Topic: AAC 48kbps test - results (Read 33655 times) previous topic - next topic
The results of the public AAC 48kbps listening test are now available:
http://www.mp3-tech.org/tests/aac_48/results.html
Nero misses winning over 3GPP by a very small margin.
Overall it is safe to say that the tested Nero encoders are quite competitive against Coding Technologies ones, and 3GPP reference code is not that bad.
edit: there was initially a small processing error in the results, which is now corrected
Ouch... I sincerely hope Bond will like the results
Come on Ivan. Don't tease bond.
Juha Laaksonheimo
It seems that you substancially improved your encoder, guys.
Now, please do not forget that you still have to release it within the (too big IMHO) Nero suite.
As conclusion  mostly PS is useless at 48 kbits.
Despite the low bitrate of these samples, it seems the encoders performed quite well. I'm very impressed. It's incredible how quickly and radically the efficiency of audio compression progresses.
Congratulations to the folks at Nero for providing such an excellent product. Keep up the great work!
UED77
UED77
wavpack 4.50 -hx3; lame 3.97 -V4 --vbr-new
Yep...congrats to the Nero devs and Gabriel to submit this test.
Now, we waiting the new core engine guys...
Excelent work of Nero. Hope there still room for good engineering to improve AAC.
"harashin_result15.txt" is located in sample16 directory.
Is it just a mistake when hosting files?
This was a processing error. It is now corrected, but changed the results: Nero can not be said anymore to be better than 3gpp (considering 95% confidence intervals).
[a href="index.php?act=findpost&pid=373109"][{POST_SNAPBACK}][/a]
hehe
remembering all your promises i would have assumed that nero would have stumbed the reference encoder into the ground
anyways i hope those results will lead to that ct's encoder will not be that widely ignored anymore on hydrogenaudio compared to nero
(in fact after i tried to get guruboolez to care more about ct and not only about nero and the resulting flame war my mod status here was removed  )
anyways, who cares, great results for both ct and nero!
[a href="index.php?act=findpost&pid=373471"][{POST_SNAPBACK}][/a]
This assertion is false and the real reason was something else entirely:
Saved Moderator Logs
 Member Name  Actions Perfomed
 Peter                    3197
 bond                        1
Note to all: whineposts about doom9 moderation are NOT welcome in this thread.
 Peter                    3197
 bond                        1
[a href="index.php?act=findpost&pid=373504"][{POST_SNAPBACK}][/a]
ok if thats the real reason, i just thought it was something else because the removal of the mod status happened at the same time as the clash with the nero dev crowd (hey, noone cared to drop me a message on why i was "demoded"...)
there just isnt much to moderate in the video section
anyways, enough said about this topic...
Nero are preparing release 5.0 AAC with 2 pass support.  Maybe it will be possbile to introduce the feature autoselection between HE-AAC1 or HE-AAC2 basing on stastistic information of 1st pass.
I noticed that many times when LAME encoded samples with MS approx 90-95% or higher  then  PS is better than SBR for those samples.
For winamp 48000 bit/s != 48 kbit/s . 1 kbit = 1024 bits  != 1000 bits
So real 48 kbit bitrate for winamp will be 48*1024 = 49152 bit/s
Winamp CT in this test was tested at 48000 bit/s = 46,875 kbits/s
I just riped 1 cd  ( 4297 sec = 1 hour 11 mins 37 secs):
1. Nero 4.9.9.5 SBR vbr 3. Size 26498997 byte . Real bitrate 48,17 kbit/s
2. Winamp CT sbr --cbr 48000 . Size 25564613. Real bitrate 46,48 kbit/s
3. Winamp CT sbr --cbr 49000 . Size 26101657. Real bitrate 47,46 kbit/s
4. Winamp CT sbr --cbr 49500 . Size 26370201 . Real bitrate 47,94 kbit/s
Also riped 20:06 min:sec ac3 soundtrack . The same result.
Now I'm triyng to listen difference between CT and Nero and can't.
Sorry, but we are talking about bits here, so 1k = 1000.
48kbps is 48 000 bits per second.
Practically, I encountered winamp's encoder to give 46000bps when asked 48000bps. This might be because they are taking the mp4 container overhead into consideration.
To check it, someone has to encode files at both 48kbps and 96kbps. If the difference is 2kbps in both cases, then it probably means that they are taking container overhead into consideration. If the difference is 2kbps in one case and 4kbps in the other one, it means that they have an issue understanding the required (by the user) bitrate.
Just a question, where may I obtain the Nero encoder used in this test? An earlier comment leads me to believe it's not available to the public, is that right?
Look at the bottom of this page:
http://www.mp3-tech.org/content/?48kbps%20...20public%20test
However, I just noticed that the encoder is not there anymore. I'll restore it this evening.
still not there
Yes gabriel that would be wonderful, thanks I'll download it when it's up
Sorry.
Nero AAC encoder is now re-uploaded.
All the  contenders are statistically tied
whats up with that? (not that i really understand all this stats math.)
i imagine you could also say: just use the 3gpp reference code. (or maybe not?)
