Topic: Nero AAC Recommended Settings (Read 89976 times) previous topic - next topic
can anyone recommend a string to get this working in EAC? Please?
aha, thanks. i missed out the %s (doh!)
so is the latest encoder included in Nero 7 or do I have to install the software linked above?
You don't even need Nero 7 to run that software. So I'd say just use the new program and leave Nero alone.
Just to clarify, what are the options to set for the foobar CLI interface (0.83 and 0.9x)
I'm thinking stuff like 16/24 bit, floating point, accurate length and tagging issues.
And please write in large and coloured text "do not use 2pass with pure VBR mode it makes no sense". Or disable that combination in next release.
Nero has a slightly older version of the encoder above, but it is safe to use if you for example feel uncomfortable using a command line utility. There are no significant quality differences.
Options given are for 0.9.x, I'll clarify that. The encoder will accept any input format.
For 0.8.3, you can enable accurate length, or disable it and use "-ignorelength". As far as I understand, the latter option is actually preferred.
There are some reports that 0.8.3 might have broken MP4 tagging, so using 0.9.x is recommended.
We will probably just disable it. I certainly didn't anticipate that people would try to do that!
                Note that the above switches (-lc, -he, -hev2) should not be
                used; optimal AAC profile is automatically determined from
                quality/bitrate settings when no override is specified.
By default, what quality/bitrate settings result in LC/HE/HEv2 profile being used?
http://www.hydrogenaudio.org/forums/index....55&#entry386255
Sorry, but this was changed in the meantime based on test feedback.
Currently, the switching is at <40kbps (PS enabled) and <85kbps (SBR enabled).
The quality levels are -q 0.16 and -q 0.31 (from memory, may be wrong).
Note that this all may change from update to update as we change or improve various parts of the encoder, so relying on this is not a good idea. ("The Link" already unwillingly demonstrated this  )
This is also only valid for stereo. Mono and multichannel work differently yet again.
Mhmm floating point input, nice
thx
whoooooo , that's what I wanted .... settings are right (0.159 = ps enabled, 0.309 = sbr enabled) ......
if you change this "parameters" can you put it in the readme.txt or in a changelog ?
thanks in advance
    <-- nero acc devs
  <-- users
An interested Niph :D
i cant seem to find that 'quality <-> bitrate' table anymore? (were quality switches changed as well?)
oh, tnx.
Possible to add switch for wav input chanel order like for example faac. It's very usefull setting.
-q 0.5 -if %s -of %d
Thanks to Nero for that decission (releasing the encoder for free) :up: !
So far I used nero_fends as a command line tool together with my nero6 dlls - and I am more than glad to switch now to the new encoder version - only question is - how can I tag the files via EAC? So far I was used to just provide the tags through the command line and those switches am I missing now.
I'm a Lame --preset extreme kind of guy normally, what would be an similar setting in Neroenc? .6 ? or is that too much?
I would like to know as well.  The jump between .5 and .55 seems a bit high, or maybe it was just the music I selected.  Don't know where standard or extreme would actually land.  Or the previous AAC Normal/High settings.
Get AtomicParsley. Make sure to download v0.8.0, and not the latest one (buggy).
File extension: .m4a
Program used for compression:  c:\WINDOWS\System32\cmd.exe
Additional command line options:
    /c c:\Encoders\neroAacEnc.exe -q 0.5 -if %s -of %d && c:\Encoders\AtomicParsley.exe %d --writeBack --artist "%a" --album "%g" --tracknum "%n/%x" --title "%t" --genre "%m" --year "%y"
could we use this AtomicParsley to tag from EAC? I can't get EAC to insert the tags.
take a look at MAREO, it works fine with the conbination.
the Atomic Parsley method (above) works fine. I couldn't get Mareo to tag.... It would encode the Flac, encode the mp4, then say something about "file already exists" when it comes to tagging.
But we're going off topic, apologies
When I encode a file using -q .55 (latest Nenc), the files show up as CBR in Foobar. Is this normal? I thought they were VBR? (or is that a bug in foobar?)
-- edit
it must be something with the output codecs. I installed the in_mp4 from rarewares in Winamp and now its showing it as a vbr
sorry, just checking that I wasn't doing anything wrong
Which foobar2000 version?! As far as I know it doesn't even display that...but yes, -q is definitely VBR.
... and similarly, when I encode using -cbr, looking at the bitrate indicator in Winamp (using the MP4 input plugin for Winamp plugin found at RareWares) the bitrate still fluctuates by a few kbps either direction of the target.
Same question: Is this normal? I thought they were "CBR"?
The plugin in question shows up as "AudioCoding.com MPEG-4 General Audio player: 2.1 beta compiled on Jul 9 2004." (Is there a later version?)
    - M.
