Topic: foo_sendtodevice (Read 180787 times) previous topic - next topic
foo_sendtodevice
Reply #150
Thanks for the plugin, I like that I can copy files on the fly, without being prompted with a preview window. But could you create a variable which would return the free space on that device? I'd like to display that in FB, without having to open an Explorer window.
foo_sendtodevice
Reply #151
Hey, I would like to give you some feedback und post some requests in order to improve this plugin:
Additional settings for the cover-image should be added
- e.g. resizing to different resolutions (100x100, 200x200 etc.) and
- possibility to rename the cover using %album%, %artist% strings
What do you think? This would go well with my MP3-Player.
foo_sendtodevice
Reply #152
Where can I download this component?
foo_sendtodevice
Reply #153
Hello there !
I am exactly in the same situation, i can't find that compoment... Can someone could upload it again, that would be great !
foo_sendtodevice
Reply #154
Look here
foo_sendtodevice
Reply #155
That is the exact link. Thank you very much !!!
foo_sendtodevice
Reply #156
Sendtodevice is great. But it seems has some problem with transcoding to mp3.
I tried two send 1 ape format sound to my device, and I can only hear noise from the target mp3.
After checking, I found when sendtodevice create the temprate wav file for lame to compress, it missed the head of the wave file. Is anybody else had the same issue? or it's only happen on my 0.9.5.4 and 1.1.2 sendtodevice?
When can I found older sendtodevice plugin so I can try?
foo_sendtodevice
Reply #157
I have the same issue (1.1.2 with foobar 0.9.5.6) so I have to convert non-mp3 files manually
foo_sendtodevice
Reply #158
This plugin has a lot of potential...is it still supported? I'm getting the problem with static mp3s also.
Too bad I don't have an ipod else I could use the other plugin
foo_sendtodevice
Reply #159
i also would like to see this plugin further supported. im using it in Foobar 0.9.6.1, copying mp3's is fine but also getting the same problem as the preious posts with the noise conversions.
foo_sendtodevice
Reply #160
There is a way to use Sony / other players natively in MTP mode and therefore this plugin:
Control Panel>> System>> Hardware>> Device Manager
1). Search for Sony Walkman (or other player) in the list of equipment - if you've already plug it in Win XP installed, we have designated it as MTP device
2) press "Update Driver" button
3) the question whether the computer has to connect to the network select "not this time"
4) select "Choose driver from a specific location"
5) select "Do not Search - I will choose the driver to install myself"
6) in the "Show compatible hardware" Windows shows you two options
> you have a choice for drivers: "MTP Device" or "USB Mass Storage Device"
> Choose the second one
7) Now U can use your player as UMS device (with a proper drive letter)
I hope this helps, in my case it was more than enough after hours of seraching
foo_sendtodevice
Reply #161
I'd like to second this request!  As a suggestion for enhancement, would it be possible to configure which extensions would be converted?  It would be ideal to take advantage of ogg and flac capability on some newer DAPs.  Thanks!
foo_sendtodevice
Reply #162
Amazing!! Thank's a lot!!!
foo_sendtodevice
Reply #163
I too am having no luck converting to mp3 using lame 3.98.2, foobar 0.9.6.2 and foo_sendtodevice 1.1.2.  I too hope the developer would revisit this great addition to foobar.
foo_sendtodevice
Reply #164
Oddly enough, the transcoding works properly with lame 3.97.
foo_sendtodevice
Reply #165
I thought that perhaps there was some conflict between foo_sendtodevice and lame 3.98.2 but I was not able to find lame 3.97 anywhere.  Do you have a link for where lame 3.97 is available?
Found it: http://www.oldversion.com/LAME-MP3-Encoder.html
I can confirm that 3.97 definitely works with foo_sendtodevice 1.1.2 and foobar 0.9.6.2.
edit: added link.
foo_sendtodevice
Reply #166
Great plugin, and very usefull to transfer files to my usb memmory for listening on my car audio and other devices. But I would like to have the files exported to a folder named after the playlist. For example:
F:\%playlistname%\%track% %artist% - %title%
Also how can I do to avoid the track "item" when there is no track number (an "if" instruction)
And finally, where can I find how make my own combination of "track tags"?
tx.
foo_sendtodevice
Reply #167
The playlist name I'm afraid it can't be retrieved.
Square brackets is what you need: [%tracknumber%] shows the tracknumber only if it's present.
If I understood, title formatting reference should be what you're searching for.
foo_sendtodevice
Reply #168
Thanks Novembre, but is there, at least, a way to name each playlist... let's say pl1, pl2... and so?
By the way tx for the tip for the track number, much simpler than my "if" aproach.
foo_sendtodevice
Reply #170
it doesnt seem to work here.. lame 3.98.2
Could not update tags (Object not found) on:
"C:\DOCUME~1\BULL~1\LOCALS~1\Temp\CWB47E.tmp.mp3"
foo_sendtodevice
Reply #171
Does anyone have this plug in u/l'd anywhere. Thanks.
foo_sendtodevice
Reply #172
http://bazquux.com/wiki/Foobar2000
As of May 2009, I'm taking down all foobar2000 related files.
  As of May 2008, I will no longer be developing foobar2000 components.
I no longer wish to contribute my time to a closed source, single platform app.
Also, certain actions by the foobar2000 developers have lead to my no
longer wishing to contribute.  These include removing features utilized by
developers and users because they dislike they way they are  being used and
allowing only an elite few access to new API features.
Thank you to loyal users over the past years.
If you are a developer and are interested in taking over
development of one of my components, please email me at
chris SQUIGGLE bowron SLAM us.
foo_sendtodevice
Reply #173
The component author has now decided to remove all his Foobar components, including the sendtodevice plugin, unfortunately    This is one feature that I would love Foobar to have, unless I'm missing something (I'm a new user and loving Foobar, glad I converted from Winamp).  I'm pretty much a newbie, is there any other way I could send songs to my mp3 player?  Thanks for any help!
foo_sendtodevice
Reply #174
+1
Anybody have a copy they could kindly upload?
Moderation: Removed useless full quote of the preceding post.
