Topic: HE-AAC V2 pattern decoding error with FAAD2.0 latest codes (Read 2982 times) previous topic - next topic
Hi.
I met with following error while decoding the patterns in the attachment using FAAD latest version codes.
The pattern uploaded is in ADTS format with samplerate 24000  and 1 channel ,using HE-AAC V2 standard.
I can use other codes like "Elecard AAC decoder" to decoding this pattern well, but while in FAAD , it will show "Error: Maximum number of bitstream elements exceeded" .
Can anyone help on this case? Is it because of the pattern's bad frame data or because of FAAD's limited capability?
Thanks...
[attachment=2194:attachment]
Soory... Just forgot to add the attachment...
