Topic: Foo_osd (Read 92557 times) previous topic - next topic
Re: Foo_osd
Reply #176
Tweaked my old one in above post. (see below the code)
I did notice that the text is cut at the base of the bottom line. Is there any way to fix that? See particularly the S and C for Comment and Style.
$if(%isplaying%,
$puts(pipe,$rgb(255,255,255) . )
$puts(genre,$rgb(255,0,128)$replace(%genre%,'/',$rgb(128,128,128)'/'$rgb(255,0,128)))
$puts(title_and_album,$rgb(255,0,128)%artist% $rgb(255,255,255)▪ $rgb(255,0,128)%title% $rgb(255,255,255)Album. $rgb(255,0,128)%album%$crlf())
$if($longer(%comment%,0),$get(title_and_album)$rgb(255,255,255)Comment. $rgb(255,0,128)%comment%,$get(title_and_album)$rgb(255,0,0)No comment)
$if($longer(%style%,0), $rgb(255,255,255)Style. $rgb(255,0,128)%style%, $rgb(255,0,0)No Style)
$if($longer(%genre%,0), $rgb(255,255,255)Genre. $get(genre), $rgb(255,0,0)No Genre)
 $rgb(255,255,255)Progress. $progress(%_time_elapsed_seconds%,%_time_total_seconds%,40,$rgb(255,0,128)' (◣_◢) ',$rgb(128,128,128)'-')
$rgb(0,0,0)'(◣_◢)')
Re: Foo_osd
Reply #177
Hiyas, is any chance to change the volume bar to move proportionally with the toolbar volume slider?
I think OSD bar moves from 0 → -100dB linearly so -50db is directly in the middle (if I choose minimum displayable value as -100dB), while standard slider's -50dB is very close the left edge which is natural for volume. I think this should be changed.
Here watch the cap which shows it clear:
https://www.screencast.com/t/KshPFeteI4Qv
What I wished is to remove the displayable minimum (or leave only for linear mode) and add exponential mode which always has -100dB at left edge and 0dB at right edge.
Re: Foo_osd
Reply #178
I was if wondering OSD would work with %cwb_volume% to show a muted and unmuted state such as:
$ifgreater(%cwb_volume%,-100,unmuted,muted)
Re: Foo_osd
Reply #179
Probably not.
Re: Foo_osd
Reply #181
Hah, yeah, sure. Just show me what I need to do to make it work. Because global formatting hooks haven't been a thing since 0.9.4.5.
Re: Foo_osd
Reply #182
kode54 have you any thoughts for the logarithmic/exponential mode of the volume bar? I'd really find it more suitable.
Re: Foo_osd
Reply #183
The core already reports the volume in a logarithmic fashion: In decibels. I already had to convert it back to linear to display it as a sort of percentage.
Re: Foo_osd
Reply #184
So it's not possible to change it to move proportionally with volume slider?
Re: Foo_osd
Reply #185
Hello!
how to see radio (online) tags?
Re: Foo_osd
Reply #186
ChkBox  - Strem Title ..
