Topic: foo_audioscrobbler 1.4.7 (Read 931437 times) previous topic - next topic
Reply #375
Basically saying, I want you to do $meta_sep(artist,&) or let users choose what string to send.
as I said above, I prefer a easy solution with as few possible problems caused by misuse of any options (just imagine users complaining about their tracks not being scrobbled because their over-complex title formatting for the artist field resulted in an empty artist).
Reply #376
Okay, thanks.
stimulating the audio nerve directly
Reply #377
I would love the option to mark a track as 'loved' on LastFM directly from Foobar. I guess an option in the right click menu would be enough.
Reply #378
I am having a problem scrobbling tracks with multiple artists in the ARTIST ID3 tag.
Tracks are btw autotagged from freedb.
For example, if the track is tagged:
David Byrne \ Thievery Corporation
in the artist field (which is, i'm pretty sure, in complete compliance with the ID3 standard),
the data scrobbled to last.fm is in the following format:
David Byrne , Thievery Corporation
which is actually the way foobar interprets it, but in last.fm that is an unkown artist.
I did not have this problem in the older versions of foo_audioscrobbler.
last.fm/user/antropocentrio
Reply #379
Artist Name : David Byrne
Track Title : Dance On Vaseline
Album Title : Abductions And Reconstructions
Date : 1999
Genre : Trip Hop
Composer :
Performer :
Album Artist : Thievery Corporation
Track Number : 1
Total Tracks :
Disc Number :
Total Discs :
Comment :
Reply #380
That would be a lovely feature.
Reply #381
Date : 1999
Genre : Trip Hop
Composer :
Performer :
Track Number : 1
Total Tracks :
Disc Number :
Total Discs :
Comment :
That certainly is an option, but i would hate to edit all the tags of my correctly tagged files.
Reply #382
Date : 1999
Genre : Trip Hop
Composer :
Performer :
Track Number : 1
Total Tracks :
Disc Number :
Total Discs :
Comment :
Why do you assume that your way is the "correct" one?
I use the same way of tagging as TREX6662k6 and to me it makes perfect sense, and with your way i find it annoying.
It's probably good for mp3 players and such, but i rather have each thing in it's own field.
Reply #383
Date : 1999
Genre : Trip Hop
Composer :
Performer :
Track Number : 1
Total Tracks :
Disc Number :
Total Discs :
Comment :
I am not assuming anything.
http://www.id3.org/id3v2-00
TP1
  The 'Lead artist(s)/Lead performer(s)/Soloist(s)/Performing group' is
  used for the main artist(s). They are seperated with the "/"
  character.
Besides, files were always tagged this way and there were no problems with scrobbling before.
Reply #384
I just tried to submit the songs manually since audioscrobbler wasn't submitting them itself and the submitting server is supposedly up and running. This is what the Console showed.
Audioscrobbler: Submitting 10 of 92 cached tracks...
Audioscrobbler: Invalid data, full line expected
Reply #385
This console message is caused by an unexpected response from the server. It should be something that occurs only from time to time and not on a regular basis.
Reply #386
Please don't make this plug-in bloated. This is just a track info submitter.
Reply #387
Thanks for creating this plugin.
It was a pleasure to remove the last.fm software from my computer and use this instead!
I am going to have to second this sentiment. All this needs to do is upload tracks played.
Reply #388
I don't want that much bloat either. I just want to set my songs as loved. Because if I use foo_audioscrobbler I can't do it anymore with the stupid LastFM software.
Reply #389
I've split some posts on a proxy issue to a [a href='index.php?showtopic=61151']separate topic[/a].
Reply #390
Hi, is there any possibility to bypass the %artist% and %title%, since none of my files are tagged, I'm using the directory/file name to display all the info I need. Unfortunately I can't change the artist and title info for foo_audioscrobbler.
Thanks in advance!
[edit]Or am I missing an option in foobar2000 to rewrite %artist% and %title% without tagging my files?[/edit]
Reply #391
No. Tagging your files correctly is crucial to work with foo_audioscrobbler.
Reply #392
Right, goodluck with your addon.
Reply #393
Just chiming in to say I'd like this option as well!
Reply #394
Any chance of finding a older version, say 1.3.12? I'd need this since the newer versions don't support Win2k.
Thanks in advance!
Reply #395
Hey everyone, just got the foo_audioscrobbler plugin, set it up in foobar with username and password, started playing, but the submissions aren't appearing on my last.fm page. And yes, I have checked the submissions server status and everything is online.
Here's my console output:
Facet initialized in : 0:00.051
Facet initialized in : 0:00.044
Startup time : 0:01.465022
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting track...
Audioscrobbler: Submission succeeded.
Also, does handshake successful mean there's a constantly open connection while foobar/the plugin is running? Surely if there is this could be a security risk?
And a quick off-topic, why is there 2 facet initialisation values?
Many thanks for the plugin and help everyone, esp. Florian.
Reply #396
thank you a lot
Reply #397
Heya Florian, just wished to make sure you had a look at this topic about rockbox. I think it would be the easiest way if you could include it in foo_audioscrobbler, as you already have all the audioscrobbler protocol support, but eh it's up to you of course
If you are interested and need more details about it, please ask.
Reply #398
I've just released foo_audioscrobbler 1.3.16 which fixes a problem with scrobbling tracks with tracknumbers that contain characters that are subject to url encoding.
You can get it via the first post of this topic.
Reply #399
I play a fair amount of my classical music off vinyl, CD and SACD and use mp3s just over 30secs long to submit what I have been listening to.  Today I had to upgrade foobar and the audioscrobbler plugin as the old version I was using stopped working.  The new version doesn't seem to like files that are only just over 30 seconds long,  they don't submit and no warning or reason is given.  Have you increased the minimum track length to above 30 seconds for some reason?
In case anyone thinks I just want to spam the system, my profile is here: http://www.last.fm/user/spod_mandel
I don't exactly submit an excessive amount of music.
This does make the new version of foobar2000 essentially unusable for me.  Just discovered why the old version wasn't working, so am using that again for now.
wow thats so incredible nerdy to play the mp3 of your vinyls to get them listed in last.fm ... extreme
