traitors\04 - Traitors.mp3"
restart foobar solve problem and submit all played songs
Reply #593
I just installed this, and can't find an answer anywhere.... how does the plugin KNOW what my last.fm account is?  How's it know where to send the data???
Reply #594
Go to Preferences -> Tools. There, under Audioscrobbler, input your usename and password.
Reply #595
It'd be really great to have a main menu item that toggled scrobbling and also a track menu item such as "play without scrobbling"  great component!
Reply #596
"Love Track" function is what i miss. Would be awesome² if you could love a track just by pressing a button in fb2k. like rating it or setting a mood, only that it communicates with your last.fm profile.
Loved tracks could appear as such in the playlist. Also a "loved tracks" playlist could be generated.
Although it's a great component already, gj.
edit: oh well, of course this was suggested before -.-' consider it as a +1
Reply #597
I double scrobbling on/off button, and menu item, maybe if file has tag field 'no scrobbling' set to '1' then scrobbling could be skipped, same as with foo_skip and SKIP=1 tag
Reply #598
I don't know if you've heared the lastest news: http://www.techcrunch.com/2009/05/22/deny-this-lastfm/
It made me come up with a feature request :-D What about including an option to prevent submission of track play stats when the release date is in the future? So when a track has a release date set in the future, it should not be send to last.fm after it has been played. After all, you couldn't have played it in the first place since it doesn't exist yet, therefore you are submitting invallid play stats if you allow submitting these tracks ;-)
Reply #599
I think that s not a real problem as you can have listen to the track from myspace for example. You can also download the tracks from there and so scrobble them. Nothing illegal i think?
