Topic: Columns UI / Panels UI appearance (Read 3568089 times) previous topic - next topic
  • manudevil
Reply #50
[a href="index.php?act=findpost&pid=376838"][{POST_SNAPBACK}]
For the track_info panel i used 'AvantGarde LT Medium Caps bold 14pt', you can get it here.
The component for the popup is called 'Pretty Popup', you can find it easily on these boards.
[a href="index.php?act=findpost&pid=376967"][{POST_SNAPBACK}][/a]
Could you give us the code for your PrettyPop seekbar, please ?
Sites dynamiques : http://www.manudevil.com
  • mazy
Reply #51
added 2nd and 3rd track info panel ...
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
Reply #52
This is my config. Its based on habla's setup, I removed the tag checks and added replaygain ones. The questionmark is to remind me to fix hottness somehow
  • Tiis
Reply #53
Conversation of my 0.8.3, also with flashing TrackInfo Panel. Every two secs. a new info about the actual track
New:
[a href="http://img232.imageshack.us/my.php?image=090vx.png" target="_blank"]
Download
  • vonmeth
Reply #54
Great setups everyone =)
Just had a question though.
Is there a way to change the first track numbers color?
http://img207.imageshack.us/img207/487/here3ik.jpg
For example the first track number for the Sigur Ros album Von is in black, and I wish to have it in white.
Thanks in advance, and thank you as well for sharing your stuff. Wouldn't have mine the way it is without it. =)
  • Habla
Reply #55
Nice mod, UOBean!
Looks good. I could mod my fcs to make different color schemes, so people could choose one they liked.
It took a long time to change all the colors, because none of them are set in the globals. You think that was hard, I should tell you how long it took to port the whole style from v0.83...
Tiis, what does the far right column display? Play_count+er? What character did you make that bar with?
Looks like my PLisk mod is a hit....
  • Last Edit: 30 March, 2006, 05:02:51 PM by Habla
Reply #56
@turzol: that looks great, mind sharing the fcs and the telling me what fonts you used ?
  • Chri5peed
  • Banned
Reply #57
Is there a way to remove the fugly grey surrounds, or at least change its colour to the same as the playlist background so it doesn't stick out?
A kind of easy way!;)
I'll just edit this post -
Is there a plugin to operate Foobar from the rightclick menu?
  • Last Edit: 30 March, 2006, 06:31:35 PM by Chri5peed
  • Jayphen
Reply #58
[a href="index.php?act=findpost&pid=377143"][{POST_SNAPBACK}][/a]
How did you add multiple trackinfo panels?
And how did you get those artists to be in different colours? (I assume it alternates?)
  • sIIhZt
Reply #59
works fine with multi and single artist albums
fcs-file: http://rapidshare.de/files/16832968/bluestripes.fcs.html
  • Last Edit: 30 March, 2006, 07:19:15 PM by larskl
Reply #60
[a href="index.php?act=findpost&pid=377262"][{POST_SNAPBACK}][/a]
In .9 you are able to add as many panels, toolbars and the like to your interface as you want. Just insert them into the splitter repeatedly.
  • mackycorp
Reply #61
http://www.mackycorp.org/pics/foo_setup.png
Nothing really special, I tweaked azrael to fit the colors I like.
I got the idea that foobar would look great without any panel borders, so I quicky photoshopped this...
http://www.mackycorp.org/pics/foo_setup_borderless.png
  • Jayphen
Reply #62
[a href="index.php?act=findpost&pid=377295"][{POST_SNAPBACK}][/a]
I know this, but if I were to insert two trackinfo panels, they would both display the same thing.. Is there a way to make two independant ones? (Maybe change the .dll name I guess)
  • Jayphen
Reply #63
[a href="index.php?act=findpost&pid=377297"][{POST_SNAPBACK}][/a]
Yeah, that's something I repeatedly wished could be done as I was making my config.
  • Glass
Reply #64
Mine is here:
1280x1024 res screenshot
sorry for not resizing.
love, IAN
droptothetop.com/
  • chiwou
Reply #65
mine
  • EastMushu
Reply #66
Sorry guys if this is off-topic but could someone point to me how can I present my playlist in tabbed format in 0.9? I installed 0.9 a few days ago but I just couldn't get the tabbed playlist like 0.8.3, so I've reverted back to 0.8.3.
Thanks in advance.
  • lav-chan
Reply #67
In the Columns UI Layout tab you have to specifically add the play-list tabs, and then once you do that you have to right-click it and insert the play list.
  • skyhopper88
Reply #68
I'm rather proud of this. Think I'm finally happy with it. I have a bit more room for buttons though
My Foobar
  • Last Edit: 30 March, 2006, 10:43:15 PM by skyhopper88
  • UObean
Reply #69
Well I took Habla's setup and sort of stripped it a little and recolored it.
The placement of the components is temporary, but it has all the things I need for now.
[a href="index.php?act=findpost&pid=377087"][{POST_SNAPBACK}]
wanna share your cfg?  that looks so good.
[a href="http://home.comcast.net/~jroullier/foobar.rar]Download for the fcs and track info code.[/url]
I'm not going to bother uploading a config file simply because I dont think the placement of the components is that great in the first place.  Just a warning, the coding I added is somewhat sloppy.  I never claimed to be an expert.
  • lextune
Reply #70
foobar2000 + EAC + Burrrn = Happiness
  • SpaceChief
Reply #71
Just a quick question: how do I put all those panels above the playlist? In the context menu all I get is Album Art, while when I right-click the sidebar, all of them are available.
EDIT: also, in unabatedshagie's attachments I can see 'Splitter' in the layout tab. In mine there's 'Columns playlist' only.
[a href="index.php?act=findpost&pid=377054"][{POST_SNAPBACK}][/a]
It took me a long time to figure that out also; in the layout tab you 'right' click where it says 'Column' and a menu drops down and you can add all the panels, splitters, etc. to your heart's content!
  • Tiis
Reply #72
[a href="index.php?act=findpost&pid=377230"][{POST_SNAPBACK}][/a]
Its the Rating-bar, using this ▀ char for displaying.
  • takt
Reply #73
[a href="index.php?act=findpost&pid=377354"][{POST_SNAPBACK}][/a]
What font are you using to display this char? Unicode one? Mine gets displayed as a outline of a rectangle.
  • m-z
Reply #74
Old
EDIT: some small changes...
  • Last Edit: 31 March, 2006, 01:34:47 PM by m-z
