Topic: foo_cwb_hooks (Read 305290 times) previous topic - next topic
foo_cwb_hooks
Reply #275
I changed the tag name and the tags. They worked on the previous versions when the buttons were enabled by default.
foo_cwb_hooks
Reply #276
Can someone upload latest version on http://savefile.com ?
I can't download 1.2beta0c with the link cwbowron provide. all i got is 1.2beta0b no matter how i try.
Thanks in advance.
foo_cwb_hooks
Reply #277
Have you tried empty your browser's cache?
foo_cwb_hooks
Reply #278
Yes i already try that.(3 times actually & reset too) I don't really know why i still got the old version.
foo_cwb_hooks
Reply #279
If you use IE then maybe try Firefox/Opera.
foo_cwb_hooks
Reply #280
What UI are you using?
There used to be a link to my website here.
foo_cwb_hooks
Reply #281
Columns UI 0.2.0 alpha 1
Panels UI 0.13.5 beta
Main interface is Columns UI, only using Panels UI for SCPL Track Display and Library Filter.
foo_cwb_hooks
Reply #282
Ok, I found the problem.
Columns UI 0.2 was working a little differently than 0.1.x, but I have the issue fixed and uploaded a newer version to the website.  (1.2.beta0d).
foo_cwb_hooks
Reply #283
So far... It's working right now.
foo_cwb_hooks
Reply #284
Same here, just minor glitching when resizing.
foo_cwb_hooks
Reply #285
to cwbowron:
I regularly backup all my 14k tracks because I put a lot of work in tagging them.
Recently, I had to temporarily point the FB media library to my backup drive and this ended up in retagging all the tracks in the drive.
Would it possible for you to add a warning dialog when a new drive or directory are added to the media library to make people aware they still have the "new files tagger" on?
Maybe with a question if they would like to tag or not the incoming "new files"?
foo_cwb_hooks
Reply #286
to cwbowron:
Its probably not going to happen, but there is a checkbox under Preferences->New File Tagger that you can turn on and off as to whether you want files tagged or not.
I just uploaded another beta release with the tagger window:
= Release 1.2.beta1 =
* added rating radio buttons to tagger window
* added filename display to top of tagger window
foo_cwb_hooks
Reply #287
to cwbowron:
Yes, I know, but unfortunately I didn't even remember I had the nft on.
Honestly, I think I wouldn't have realized the plugin was going to consider my old backupped tracks as "new" even if I did remember it was there and on. This is why I'm asking you that warning dialog.
foo_cwb_hooks
Reply #288
I think this is a bug.
in Column UI 0.2.0 If i put tagger window in tabbed panel stack. Changed layout to another. and then change back. tagger window will gone.    and sometime when i add it to my tabbed panel. close preference. and still tagger window will not show up.
If i not put it in tabbed panel and to somewhere else. and change layout then change back. tagger window is still show in column ui layout page in preference. but it's not show up in my UI.
cwb hook version 1.2.beta1
foo_cwb_hooks
Reply #289
= Release 1.2.beta2 =
* tagger window: work with multiple files
* tagger window: work on the contents of the active playlist selection or now playing (whichever action happend last)
* tagger window: when adding tags to the list box, also add them to the stored list of tags
* tagger window: bug fixes - tested to work with foo_uie_tabs
foo_cwb_hooks
Reply #290
cwbowron: Do you think it would be possible to make $cwb_fileexists work with something like *.bmp ? (i know i already asked but i was not sure you saw it)
foo_cwb_hooks
Reply #291
The bugs i report are now gone    Great job cwbowron.
I noticed that now there is a "grey" checkbox. what does it do?
foo_cwb_hooks
Reply #292
the grey checkbox means leave as is... It will show up when the tag is in some, but not all of the selected tracks.  If you don't change it to the regular checkbox or a non-checkbox it won't modify that tag.
foo_cwb_hooks
Reply #293
Please, include "hotness" meta-rating in cwb_hooks! That would be very useful for other plugins like playlist_tree.
foo_cwb_hooks
Reply #294
great stuff cwb,
was wondering if %cwb_selection_count% -is, could, might, won't -be added?
or maybe this is already possible with existing title formatting?
I have the same request for %cwb_selection_count%. If there is another solution please let me know.
foo_cwb_hooks
Reply #295
cwbowron, the Tagger Window is a nice addition (I guess I can ditch the keyword tagger I made for PUI).
The UI needs some work though.
foo_cwb_hooks
Reply #297
Maybe something like that? The tabs at the top represent more than one tag field that users could specify in settings. That might be a lot of work (what's in that concept) and maybe even warrant its on tagger window component?
I made a mistake though in the concept. If tag values are to be clickable (for searches), I should have made them look like hotlinks (underlined with Windows' default hotlink color).
foo_cwb_hooks
Reply #298
  I also thinking that to have multiple tag window&tag name would be great. But not think far enough to have them tabbed together. Nice!
May i also add some request? i think it's nothing fancy or something new but certainly be very useful.
Ability to change background&font color and change font.
foo_cwb_hooks
Reply #299
I agree with the two previous posters, this tagger panel is a great addon. I also agrees 100 % on all their requests< hiding ratings, tabbed tag fields, clickable tag values, and ability to change the colors and fonts
Great idea this however!
