Topic: foo_audioscrobbler 1.4.7 (Read 931447 times) previous topic - next topic
Reply #300
Great component Florian, keep up the good work.
Just wondering if there is any interest in making foo_audioscrobbler submit information from streams so that those tracks will be scrobbled as well? I think this would be a handy feature, and I don't know why the Last.FM client doesn't support it yet either.
Hear any thoughts on this would be great.
jmlane
Reply #301
Now it works perfect as usual.
I only changed the ".jpg" to ".*" in the Album Art Panel sources.
And now I also can open the audio CD without any "I/O error (win32 #xyz).
Reply #302
Worlking fine, here in 0.9.5
I decided to uninstall my 0.9.5 and start over with a new installation and now 0.9.5 and audioscrobbler 1.3.9 are getting along perfectly
I really have no idea what was causing the problems before, must have been something on my end, but hey all is good now
Reply #303
I'm using the latest foobar beta (0.9.5 beta 1) and Audioscrobbler 1.3.9. I keep getting the 'Cannot connect to server' error, while at the same time older foobar and foo_audioscrobbler seem to be submitting just fine. So it isn't an issue with my connection or last.fm server. This isn't a firewall issue, either. Any ideas?
Reply #304
In my case I believe it might have been a firewall issue. I have two Foobar installs, one running the latest beta, the other 0.9.4.5. When I did a reinstall of 0.9.5 my firewall asked me if I wanted to update my rules for Foobar. Since then it's working fine. So I think either for some reason I didn't get this same firewall rule update request or I accidentally dismissed it, I'm not sure. So in case you haven't tried yet I would suggest to remove your firewall rule(s) for foobar and starting over.
Reply #305
Im my case it's not firewall issue - same foobar installation (0.9.5b1) and if I use foo_audioscrobbler 1.3.6 it works, when I switch to 1.3.9 it keeps telling me that it cant connect to server... So there must be some problem with new version I guess...
Reply #306
.95b2+1.3.9 work fine here
Reply #307
I've just released foo_audioscrobbler 1.3.10 which fixes a random DNS problem that was responsible for the "Cannot connect to server" messages.
You can get it via the first post of this topic.
Kind regards,
Florian
Reply #308
Installed it, works fine so far, but has a funny line at the first start:  "Startup time : 13799wk 4d 5:01:41.952348" - after a second start of foobar the line looks normal again. I use foobar 0.9.4.2
My problem with the brackets is still there (see page 12 of this thread), I hope you can fix this too.
Reply #309
thanks, it works now !
Kind regards,
Florian
Reply #310
Sorry to say this but i should have tested it more... It's not working at all. With every song I hear the lastfm site tells me, that the song was wrong tagged and could not be added.
Reply #311
I had now enough time to play with the new plugin. It works with all songs besides the ones tagged as [:SITD:]. If I play a song of this artist lastfm tells me, the song was wrong tagged and could not be added and this warning stays there till I click on it. That's why I thought this warning was for all songs, but it's only for songs of [:SITD:].
Removing the brackets is still the only way to get it working. lastfm's recenttracks.txt shows me:
1194295673,[:SITD:] – Curtain Raiser
So I still think the brackets should be okay and the plugin causes the problem. Anybody else having a problem with brackets?
Reply #312
I don't know if it's possible but is there any way to grab the play count for a particular song from last.fm and retag the mp3 with it?
Reply #313
This is because of the spam filter on last.fm's side, nothing to do with the plugin. Have you tried tagging the files with MusicBrainz? If the plugin submits a MB Track ID it will by-pass the filter, or you can wait until Last.fm finish their own fingerprinting.
Reply #314
Actually I use musicbrainz to get the track information within EAC, which I use for ripping my CDs.
I tagged some mp3s now again and got the additional musicbrainz information (musicbrainz_trackid and many more) in the id3tag, but there is no difference, I still get the error message on my lastfm site.
It is still working with "[:SITD:] & Painbastard" though, although there are brackets in the artists name.
Reply #315
Citizen, can you please send me one of this problematic tracks to my contact email for further analysing this issue.
Reply #317
Okay, I sent you the smallest file I have of this artist. Thank you!
I've tried it and encountered the same problem.
A quick chat with someone from the last.fm staff gave some insight to this issue: at the moment they are blocking all artists in square brackets. So this is not an issue with the component, but a general limitation of the service.
Reply #318
Uhh... thanks for that information... weird... so I will blame lastfm. Thanks!
EDIT: But it's working with an artist name  '[:SITD:] & Painbastard' - there are square brackets and it's working! weird lastfm....
Reply #319
I looked at some of my mp3s I have and noticed that the MB trackID has been written to UFID which, from a quick look at the wiki, foobar does not support. Thus MB trackIDs are not currently possible to submit, unless the MBtagger changes to storing it in a TXXX frame, like all the other data it adds.
This only appears to be a mp3 problem as I get the field MUSICBRAINZ_TRACKID on ogg and flac files. IMO I would say this is an inconsistency with the tagger, and/or a limitation with foobar's tagging support.
Reply #320
I've just released foo_audioscrobbler 1.3.11 which fixes a crash caused by wrong handling of MusicBrainz Track IDs and a problem where successfully submitted tracks are submitted again in rare cases.
Kind regards,
Florian
Reply #321
Unfortunately there was a problem with the last version 1.3.11 that that prevented foobar2000 from closing correctly in certain circumstances.
The new release of foo_audioscrobbler 1.3.12 fixes this problem and removes the title formatting field for the cache size (because title formatting isn't intended for global data).
Kind regards,
Florian
Reply #322
Version w/o installer is still 1.3.11
Thinking Outside The Box
Reply #323
In foobar it does report as 1.3.11. However, in Windows Explorer, it says its 1.3.12... so which one is it really?
Reply #324
I forgot to bump the version number within the component. It's fixed now, thanks!
