Topic: foo_dsp_silence (Read 16221 times) previous topic - next topic
foo_dsp_silence
foo_dsp_silence
After someone ranted in the IRC channel about creating pauses in between tracks and mourned foo_dsp_pause from 0.8, I made foo_dsp_silence. The plugin will insert a configurable amount of silence at the end of tracks. It's handy for getting MiniDisc devices to detect track changes.
foo_dsp_silence
[deleted]
foo_dsp_silence
Now that was a stupid bug.
Reproduced and fixed with 0.0.2, available from the site.
foo_dsp_silence
you're a hero
foo_dsp_silence
Thank you! I also have a MD-Player. Maybe it's time to record some tracks
foo_dsp_silence
I have this CD of many tracks but the end of a track sometimes is the intro of another and i wonder how to get gapless trackmarks like on the original CD. Would you know? I suppose relying on the MD to just cut off the silence accurately wont work.
foo_dsp_silence
Hm, some days ago, this component caused my foobar to crash, but now everything seems to work just fine (maybe due to a reduction to a minimal number of components).
I'll let you know if there will be a problem again, because I am one of the surviving MD users not keen on buying an mp3player.
foo_dsp_silence
[deleted]
foo_dsp_silence
rotzbouw: I'd be interested in knowing if this crash produced any failure.txt, and how it crashed. Did it make foobar2000 poof, throw up a dialog about getting terminated by the runtime, or did it show the regular windows crashed app box?
Also, what were you doing when the crash occured? Was it at a track change event, just generic fiddling around or something odd?
foo_dsp_silence
[deleted]
foo_dsp_silence
Unfortunately I don't have logs anymore as I have completely reinstalled foobar2000.
The crash happened at a track change, yes. I remember it causing Dr Watsons to get started but not the exact error message, I'm afraid.
However, it seems that it works perfectly well now, so I can't help you with bug reports anymore
foo_dsp_silence
I have a question can this plugin make it like when your listening to a album version of a song and it gets real quiet at the end or theres no point of hearing near silence, can it can fade out that track at a certain amount of silence and go into the next track?
Thanks if you know
foo_dsp_silence
I need pre-track silence, since my MP3 player does fade in effect at beginning  of each track . Do you add this feature?
foo_dsp_silence
Does anyone can to recompile plugin for using in foobar2000 1.0?
