Topic: Getting foo_uie_search to work (Read 4452 times) previous topic - next topic
I get the following error message:
INFO (CORE) : startup time: 391 ms
ERROR (CORE) : Failed to load DLL: foo_uie_search.dll, reason: Unable to load DLL.
Tried on a fresh install on two separate machines. The dll from that website does not work!
I have been looking for WEEKS for a panel search plugin like that. I cannot believe when I finally find one, it does not work! I have not updated to 0.9 yet because the other plugin I reallly like, RMX, has not yet been ported.
Do you have a working version of the foo_uie_search.dll plugin for 0.8.3? I would really appreciate a copy! Thanks.
  I have a working copy.  I do not know where I found foo_uie_search.  I do not understand why it is not a more well known componant since it is excellent.  However I just downloaded the file from the above link and that file and the one I allready had are the same.  I hope this is of some help and I hope you get it working.
Try to put msvcr80.dll in your Foobar folder.
Doesn't seem to help any. Why exactly does it not work for me on TWO separate machines if the plugin is functional for other people? Do I need to have something else installed that I may be missing?
EDIT: You were on the right track though. I just had to reinstall .net framework (and install for the first time) on the other machine.
