Topic: Columns UI / Panels UI appearance (Read 3569756 times) previous topic - next topic
  • esa372
  • Members (Donating)
Reply #100
FCS (Note: Right-click -> Save as doesn't work with this for some reason...)
Nice one, foosion.
Is that the "simple spectrum" I see at the bottom?
Where can the 0.9 version of that be found?
~esa
Clowns love haircuts; so should Lee Marvin's valet.
  • foosion
  • Moderator
Reply #101
esa372: In the .fcs.
http://foosion.foobar2000.org/ - my components for foobar2000
  • esa372
Reply #102
Thanks, foosion!
  • kern_th
Reply #103
Hello,
I have a question to you Habla. You said your Visual Style is "Spirit", can you pls tell me where i can download this one? I'm fascinated by your foobar Look and rebuild it on mine, only thing is missing is the Style!
thx
kern_th
BTW: my foobar atm
  • Nova5000
Reply #104
[a href="index.php?act=findpost&pid=377813"][{POST_SNAPBACK}][/a]
I can't get it to work. The .fcs that is
  • strife
Reply #105
[a href="index.php?act=findpost&pid=377828"][{POST_SNAPBACK}][/a]
uhm,
take a closer look at the fcs file.
yes,
that is why it does not work.
  • Last Edit: 01 April, 2006, 09:58:54 AM by strife
  • Nova5000
Reply #106
Stupid april fools
  • fusion
Reply #107
... You said your Visual Style is "Spirit", can you pls tell me where i can download this one? ...
I was just looking for a visual style myself and found a 'spirit v1.0'.
Don't know if this is right one.
http://www.customize.org/details/43901
/\_/\
  • kern_th
Reply #108
[a href="index.php?act=findpost&pid=377834"][{POST_SNAPBACK}][/a]
Thanks for your fast answer, but I think this isn't the one... But thank you anyway!
  • Sphix
Reply #109
Where do you guys downloaded Calibri font? I have it here but it's different from yours
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
  • lav-chan
Reply #110
It comes with our legit copies of Windows Vista, of course.
Reply #111
Where do you guys downloaded Calibri font? I have it here but it's different from yours :(
[a href="index.php?act=findpost&pid=377840"][{POST_SNAPBACK}][/a]
Do you have ClearType off like I did :O?
  • Last Edit: 01 April, 2006, 11:09:08 AM by Bob... Just Bob
Reply #112
Here's my latest, based off of mazy's fcs.
  • DeepDose
Reply #113
@ nightwingz    the buttons can be found here    http://www.hydrogenaudio.org/forums/index....pe=post&id=2125
  • nebrion
Reply #114
Here's mine, just had some problem importing old database from 0.8 but now all seems working smoothly ^^
I use azarael for columns ui with fresco white profile, the track info config file is the same one that you can find somewhere in this discussion with colours modified to match the all around looking.
  • tofu
Reply #115
Here it is, this is my current config, I made it from scratch, totally customized
Greetings
C00I90WN
[a href="index.php?act=findpost&pid=377506"][{POST_SNAPBACK}]
very nice.  mind sharing?
  • Habla
Reply #116
[a href="index.php?act=findpost&pid=377839"][{POST_SNAPBACK}][/a]
Yes it is.
  • zachastrife
Reply #117
Here's mine.
[a href="index.php?act=findpost&pid=377029"][{POST_SNAPBACK}][/a]
Are you willing to share that .fcs...
or at least tell me/us which visual style that is =)
  • nightwingz
Reply #118
[a href="index.php?act=findpost&pid=377884"][{POST_SNAPBACK}][/a]
Thanks for the link but for some reason they don't work. I load them up and the buttons just completley dissapear. Whats the reason behind this? I've even tried others but they all do the same thing, I don't get it.
~nightwingz
  • Ivan_
Reply #119
it's area04, get it from [a href="http://www.deviantart.com/deviation/23369316/]http://www.deviantart.com/deviation/23369316/[/url]
  • acedriver
Reply #120
modded navigator-suite
  • david_dl
Reply #121
Pretty standard stuff here:
  • skelly831
Reply #122
Still pretty much the same, but now the red now-playing background is a subtler red frame around the title and length, the selected item background and frame colors were taken from iTunes.
I saw this setup on an LCD monitor and could barely make out the alternating color lines in the playlist, they're clearly visible on my CRT, can anyone with a correctly set up LCD tell me if the background colors look good?
  • lav-chan
Reply #123
oh look, decrepit birth, my favourite
  • david_dl
Reply #124
[a href="index.php?act=findpost&pid=378066"][{POST_SNAPBACK}][/a]
I can see them quite clearly on my LCD...
