Topic: What happened to uSHFileOperation? (Read 3267 times) previous topic - next topic
Hi!
I'm the author of foo_massdelete. I will try in the (near hopefully) future to port it to v0.9, but I'm really a little bit lost. For now, I have 2 questions, if anyone knows:
-What happened to uSHFileOperation and string_list_nulldelimited? Will they be included in a later SDK?
-How can I get a bitmask of the currently selected items in the visible playlist?
My knowledge of C++ is very limited btw, I'm into C# mostly...
Does anyone know of any plugin's source code that's available for v0.9?
If I can't port it, I'll eventually post the source code...
Thanks in advance!
MODS: Please move this to "Development" and delete this line, I screwed up.
Hi!
Can you open the source code when porting is done?
uSHFileOperation and string_list_nulldelimited were removed. The best idea would be to create your own helper class using array_t<TCHAR> and string_os_from_utf8 and call SHFileOperation directly.
To get a bitmask of the selected items, use this:
static_api_ptr_t<playlist_manager> pm;
t_size playlist = ...; // index of playlist, use pm->get_active_playlist() for active playlist.
bit_array_bittable mask(pm->playlist_get_item_count(playlist));
pm->playlist_get_selection_mask(playlist, mask);
In case you just want the selected items, replace the last two lines with:
metadb_handle_list items;
pm->playlist_get_selected_items(playlist, items);
I'm currently porting the component tutorial to 0.9; it should be available within the next days (hopefully tomorrow).
@foosion: Thanks very much, I'm anxiously waiting for your tutorial!
@$ergi0: I might just post the source code, if I'm not able to port it.
       I haven't quite followed the development up to v0.9, so I didn't know that File operations->Delete files is now available!! I find no reason to port it to v0.9. If anyone wants the source code, pm me to e-mail it to him.
