Topic: Matroska support (Read 47542 times) previous topic - next topic
  • cacko
Matroska support
Reply #50
Hi, the latest foo_input_matroska-0.9.2.0.zip is breaking somehow foobar2000. When I drag on add folder from the content menu, It's just adds the folder name, no the files. Reverting to the previous verions of foo_input_matroska fixes the problem.
More on this issue can be found here.
Could it be fixed.
  • Last Edit: 26 October, 2006, 04:40:10 PM by cacko
  • vlada
Matroska support
Reply #51
I have the same problem with the latest Matroska plugin.
  • szczepl
Matroska support
Reply #52
I have a problem with foo_input_matroska...
What I want to do:
- merge whole album which is stored as mp3 files
- merge cuesheet created with fb2k cuesheet creator
into one MKA file.
And: cuesheet loads ok, all files are playable via it in fb2k
But if I merge mp3s, and cuesheet into MKA file with mkvtoolnix,
fb2k loads file, but there is no duration time at tracks but last track.
And for this reason only the last track is playable
I think it is a bug in foo_input_matroska...
I've updated to last versions of mkvtoolnix and cuesheet creator.
Please, help.
  • Slotos
Matroska support
Reply #53
Your album is a bunch of files, not a single file, am I right?
Matroska counts different audio files in container as different versions of one audio track. It's a video container initially after all. At least that is what I've figured out trying to do the same thing as you. Maybe there is a workaround but it will be a hack, I suppose.
Sharing delusions since 1991.
  • vlada
Matroska support
Reply #54
No, if you use the Append function of MKVToolnix (btw. version 1.80 has just been released), then it will be one audio stream only. I created some MKA albums from more MP3 files and it worked perfectly. But all files need to have the same format.
szczepl
Have you used the Append function? How does your file play in MPC or VLC?
  • Slotos
Matroska support
Reply #55
Oh, thanks for the info. Btw, will it work with VBR files?
  • vlada
Matroska support
Reply #56
I've never tried VBR, but it should work fine. I think it even shouldn't be a problem to join files with different bitrate. But I think you need to keep resolution (bit depth), sampling frequency and compression format for one track.
  • Slotos
Matroska support
Reply #57
Thanks again. (Gone muxing ^^)
  • vlada
Matroska support
Reply #58
Any solution for the problem me and cacko mentioned? Thank you.
  • drbeachboy
Matroska support
Reply #59
szczepl
vlada,
If the files are appended, then can the foobar2000 created cuesheet be added in the "Global" setting of mmg? Or will the cuesheet need some manual amending for it to work properly?
Surf's Up!
"Columnated Ruins Domino"
  • vlada
Matroska support
Reply #60
Just append the files and use the cuesheet to create chapters. It should work.
  • vlada
Matroska support
Reply #61
Does anybody know what's going on? There is a serious bug in the last version and unfortunately there haven't been any update for quite a long time :-(
I would be very sad if Matroska support in fb2k was abandoned.
  • Liisachan
  • Members (Donating)
Matroska support
Reply #62
hi, vlada
0.9.2.0 was out on Oct 12, 2006, then on Oct 20 (local time) ayana posted an article about current limitations of foo_input_matroska in his blog. His fb2k-related directory was last updated on Nov 16 (local time).
According to his blog, it seems that he'll soon graduate from his univ and will start working for a company, no more a student, he moved too. maybe he's now (and will be) a bit busier, but I do hope he'll be able to go on working for his plugins too.
  • Kohlrabi
  • Global Moderator
Matroska support
Reply #63
I just found that http://dl.matroska.org/downloads/foobar2000/ has a new version of input_matroska, which fixes the library-crash and the folder-drag-and-drop-bug
many thanks to ayana for that!
  • vlada
Matroska support
Reply #64
Great news! Many thanks for the fix.
