Topic: foo_sendtodevice (Read 180781 times) previous topic - next topic
foo_sendtodevice
Reply #101
bug with folder names including brakets "[]"?
recreate:
- name a folder "[folder 01]"
- inside create another folder "folder 02" without brakets
- point foo_sendtodevice to that folder (D:\[folder 01]\folder 02\)
- send a file to "folder 02"
> in my case foo_sendtodevice created a new folder in the root directory  ignoring the "[folder 01]" (D:\folder 02\filename.ext).
Can anyone confirm this?
JD
foo_sendtodevice
Reply #102
recreate:
JD
I can confirm this...
then, I've tried with D:\'['folder1']'\folder2\filename.ext and it works like you want.
foo_sendtodevice
Reply #103
recreate:
JD
Well. It is perfectly normal behavior so just do as kabuki said.
(in foobar titleformatting brackets means "show this text if the tags that are between the brackets exists", in your case no tags so no text)
foo_sendtodevice
Reply #104
Hi cwbowron,
Is it possible to create scripts that convert APE tags into ID3V2 tags on the destination files? Would be great for the mp3 files managed by foobar that have no readable meta data in the mp3 players...
foo_sendtodevice
Reply #105
With using Y:\%artist%\%album%\%tracknumber% - %title%.$ext(%_path%) and trying to send multiple files foo_sendtodevice first creates a new directory in %artist\%album% (i.e. Linkin Park\Meteora) that is called for example "01 - Foreword.ogg". That is annoying.
What I want to have is:
Create for each album a new folder. Put the songs in the respective folders.
What am I doing wrong?
foo_sendtodevice
Reply #106
There could be a problem with some of the titles containing the | character.
There used to be a link to my website here.
foo_sendtodevice
Reply #107
Do you need more information? Can I help somehow?
Apart from that: Are you willing to improve this?
foo_sendtodevice
Reply #108
Well, if its the | problem, its been fixed in the dev version, but I havent released a new version lately.
And if it is that problem, just wrap your whole target device inside a replace function like this: $replace(old_string,|,-)
foo_sendtodevice
Reply #109
This is actually an unecessary plugin if you use copy, move or rename feature this can be set up to do the very same thing, I use foobar to copy my music to my Rio Carbon, it works a treat and you can save the preset.
:Foobar 2000:
:MPC --standard:
:iRiver H320 Rockboxed:
foo_sendtodevice
Reply #110
Can copy, move or rename output a m3u along with the files or transcoded to mp3 on the fly?
foo_sendtodevice
Reply #111
sendtodevice copies the files in the same order as they are sorted in the playlist. Since 0.9 the f2k build in copy funktion handles the files in alphabetical order. My old mp3 porty and my Nokia mobile both play the files in the order they where copied to the flash storage.
Just because you don't need it, this plugin is not unnecessary!
foo_sendtodevice
Reply #112
Sorry guys didn't realise it actually transcodes as well, seems like a good plugin  sorry
:Foobar 2000:
:MPC --standard:
foo_sendtodevice
Reply #113
under feature request on your website you list copying of albumart if your going to add that to future versions will you allow the user to set the name/size/format or just copy the art as is?
foo_sendtodevice
Reply #114
Is any way to use environment variables to set default mp3 conversion location?
Example:
%UserProfile%\Desktop\Music\Conversion
Thx!
foo_sendtodevice
Reply #115
Would there be a way to export a certain tag(s) to an external file?  Clearly if you are able to transcode then it would be trivial to pass other arguments for output.
Basically, I have a portable mp3 player that supports scrolling lyrics, but cannot read them when they are embedded in file tags, but only when it exists in an external *.lrc file.  I do not want to store lyrics in external files on my master audio library, so only want to pull that field out upon copying to my portable device.
Any suggestions?
foo_sendtodevice
Reply #116
I have a HUGE feature request - support for devices that doesn't get a drive letter. My Creative Zen Touch doesn't get a drive letter, and is instead only listed as the name I've configured it with. I think it has to do with the PlaysForSure firmware. Is this possible at all? I see it's been up before...
foo_sendtodevice
Reply #117
I have a request:
It would be pretty cool if you plugin could check if marked files have a special Codec and settings.
Maybe all files which are not mp3, V2 could be converted to the MP3-Player folder?
It would be cool if you could set those settings.
foo_sendtodevice
Reply #118
I created a button to send my files to my mp3-player.
But somehow it just works for the active file not for selected files.
Here's my code:
//added MP3-Player option
            $button2(10,$eval($getpvar(TopAlign1)+$getpvar(TopAlign2)+110),0,0,180,20,
            '$font($getpvar(font),$getpvar(fontsize),$getpvar(shcolor),$getpvar(color1))$ifequal($getpvar(lang),1,Send Active File to Mp3-Player,Insert Spanish Text here)',
            '$font($getpvar(font),$getpvar(fontsize),$getpvar(shcolor2),$getpvar(color2))$ifequal($getpvar(lang),1,Send Active File to Mp3-Player,Insert Spanish Text here)',Send to Device/Default,TOOLTIP:""
foo_sendtodevice
Reply #119
Hi!
I might be looking into the MTP issue the next days. I won't make any promises - but if somebody else tries to do the same thing: Please contact me, maybe we can learn from each other
foo_sendtodevice
Reply #120
Hi!
So now I have looked into the MTP issue for a few hours... It is WAY more complicated than usual file copying.
I see no justification for putting so much effort into something for achieving such a simple goal (like copying a file from A to B).
I can see why many manufacturers prefer the MTP approach. It takes the burden of tag scanning, cover art, folder traversing, playlist parsing, etc. from the player to the application.
I can also see now, why MTP is not especially liked around here
foo_sendtodevice
Reply #121
Hi!
Bad news then....
I was really exited when I saw your first post.
Question: is this so much different from the iPod?. There is a foo_pod plugin available, thay may be help tfor inspiration.
foo_sendtodevice
Reply #122
Great plugin !! I use it to copy and transcode files to my PSP.
Minor request: make the call to lame for transcode not block foobar UI
foo_sendtodevice
Reply #123
cwbowron, would it be possible to add an option to copy the picture from the folder to the device?
I used this external application http://www.anythingbutipod.com/forum/showthread.php?t=7228 but will simplify dramatically the process to have it integrated.
Basic idea is to copy folder.jpg to same folder where music is been copied.
foo_sendtodevice
Reply #124
Release 1.1.1
    * replace | with _ to avoid problems
    * copy album art option - contribution from Hanno Stock
