Topic: Foo_osd (Read 128075 times) previous topic - next topic
Foo_osd
Little refresh - any chances for adding keyboard shortcut?
Foo_osd
lwiczek
+1
Foo_osd
1
Foo_osd
Any chance of a keyboard shortcut for the "new" version of foo_osd ??
Anybody have any workarounds other than pausing/seeking the song?
Foo_osd
A shadow effect and hotkey would be great if this is still being developed
Foo_osd
Reply #30
It would be nice if it was able to detect full screen (like popup plugin for example).
But I guess plugin is not developed anymore. I hope someone else will improve it.
Great plugin.
Foo_osd
Great plugin.
So nobody's developing it anymore?
I tried to use it but can't seem to be able to change the settings (they always come back to their default value after a message tells me "the current preset has been modified. Do you want to save the changes?", whatever I click, Yes or No.
otherwise it's a great plugin yeah!
Foo_osd
If you actually want assistance, you might want to be a bit more specific.
There are multiple tabs of values to set. Where are you having trouble.
It has been trouble free for this user.
terry
Foo_osd
Reply #33
This is a bug in the plugin. The only way to actually apply new settings is to "apply" them - just going elsewhere or clicking save will not work, because regardless of what you click in the mentioned popup, it will always discard the changes.
Foo_osd
Reply #34
would it be possible to add unicode support to the plugin?
Foo_osd
Reply #36
maybe an option to show text only on desktop?
Foo_osd
Reply #37
I like this plugin very much, but for some reason it doesn't support any ttf installed
Another great feature could be something like an "MTV-mode" where the info would popup x sec before the track ends.
Foo_osd
Reply #38
I like it too
I've made this MailTicker look for foo_osd, and thought to share (user of The Bat! may find it nice)
The font is rendered better without GDI+ (at least on my display)
'Artist :  '
$rgb(0,250,0)
%album artist%
['  [ '%album%[' ('Disc %discnumber%')']' ]']
$crlf()
'Track :  '
$rgb(0,250,0)
[$num(%tracknumber%,2) - ][%track artist% - ]%title% ' [' %length% ']'
The settings are:
Font: Segoe UI, 8pt
Default color: white
Background color: RGB 69,69,101
Transparency for background ~ 180 (or 1/4 from beginning of slider)
And do I dare to ask for keyboard shortcut (the main reason I browsed this thread)?
Foo_osd
Reply #40
this is great and i love the idea of this plugin but it only works when "overlay" is checked      otherwise it doesnt show up at all!  plz help!
Foo_osd
Reply #41
Edit:
Just checked for myself and it works fine with Foobar 1.0
Foo_osd
Reply #43
Is overlay working for you guys in DirectX games?
I'm trying to display the titles while I play World of Warcraft and while it works in regular applications and windows, it doesn't work in WoW.
I tried the regular version as well as the GDI Plus one.
My system is Win7 x64
Foo_osd
Reply #44
SICK COMPONENT!!!
thanks for the constant updates.
Foo_osd
Reply #45
Thanks for foo_osd!
There is a question: what the checkbox 'Interval update' (in foo_osd configs) means?
Thanks!..
Foo_osd
Reply #46
Thanks for foo_osd!
Thanks!..
If you have e.g. a timer showing, it will update the display dynamically.
Foo_osd
Reply #47
Got it! Thank you for explanation!..
Another one question: if there is a way to control the foo_osd visibility (switch it on or off) from external app? (I'm trying to show info using OSD only when PC is idle).
Foo_osd
Reply #48
Can we have option for popping on transition end/start?
Foo_osd
Reply #49
Hi, I periodically have mistake and crash foobar.
in failure_*.txt:
Crash location:
Module: foo_osd
Offset: 84DBh
