Topic: foo_browser (Read 433959 times) previous topic - next topic
foo_browser
Reply #450
I confirm too!! 1.1.9 working like a charm
thank you !!
foo_browser
Reply #451
just remaking the question
someone answer me plz =)
to chose the artist what i want to listen i use the foo_browser plugin
how can i make the name of artists go to the right of the browser colum???
(like when i chose the alignment: right to one colun (like the title colun for exemple))
foo_browser
Reply #452
I tried playing around a bit with the $tab() function to try and make things right alligned as this function normally does this sort of thing however it did not work. I assume, therefore, that there are considerable TAGZ limitations with this panel.  Can anyone suggest an alternative approach?
Again, I really love using these panels to dynamically filter my active playlist.. keep up the good work!
foo_browser
Reply #453
The new version works fine. The only issue I have with it is that it resets the playlist when foobar loads (with the old version, foobar would remember the track I had last played and the scroll position. With this version, foobar remembers the scroll position of the playlist but after browser loads it scrolls to the top)
Edit: Here's a screen shot of another problem I have, browser ignoring the sort string:
foo_browser
Reply #454
@david_dl
I saw the setting for the doubleclick and i must say: Now i understand your request for a single click action!
A very interesting idea i am going to test!
foo_browser
Reply #455
Have you tried 1.1.9?  It seems to sort correclty for me, using your original string you posted.
There used to be a link to my website here.
foo_browser
Reply #456
Tried 1.1.9 and nothing crashed. (with dragging or adding 3panel at once)
It seems more stable.
foo_browser
Reply #457
@david_dl
I must say that a single click action for the browser makes sense: you can improve david_dl's idea to make the browser a powerful filter for the library playlist of playlist tree. Also some people could be interested who don't need the browser playlist but use the browser more for building up the active playlist.
So let me bump his request!
foo_browser
Reply #458
foo_browser
Reply #462
Hi, I am using 1.1.9. After half an hour of experimentation, I discovered that the sorting doesn't work when the view is called 'Artist'. However if I call it anything else it works fine. This is very strange and unpredictable behaviour, however I'm happy now, it's working how I like it.
foo_browser
Reply #463
Sorry, but this is not possible in the current version.
foo_browser
Reply #464
Cwbowrons account is suspended until monday so that he can't give any replies anymore. Look into his forum:
My suspension has been lifted.
foo_browser
Reply #465
Welcome back, Chris! I'm glad to see that Version 1.1.9 is working well. I was happy to help out with testing. Thanks again for sharing foo-browser.
Surf's Up!
"Columnated Ruins Domino"
foo_browser
Reply #466
Some weeks ago i asked in your forum for the oppurtinity to define the dependencies of the panels by their order in foobar instead of order in the preferences. As you explained that is not possible because the panels don't know the order. Look here: http://bowron.us/smf/index.php?topic=229.0
Wouldn't it then be possible to define the order of the panels already in ColumnsUi by designing the layout. I mean something like that:
---Horizontal splitter
          Browser panel 1
          Browser panel 2
          Browser panel 3
Sure, that would mean to have an limited number of panels but on the other side if you balance what could be more useful i would say that i can't imagine that somebody needs more than 7 or 8 panels.
foo_browser
Reply #467
Hello,
I'm using fb2k 0.9.1, columnsUI 0.1.3 beta 1v5 and browser 1.1.9.
When adding the browserpanel to my layout, I get the following message in the console:
exception while reading config:: Unsupported format or corrupted file
As soon as I click into the panel, foobar crashes with this message:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00C12B2Ch
Access violation, operation: read, address: 00000018h
Call path:
entry=>app_mainloop
Code bytes (00C12B2Ch):
00C12AECh:  88 12 C4 00 A3 8C 12 C4 00 A3 90 12 C4 00 8B 4F
00C12AFCh:  0C 50 89 0D 70 12 C4 00 C7 05 6C 12 C4 00 04 00
00C12B0Ch:  00 00 8B 17 68 4B 10 00 00 52 FF 15 30 11 C3 00
00C12B1Ch:  85 C0 0F 84 27 03 00 00 A1 8C 12 C4 00 8B 55 08
00C12B2Ch:  8B 48 18 6A 00 6A 01 68 13 01 00 00 52 89 0D BC
00C12B3Ch:  11 C4 00 A3 C0 11 C4 00 FF 15 9C 11 C3 00 E9 FC
00C12B4Ch:  02 00 00 33 C0 89 44 24 58 89 44 24 5C 89 44 24
00C12B5Ch:  60 C7 44 24 54 F0 34 C3 00 C7 44 24 70 03 00 00
Stack (0012F3DCh):
0012F3BCh:  0162DCDC 7C9D93A0 77F443DD 7C9D93A0
0012F3CCh:  00000004 00000000 0162D1E8 00000000
0012F3DCh:  7D0A2A98 0012F4BC 00C126A0 00000000
0012F3ECh:  00000000 0015F460 00000000 00000001
0012F3FCh:  00000208 00000000 0012F82C 773A78E2
0012F40Ch:  00000000 00000000 0012F420 773A790A
0012F41Ch:  00000002 00000000 77D18734 02C40646
0012F42Ch:  00000020 004F0634 00C126A0 03FC7220
0012F43Ch:  DCBAABCD 00000000 0012F4DC 00C2F3F9
0012F44Ch:  FFFFFFFF 0000004E 0012F480 77D18734
0012F45Ch:  0346068C 0000004E 00000000 0012F6EC
0012F46Ch:  00C126A0 DCBAABCD 00000000 0012F4BC
0012F47Ch:  00C126A0 0012F4EC 77D2418D 00C126A0
0012F48Ch:  0346068C 0000004E 00000000 0012F6EC
0012F49Ch:  0000004E 0346068C 007F9208 00000014
0012F4ACh:  00000001 00000000 00000000 00000010
0012F4BCh:  00000000 7741F866 00000000 00000001
0012F4CCh:  00000000 00000000 0012F49C 0012F000
0012F4DCh:  0012F5D4 77D40467 77D241B0 00000000
0012F4ECh:  0012F534 77D23FD9 00000000 00C126A0
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000001, EDX: 0346068C
ESI: 00C126A0, EDI: 0012F6EC, EBP: 0012F454, ESP: 0012F3DC
Crash location: "foo_browser", loaded at 00C10000h - 00C49000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004E0000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 773A0000h - 774A2000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1EF000h
ole32                            loaded at 774B0000h - 775ED000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
LPK                              loaded at 62E10000h - 62E19000h
USP10                            loaded at 75790000h - 757FB000h
uxtheme                          loaded at 5B0F0000h - 5B128000h
MSCTF                            loaded at 746A0000h - 746EB000h
msctfime                        loaded at 75250000h - 7527E000h
foo_abx                          loaded at 00A50000h - 00A84000h
foo_ac3                          loaded at 00AA0000h - 00ACC000h
foo_albumlist                    loaded at 00AF0000h - 00B31000h
foo_autoplaylist                loaded at 00B60000h - 00B92000h
foo_bitcompare                  loaded at 00BC0000h - 00BE6000h
foo_browser                      loaded at 00C10000h - 00C49000h
foo_cdda                        loaded at 00C70000h - 00C9D000h
foo_common                      loaded at 00CC0000h - 00CFA000h
foo_converter                    loaded at 00D20000h - 00D81000h
foo_cwb_hooks                    loaded at 00DB0000h - 00DB9000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dbsearch                    loaded at 00DE0000h - 00E3C000h
foo_dsp_atsurround              loaded at 00E60000h - 00F55000h
foo_dsp_dolbyhp                  loaded at 01080000h - 010A1000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_dsp_std                      loaded at 010C0000h - 010FF000h
foo_dts                          loaded at 01120000h - 0116C000h
foo_freedb2                      loaded at 01190000h - 011D0000h
foo_fullscreen                  loaded at 011F0000h - 0120B000h
foo_infobox                      loaded at 01230000h - 0126F000h
foo_input_matroska              loaded at 01290000h - 01316000h
foo_input_shorten                loaded at 01340000h - 0136E000h
foo_input_std                    loaded at 01390000h - 014A3000h
foo_lnk                          loaded at 014D0000h - 014E9000h
foo_masstag                      loaded at 01510000h - 01560000h
foo_out_ks                      loaded at 01580000h - 015AB000h
SETUPAPI                        loaded at 778F0000h - 779E4000h
foo_playcount                    loaded at 015D0000h - 015F8000h
foo_playlist_manager            loaded at 01620000h - 01666000h
foo_pqview                      loaded at 01690000h - 016AC000h
foo_prettypop                    loaded at 016D0000h - 0171E000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_random                      loaded at 03BB0000h - 03BEF000h
foo_rgscan                      loaded at 03C90000h - 03CD4000h
foo_sendtodevice                loaded at 03D00000h - 03D13000h
foo_tradersfriend                loaded at 03D30000h - 03D6D000h
foo_uie_albumart                loaded at 03D90000h - 03DC2000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
foo_uie_albumlist                loaded at 03E00000h - 03E3F000h
foo_uie_console                  loaded at 03E60000h - 03E7C000h
foo_uie_explorer                loaded at 03EA0000h - 03EDD000h
foo_uie_quicksearch              loaded at 03F00000h - 03F41000h
foo_uie_trackinfo                loaded at 03F70000h - 03F9E000h
foo_ui_columns                  loaded at 03FC0000h - 0405B000h
foo_ui_std                      loaded at 04080000h - 040D7000h
foo_unpack                      loaded at 04100000h - 0412E000h
foo_utils                        loaded at 04150000h - 04189000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E3000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
appHelp                          loaded at 77B10000h - 77B32000h
cscui                            loaded at 779F0000h - 77A46000h
CSCDLL                          loaded at 765A0000h - 765BD000h
MPR                              loaded at 71A80000h - 71A92000h
drprov                          loaded at 75F00000h - 75F07000h
ntlanman                        loaded at 71B90000h - 71B9E000h
NETUI0                          loaded at 71C50000h - 71C67000h
NETUI1                          loaded at 71C10000h - 71C50000h
NETAPI32                        loaded at 597D0000h - 59824000h
NETRAP                          loaded at 71C00000h - 71C07000h
SAMLIB                          loaded at 71B70000h - 71B83000h
davclnt                          loaded at 75F10000h - 75F19000h
dciman32                        loaded at 73B30000h - 73B36000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
DolbyHph                        loaded at 0A3D0000h - 0A4CC000h
mswsock                          loaded at 719B0000h - 719F0000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
imagehlp                        loaded at 76C50000h - 76C78000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
Stack dump analysis:
Address: 7D0A2A98h, location: "SHELL32", loaded at 7C9D0000h - 7D1EF000h
Address: 00C126A0h, location: "foo_browser", loaded at 00C10000h - 00C49000h
Address: 773A78E2h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "DllInstall" (+000015F5h)
Address: 773A790Ah, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "DllInstall" (+0000161Dh)
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 03FC7220h, location: "foo_ui_columns", loaded at 03FC0000h - 0405B000h
Address: 00C2F3F9h, location: "foo_browser", loaded at 00C10000h - 00C49000h
Address: 77D2418Dh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7741F866h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "Ordinal389" (+000028CBh)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D241B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D23FD9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D241E2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D184FCh, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D185A4h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D24204h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B89Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetParent" (+0000016Ch)
Address: 77D1B903h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SendMessageW" (+00000049h)
Address: 773BAF7Bh, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 77D1882Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000163h)
Address: 773E35E5h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+00000274h)
Address: 773EC084h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+00008D13h)
Address: 773EC57Dh, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000920Ch)
Address: 773EE78Bh, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000B41Ah)
Address: 773EFCEAh, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000C979h)
Address: 773EFF77h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000CC06h)
Address: 773F02C2h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000CF51h)
Address: 773F0CF5h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000D984h)
Address: 773F049Eh, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "FlatSB_SetScrollProp" (+0000D12Dh)
Address: 7C80262Ah, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 77D1EB3Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 746B0E6Ch, location: "MSCTF", loaded at 746A0000h - 746EB000h
Symbol: "TF_UninitSystem" (+00000A03h)
Address: 746B0E71h, location: "MSCTF", loaded at 746A0000h - 746EB000h
Symbol: "TF_UninitSystem" (+00000A08h)
Address: 746DE548h, location: "MSCTF", loaded at 746A0000h - 746EB000h
Address: 746B0E78h, location: "MSCTF", loaded at 746A0000h - 746EB000h
Symbol: "TF_UninitSystem" (+00000A0Fh)
Address: 77D1EAF2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+000000C3h)
Address: 77D1EA9Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 77D1EAADh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 77D2110Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PostThreadMessageA" (+00000032h)
Address: 77D1EAB0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 77D1EBF3h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 77D1EC03h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 746B0DE9h, location: "MSCTF", loaded at 746A0000h - 746EB000h
Symbol: "TF_UninitSystem" (+00000980h)
Address: 77D1EAC1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 77D3E185h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 77D3E162h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 77D189CDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 004CC810h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF0D4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D189F0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D18A10h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042B63Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D1DAEAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042C0C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF7ACh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C920E12h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000383h)
Address: 0046051Ch, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B20F8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004D11C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004D12A0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C927CB7h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 1000D533h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000D469h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10003C90h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+00000030h)
Address: 10003C9Eh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+0000003Eh)
Address: 7C921B09h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 004D1230h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483574h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 0048991Fh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00488720h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B05C8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 10002D77h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 0049F7FBh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042C29Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004CE2A8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00489035h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483409h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483403h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A3045h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049F9EFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00487605h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0162D0B8h, location: "foo_playlist_manager", loaded at 01620000h - 01666000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0048766Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004E0000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
Common services 0.1  (foo_common)
Standard input array 1.0  (foo_input_std)
Live show tagger 0.6.1  (foo_tradersfriend)
Album Art Panel 0.175  (foo_uie_albumart)
Kernel Streaming Output 1.2.1  (foo_out_ks)
Send to Device 1.0.4 [May 17 2006 - 13:21:17]  (foo_sendtodevice)
Shell link resolver 1.1  (foo_lnk)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Track info panel 0.8  (foo_uie_trackinfo)
MPEG-4 AAC decoder 2.1  (foo_input_std)
Special file info box v2.0.1  (foo_infobox)
Default User Interface 0.9acc  (foo_ui_std)
Binary comparator 1.0  (foo_bitcompare)
CD Audio decoder 2.0  (foo_cdda)
Converter 1.0  (foo_converter)
Play Count 1.9.2  (foo_playcount)
Music Browser 1.1.9 [Jun  1 2006 - 16:56:09]  (foo_browser)
RAR reader 1.1  (foo_unpack)
Database search 1.3.1 beta 11  (foo_dbsearch)
Matroska Plugin 0.9.0.7  (foo_input_matroska)
Shorten decoder 0.4.2a  (foo_input_shorten)
freedb tagger v0.5.1  (foo_freedb2)
Album list panel 0.2.1 beta 3  (foo_uie_albumlist)
AC3 decoder 0.7  (foo_ac3)
ABX comparator 1.3  (foo_abx)
Pretty Popup 1.2.1  (foo_prettypop)
Playlist Manager 1.0  (foo_playlist_manager)
ReplayGain Scanner 2.0  (foo_rgscan)
FLAC decoder 1.1.0  (foo_input_std)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Album List 3.2.0  (foo_albumlist)
Playlist tools 0.5.6  (foo_utils)
ATSurround Processor 0.1.3  (foo_dsp_atsurround)
Standard DSP array 1.0  (foo_dsp_std)
Fullscreen 0.3.1  (foo_fullscreen)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
DTS decoder 0.1  (foo_dts)
Randomized playlist entry 1.2.3  (foo_random)
Quick Search Toolbar 2.2  (foo_uie_quicksearch)
Masstagger 1.5  (foo_masstag)
Console panel 0.2  (foo_uie_console)
ZIP/GZIP reader 1.0  (foo_unpack)
cwbowron's hooks 1.0.1 [Apr 13 2006 - 14:30:00]  (foo_cwb_hooks)
So what should I do?
foo_browser
Reply #468
i have one question =)
can i see the musics in one playlist and play in another playlist??
because ever i was searching for some music and the music what is playing end and start one what i dont want to listen
or sometimes i just want to see my musics and i change but i dont want it
i just want to see the musics
and leave the playlist with the artist what i chose before =)
(sorry for a bad english...maybe you will not understand ^^...but try plz =P)
thx and bb =)
foo_browser
Reply #469
What kind of string would I need if i wanted it to display Album Names in order of the year, but still just display the album names? Any help would be appreciated.
foo_browser
Reply #470
Release 1.1.10
* updated to latest SDK and related fixes
* faster row population using precompiled title formatting
    o works only on non %<tag>% formats
    o .26s vs .09s in my album panel
Not a lot of changes, but the speed increase might be useful to many people.
Repeat, the speed increase does not effect formats that use the %<tag>% mult tags
foo_browser
Reply #471
The main reason I didn't use it before... Let's try again
I'm not sure I understand this very well (as said... I didn't really used your plugin to much). Could elaborate a bit more? Thanks.
foo_browser
Reply #472
If your browser panel formatting includes the use of %<artist>% or some other use of %<tag>%, you wont see much a speed improvement.  But if the format is %artist% it should see a pretty big speed improvement.
foo_browser
Reply #473
the dll in the zip archive is dated 01.06.06 and seems identical with my current version
