Topic: foo_audioscrobbler 1.4.7 (Read 740894 times) previous topic - next topic
  • Florian
  • Moderator
Reply #50
Just released foo_audioscrobbler 1.3.4 which is a maintenance release compiled with the new SDK.
Mp3tag - universal multi-format tag editor
http://www.mp3tag.de/en/
  • alive
Reply #51
great plugin!
Is there a special reason why tracks are not submitted one at a time, and instead in batches of five?
edit: Nevermind, that was just because I had updated from 1.3.2 -> 1.3.4
  • Last Edit: 21 June, 2006, 04:51:35 AM by alive
Pusk is the new Start.
  • mandel
Reply #52
I play a fair amount of my classical music off vinyl, CD and SACD and use mp3s just over 30secs long to submit what I have been listening to.  Today I had to upgrade foobar and the audioscrobbler plugin as the old version I was using stopped working.  The new version doesn't seem to like files that are only just over 30 seconds long,  they don't submit and no warning or reason is given.  Have you increased the minimum track length to above 30 seconds for some reason?
In case anyone thinks I just want to spam the system, my profile is here: http://www.last.fm/user/spod_mandel
I don't exactly submit an excessive amount of music.
This does make the new version of foobar2000 essentially unusable for me.  Just discovered why the old version wasn't working, so am using that again for now.
  • Last Edit: 29 June, 2006, 06:32:26 PM by mandel
Reply #53
When you say "over 30 seconds", are they over 31 seconds too, because that's the minimum length for submitting.
  • mandel
Reply #54
Nope, are about 30.5 seconds long.  Are you saying 31 seconds is the offical last.fm policy or just what is specified in the foobar plugin?
  • drake
Reply #55
how do i fix it. i open the console and get
"[16:03:58] Handshaking: Client up to date.
[16:03:58] Submit interval set to 1 seconds.
[16:03:58] Handshake successful.
[16:04:00] Startup time : 0:11.672720
[16:09:07] Submitting 16 cached tracks to Audioscrobbler...
[16:09:07] Submission failed: bad authorization.
[16:13:50] Submitting 17 cached tracks to Audioscrobbler...
[16:13:50] Submission failed: bad authorization."
  • Florian
  • Moderator
Reply #56
Are you using foo_audioscrobbler 1.3.4? I'm asking because the latest version should re-handshake if it gets BADAUTH as reply.
Mandel, there is a rounding issue for tracks between 30 and 31 seconds in the current version of the plugin. I'll fix it to the next release.
  • Last Edit: 02 July, 2006, 04:16:22 PM by Florian
Reply #57
well nice done.
but as i dont have internet at my music-pc i´d really really like an plugin with all these statistic-features offline available!
  • molnart
Reply #58
well nice done.
There are two components called foo_playcount, an "official" and an "unofficial" one. I never tried them, but they may provide the features you're looking for.
  • vladkao
Reply #59
I have the same problem with foo_audioscrobbler 1.3.4:
Submitting track to Audioscrobbler...
Submission succeeded.
  • Skates
Reply #60
I have had problems submitting tracks for the last two days:
Not submitting. Cache contains 25 tracks.
There's more from where that came from, anyone else having the same problems?
  • AliHaze
Reply #61
I had the same problem yesterday.
Did you install the shiny new last.m client? If so, uninstalling the client helped in my case.
  • HellSpam
Reply #62
I can't get it to work... keep getting:
Not submitting. Cache contains 5 tracks.
Cannot connect to server.
I ran ethereal, and it seems that it's getting a 404 error for the ip address 62.216.251.200, which according to a whois belongs to last.fm. Could they have changed the server?
  • ddawg
Reply #63
Same problem here.
  • HellSpam
Reply #64
Apparently, the submission server is down, so that COULD be the issue...
And to go a bit off topic - I totaly hate last.fm's new app. Why the hell shoud I have two players open? Hate that stuff.
  • AliHaze
Reply #65
Last.fm's submission server is currently down:
Submissions Server
# Status: OFFLINE
You can check the server status here:
http://www.last.fm/forum/21713/_/51596
EDIT:
And I totally agree with you, Hellspam.
Especially as there seem to be submission problems when using the app (e.g. as radio player) and still having the dll for foobar (listening to my music). Well, no radio for me then...
  • Last Edit: 19 July, 2006, 05:09:28 AM by AliHaze
  • encosion
Reply #66
[EDIT] It was just a matter of patience... Working perfectly, thanks! [/EDIT]
_______ ___ __ _
Yeah, I'm getting the same thing guys... And Last.FM says their server is up... I'm using 1.3.4 with fbk 0.9.2
Startup time : 0:00.118958
Not submitting. Cache contains 16 tracks.
Submitting 10 of 17 cached tracks to Audioscrobbler...
  • Last Edit: 19 July, 2006, 06:44:30 AM by encosion
  • gaekwad2
Reply #67
Give it some time, it's probably overloaded from everybody submitting all their cached tracks.
  • Hancoque
Reply #68
Florian, are you also the author of the official plugin on Last.fm and is your version 1.3.2 of the plugin the same as version 1.3.2 that's currently available on Last.fm? I wonder which one I should use (official 1.3.2 or unofficial 1.3.4).
It does the same as the new beta Audioscrobbler, except that you won't need to run the additional Audioscrobbler application in the system notification area.
Do you plan to update the stand-alone plugin to use the new protocol introduced with the Last.fm software?
  • Last Edit: 25 July, 2006, 10:00:44 AM by Hancoque
  • Florian
  • Moderator
Reply #69
Yes, version 1.3.2 is also from me, but Russ is a little bit slow with updating the downloads section  You can safely use version 1.3.4 of foo_audioscrobbler.
I'm not aware of a new protocol version and I'm still using version 1.1. Can you please point me to the new spec?
  • Hancoque
Reply #70
I have no spec but I found this post: http://www.last.fm/forum/34905/_/135053
Quote from: Russ link=msg=0 date=
Old-style plugin authors: I can change your old plugin forum into a group forum if you wish to continue supporting it. Alternatively, I can help you port your plugin to the new Audioscrobbler Client protocol.
That made me assume that there is a new protocol of some sort.
  • Last Edit: 25 July, 2006, 11:26:00 AM by Hancoque
  • Florian
  • Moderator
Reply #71
Yes, but it is the new protocol for talking to the official Audioscrobbler client application. The protocol for talking with the severs wasn't changed.
  • Hancoque
Reply #72
Then never mind.
Reply #73
Would it be posible to add an option to enable submitting tracks from Audio CDs even if "Only submit tracks from the Media Library" is enabled.
  • ahsile
Reply #74
Getting bad auth messages like others. The last.fm page says the submission server is up. Wondered if anyone else is seeing these issues?
