Topic: foo_browser (Read 434016 times) previous topic - next topic
foo_browser
Reply #775
I am looking to use the album panel to browse for %album artist% if present, if not %artist%. is this not the way to go?
$if3(%album artist%,%artist%,<MISSING>)
thank you
foo_browser
Reply #776
Does anyone have a copy of this file they would share?
foo_browser
Reply #777
it's not needed. the functionality is already built into columns UI. just add some filter panels to your layout.
foo_browser
Reply #778
Hey guys please check this out.
I'm trying to make fb2k look like iTunes using THIS tutorial. Now it says you need foo_browser.dll. I read here it's not needed. In step 11 it tells you to add browser panels. They're not available without this plugin. I can't find a download link. Can somebody help me out plz? Thx.
foo_browser
Reply #779
foo_browser is as outdated as the tutorial you are mentioning. You should follow the advice, which is given in the post above yours, and use the filter panels instead of the browser panels.
foo_browser
Reply #780
Hi, this is my configuration for use with 7" touchscreen lcd:
since the browser is outdated and I fear it will always be less compatible with future versions of foobar, is there a way to get tabs with linked filters (genre/album artist/artist/album so when i click a genre it change the album artist/artist/album filters) inside with the current plugins?
I've tried and searched around but without results; Many thanks to whoever can help me in some way.
Fabio
foo_browser
Reply #784
For all those that won't read the thread here goes:
This (foo_browser) component is obsolete as ColumnsUI already includes a panel with the exact same function. It's called "Filter Panel" instead of this "Browser Panel".
...now can we close this thread?
foo_browser
Reply #785
I've tried to obtain linked TABBED filter panels  with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread...
Fabio
foo_browser
Reply #787
I've tried to obtain linked TABBED filter panels  with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread...  Thanks  Fabio
In Filter preference page, set 'Filter precedence' to 'By field list above'. It works
foo_browser
Reply #788
Many thanks Hamallainen, it works!
Fabio
foo_browser
Reply #789
<xiphmont> OK
