Topic: Columns UI / Panels UI appearance (Read 3569632 times) previous topic - next topic
  • Habla
Hah, I was right. Wow. Thats a surprise.
Carry on. Someone port ProjectM, dammit! :-)
  • ev0|
Umm, how do you guys get the album art to be normal at the top of the playlist (in the toolbars) ? Everytime I put it somewhere outside the sidebar it just looks too scrunched and i can't figure out how to fix it ?
  • Last Edit: 29 March, 2006, 07:21:29 PM by ev0|
  • Bryanhoop
Mine, updated today:
[{POST_SNAPBACK}][/a]
There are two ways of fixing that problem,
1. Sounds like you have just added the album art to the toolbar, so you need to go into the preferences and then to the album art tab and set the minimum height from 0 to whatever size you want.
2. Remove the album art from the toolbar and use the columnsui layout settings, mine is set like this:
[a href="http://img60.imageshack.us/my.php?image=060330thursday0600amfoobar2000.png][/url]
Which looks like this
  • c.rystal
[a href="index.php?act=findpost&pid=376838"][{POST_SNAPBACK}]
For the track_info panel i used 'AvantGarde LT Medium Caps bold 14pt', you can get it here.
The component for the popup is called 'Pretty Popup', you can find it easily on these boards.
  • Last Edit: 30 March, 2006, 09:20:45 AM by c.rystal
  • skelly831
  • Members (Donating)
My new dark style:
quite a departure from my previous iTunes-inspired look.
this one uses Bitstream Vera because on a CRT Calibri and Verdana look like crap (at least on mine.)
  • lav-chan
Those are the two best-looking fonts ever, i think, and they both look fine on all the CRTs i've ever used....
  • Jayphen
Reply #32
eh, wanna change the colours but couldn't be bothered..
  • Last Edit: 30 March, 2006, 02:28:17 AM by Jayphen
  • Jayphen
The component for the popup is called 'Pretty Toaster', you can find it easily on these boards.
[a href="index.php?act=findpost&pid=376967"][{POST_SNAPBACK}][/a]
How did you get the track info to centre like that?
  • Habla
Reply #34
There are two components for popup notification, and you fused their names together. One is called Toaster (don't know if its been updated to v0.9 yet), and the other is PrettyPopup. That looks like PrettyPopup to me.
  • Jayphen
Reply #35
Decided to completely change it..
  • turzol
Reply #36
Here's mine.
  • Insolent
Reply #37
</signature>
  • Jayphen
Reply #38
Just made a compact version of my new config. I think I'll leave it alone now
  • Jayphen
Reply #39
[a href="http://img93.imageshack.us/my.php?image=fb2k7ex.png" target="_blank"]
  • Funeral
Reply #40
  • Vaxis
Reply #41
Just a quick question: how do I put all those panels above the playlist? In the context menu all I get is Album Art, while when I right-click the sidebar, all of them are available.
EDIT: also, in unabatedshagie's attachments I can see 'Splitter' in the layout tab. In mine there's 'Columns playlist' only.
  • Last Edit: 30 March, 2006, 07:22:27 AM by Vaxis
  • Tiis
Reply #42
Conversation of my 0.8.3, also with flashing TrackInfo Panel. Every two secs. a new info about the actual track
  • c.rystal
Reply #43
I used ' $char(1)C ' in front of the first line.
You're right, it's PrettyPopup. I must have been confused
Reply #44
Here's mine.
Very, very nice!
Edit: I suppose I should include mine shouldn't I?!
As before, it's exceedingly boring. My player spends most of its life in the system tray so I'm not too fussed with its appearance.
All I've done is change the default colours and changed the font so it's a little easier on the eyes when I happen to have it open.
[a href="http://img204.imageshack.us/my.php?image=clipboard010pv.png][/url]
  • Last Edit: 30 March, 2006, 11:30:17 AM by The Seeker
Music washes away from the soul the dust of everyday life.
  • UObean
Reply #45
Well I took Habla's setup and sort of stripped it a little and recolored it.
[a href="http://xs.to/xs.php?h=xs74&d=06134&f=foobarsetup-0.9.jpg" target="_blank"]
The placement of the components is temporary, but it has all the things I need for now.
  • Masahiko
Reply #46
  • Last Edit: 30 March, 2006, 10:05:55 AM by Masahiko
Reply #47
[a href="index.php?act=findpost&pid=377054"][{POST_SNAPBACK}][/a]
You need to right click on the columns playlist and choose change base then choose the splitter you want (either vertical or horizontal)
  • j conky
Reply #48
[a href="index.php?act=findpost&pid=377055"][{POST_SNAPBACK}][/a]
That is a great setup.  Would you mind sharing your fcs and track info code?
Reply #49
[a href="index.php?act=findpost&pid=377087"][{POST_SNAPBACK}]
wanna share your cfg?  that looks so good.
