Topic: Columns UI / Panels UI appearance (Read 3571450 times) previous topic - next topic
  • dBaines
Reply #75
  • Fungo
Reply #76
[a href="index.php?act=findpost&pid=377400"][{POST_SNAPBACK}][/a]
how do you make the artists/compilation tab (left/bottom)?
  • dBaines
Reply #77
[a href=\"index.php?act=findpost&pid=377400\"][{POST_SNAPBACK}][/a]
[a href=\"index.php?act=findpost&pid=377402\"][{POST_SNAPBACK}][/a]
The Artists/Compilations headers are just playlists with >> infront of them, so the playlist name would be >>Artists or >>Compilations. Then in the titleformatting code I've put 'if title contains >>, hide the >> and format it as a header'.
Here's the actual code if you want to play around with it:
// If contains >> set as header
$if(
$strchr(%title%,>>),
$replace(
// Header formatting
$upper(
$tab()
$rgb(0,0,0)
%title%
$tab(4)
// If Is Playing...
$if(%is_playing%,
♫ $replace(%title%,-s-,),
♪ $replace(%title%,-s-,)
// Show length
$tab()
$rgb(128,144,159)
%length%
 '('%size% tracks')'
$rgb()
It also hides the "-s-" on singles playlists.
  • Last Edit: 31 March, 2006, 04:39:31 AM by dBaines
  • mazy
Reply #78
How did you add multiple trackinfo panels?
And how did you get those artists to be in different colours? (I assume it alternates?)
[a href="index.php?act=findpost&pid=377262"][{POST_SNAPBACK}][/a]
1) multiple track info panels - you have to change two guids in the binary + 2 strings (that's optional but better) and rename the file.
2) in 0.9, there's $crc function, which can be used to compute hash of some string (like album's name) and then use this number (modulo) in color setting functions like $rgb - or better - $hsl. it's all in the wiki and there are examples in the old gallery thread.
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
  • fusion
Reply #79
[a href="http://img221.imageshack.us/my.php?image=myfoo3lg.png" target="_blank"]
http://www.deviantart.com/deviation/29511577/
  • Last Edit: 31 March, 2006, 09:51:53 AM by fusion
/\_/\
  • gamegod
Reply #80
I wanna foo_uie_albumart.dll
But I don't find where to download
  • Last Edit: 31 March, 2006, 07:15:20 AM by gamegod
  • gamegod
Reply #81
I can't download foo_uie_albumart.dll from
http://stephan.kochen.nl/proj/foo_uie_albu...ie_albumart.dll
Anyone can give it to me?
  • 2Pacalypse
Reply #82
im going insane, cant find the check box to put the playlist tabs at the top of the playlist can someone point it out.  im sure it was obvious in 0.8.3 im going blind
  • lav-chan
Reply #83
In the Columns UI Layout tab you have to specifically add the play-list tabs, and then once you do that you have to right-click it and insert the play list.[a href="index.php?act=findpost&pid=377309"][{POST_SNAPBACK}][/a]
  • Tiis
Reply #84
Tiis, what does the far right column display? Play_count+er? What character did you make that bar with?
[a href="index.php?act=findpost&pid=377230"][{POST_SNAPBACK}][/a]
Its the Rating-bar, using this ▀ char for displaying.
[a href="index.php?act=findpost&pid=377354"][{POST_SNAPBACK}][/a]
What font are you using to display this char? Unicode one? Mine gets displayed as a outline of a rectangle.
[a href="index.php?act=findpost&pid=377358"][{POST_SNAPBACK}][/a]
Sry, its Lucida Sans Unicode.
  • Nordland
Reply #85
[a href="index.php?act=findpost&pid=376797"][{POST_SNAPBACK}]
Really nice looking foobar!
What is the name of the visual style you are using?
http://www.mackycorp.org/pics/foo_setup.png
Nothing really special, I tweaked azrael to fit the colors I like.
I got the idea that foobar would look great without any panel borders, so I quicky photoshopped this...
http://www.mackycorp.org/pics/foo_setup_borderless.png
[a href="index.php?act=findpost&pid=377297"][{POST_SNAPBACK}][/a]
...And what visual style are you using? =)
Hotness!
  • Last Edit: 31 March, 2006, 10:49:44 AM by Nordland
  • C00I90WN
Reply #86
Here it is, this is my current config, I made it from scratch, totally customized
[a href="http://img126.imageshack.us/my.php?image=foobar0rb.jpg" target="_blank"]
Greetings
C00I90WN
Random number generation is too important to be left to chance
  • bidz
Reply #87
Keeping it clean and simple
myspace.com/borgei - last.fm/user/borgei
  • mackycorp
Reply #88
Hotness!
[a href="index.php?act=findpost&pid=377474"][{POST_SNAPBACK}][/a]
I'm using bblean ( [a href="http://bb4win.sourceforge.net/bblean/]http://bb4win.sourceforge.net/bblean/[/url] ). I can't quite remember the name of the theme, though. I know it has something to do with coffee. I'll look it up when I get back on my system tonight.
edit:
The theme is called "Black Coffee"
  • Last Edit: 31 March, 2006, 04:26:05 PM by mackycorp
  • m-z
Reply #89
I'm finally happy with my new foobar.
  • Last Edit: 31 March, 2006, 01:39:36 PM by m-z
  • Glass
Reply #90
[a href="index.php?act=findpost&pid=377531"][{POST_SNAPBACK}][/a]
In your playlist view, what is that a dragable "column" divider looking thing? (separating the album name from the tracks.)
love, IAN
droptothetop.com/
  • lav-chan
Reply #91
I'm sure it's just a column with a background colour made to look like a divider.
  • Glass
Reply #92
[a href="index.php?act=findpost&pid=377639"][{POST_SNAPBACK}][/a]
I just realized that's probably what it was also.
love, IAN
droptothetop.com/
  • nightwingz
Reply #93
here is mine....
I have a few questions tho, 1. How can I change the boxes in the Album List to arrows? If thats possible let me know thanks. 2. What is that plugin that im seeing where it shows what song your playing up top? Id really like to have that aswell. Any help would be greatly appreciated. Thanks
~nightwingz
  • lav-chan
Reply #94
1. Depends on your visual style.
2. foo_uie_trackinfo
  • nightwingz
Reply #95
[a href="index.php?act=findpost&pid=377681"][{POST_SNAPBACK}][/a]
Ok, I figured it was the trackinfo coding that was diff on the one i saw. But was just making sure.
Too bad you can't customize those boxes though without changing your VS. I really hate those ugly boxes .  Thanks for fast reply.
~nightwingz
  • Last Edit: 31 March, 2006, 09:27:57 PM by nightwingz
  • nightwingz
Reply #96
Hey all first time showing my setup....zoom in for full view
foobar .9, Album art, track info, foo_Ac3, columns UI edited Navigator fcs...
[a href="index.php?act=findpost&pid=376734"][{POST_SNAPBACK}][/a]
Mind telling me where you got those buttons from? I could use surely use them. Thanks
~nightwingz
  • foosion
  • Moderator
Reply #97
FCS (Note: Right-click -> Save as doesn't work with this for some reason...)
http://foosion.foobar2000.org/ - my components for foobar2000
  • lav-chan
Reply #98
curious indeed
  • Nova5000
Reply #99
I get 'Invalid File' when loading yours, foosion.. It's not ColumnsUI, am I right?
