Topic: AAC 48kbps test - results (Read 33825 times) previous topic - next topic
Statistical tie = we can't say anything with 95% certainty.
You can nevertheless conclude that 1) 3GPP code doesn't terribly suck (if it had, we would probably have  been able to conclude with >95% certainty that it did) 2) The odds are better that Nero > CT than the reverse (but again, nowhere near 95%, though).
Overall it is safe to say that the tested Nero encoders are quite competitive against Coding Technologies ones, and 3GPP reference code is not that bad.
All the  contenders are statistically tied
whats up with that? (not that i really understand all this stats math.)
[a href="index.php?act=findpost&pid=375526"][{POST_SNAPBACK}][/a]
Nero and CT are tied => they are providing a similar quality level, and so Nero is competitive against CT, but CT is also competitive against Nero. (unless I made a language mistake)
Would it be sensible to calculate some kind of variance number for the encoders? Glancing through the results it seems some encoders produce scores with higher variance and thus might be less desireable as you don't want to stray much from the average score at all (to a lower score) at this bitrate/quality.
The size of the error bars is directly caused by the encoders' variance.
That's really cool, I didn't know that before. So a shorter vertical bar means a more consistent encoder. Almost makes too much sense
Waiting for the new Nero release
