Topic: foo_browser (Read 352292 times) previous topic - next topic
  • pnG
foo_browser
Reply #775
I am looking to use the album panel to browse for %album artist% if present, if not %artist%. is this not the way to go?
$if3(%album artist%,%artist%,<MISSING>)
thank you
  • jbass350z
foo_browser
Reply #776
Does anyone have a copy of this file they would share?
  • marc2003
  • Developer
foo_browser
Reply #777
it's not needed. the functionality is already built into columns UI. just add some filter panels to your layout.
  • H3R3T1K
foo_browser
Reply #778
Hey guys please check this out.
I'm trying to make fb2k look like iTunes using THIS tutorial. Now it says you need foo_browser.dll. I read here it's not needed. In step 11 it tells you to add browser panels. They're not available without this plugin. I can't find a download link. Can somebody help me out plz? Thx.
  • fbuser
  • Developer
foo_browser
Reply #779
foo_browser is as outdated as the tutorial you are mentioning. You should follow the advice, which is given in the post above yours, and use the filter panels instead of the browser panels.
  • Fabio258
foo_browser
Reply #780
Hi, this is my configuration for use with 7" touchscreen lcd:
since the browser is outdated and I fear it will always be less compatible with future versions of foobar, is there a way to get tabs with linked filters (genre/album artist/artist/album so when i click a genre it change the album artist/artist/album filters) inside with the current plugins?
I've tried and searched around but without results; Many thanks to whoever can help me in some way.
Fabio
  • allerlei
foo_browser
Reply #781
Realy nice - which kind of display is used in your scenario?
  • Fabio258
foo_browser
Reply #782
It's a carpc vga touchscreen monitor like this: http://www.cartft.com/catalog/il/442
  • allerlei
foo_browser
Reply #783
Thanks - quite expensive, isn't it?
  • odyssey
foo_browser
Reply #784
For all those that won't read the thread here goes:
This (foo_browser) component is obsolete as ColumnsUI already includes a panel with the exact same function. It's called "Filter Panel" instead of this "Browser Panel".
...now can we close this thread?
  • Fabio258
foo_browser
Reply #785
I've tried to obtain linked TABBED filter panels  with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread...
Fabio
  • Fabio258
foo_browser
Reply #786
Yes, but you can find a lot of similar more inexpensive monitors (e.g. on ebay)
Fabio
  • Hamallainen
foo_browser
Reply #787
I've tried to obtain linked TABBED filter panels  with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread...  Thanks  Fabio
In Filter preference page, set 'Filter precedence' to 'By field list above'. It works
  • Fabio258
foo_browser
Reply #788
Many thanks Hamallainen, it works!
Fabio
  • ExUser
  • Read-only
foo_browser
Reply #789
<xiphmont> OK
