Topic: MP3 320 CBR in Foobar2000 v0.9 (Read 9836 times) previous topic - next topic
I always used Foobar2000 v0.8.3 to convert my APE and FLAC files to MP3 with a bitrate of 320 CBR. Today I downloaded Foobar2000 v0.9 and I can only choose for conversion to a maximum of ~245kbps (*) V0.
How can I convert to 320 CBR with Foobar2000 v0.9?
Edit a LAME preset, and change the dropdown list at the top to "Custom"
Change the parameters to:
-b 320 - %d
I'm on a horse.
Thanks for your reply Synthetic Soul,
How can I edit a LAME preset?
I think you have to move from "MP3" to Custom
"Preferences" > "Tools/Converter".
Select an "MP3 (LAME)" preset from the "Encoding presets" list.
Click "Edit".
Change the Encoder dropdown from "MP3 (LAME)" to "Custom".
I'm on a horse.
Thanks a lot!
Hi
Normally I use VBR but I wanted to check something so I tried CBR but I always get this error:
Error writing to file (Encoder has terminated prematurely with code -1; please re-check parameters) : file://G:\Bearbeiten\COW\1 Music00.mp3
I used these parameters:
-S --noreplaygain -b 320 - %d
When I replace -b 320 with -V 0 --vbr-new or just -V 0 everything works fine.
First I thought the parameters are wrong but -b 320 works with EAC.
Where is the problem???
Your command line works fine for me.
I'm on a horse.
Just played a bit around and converted an mp3 back to wave and then tried to convert it with -b 320 and it worked.
Are there any requirements I have to meet for converting to cbr 320 with lame?
The files that give me the error have these parameters:
Sample Rate : 22050 Hz
Channels : 2
Bits Per Sample : 16
Bitrate : 705 kbps
Codec : PCM
Encoding : lossless
If you pass LAME a file with a samplerate of 22KHz it will attempt to use MPEG 2 Layer III, which has a maximum bitrate of 160kbps.  Here's the output from LAME on the command line:
MPEG-1   layer III sample frequencies (kHz):  32  48  44.1
bitrates (kbps): 32 40 48 56 64 80 96 112 128 160 192 224 256 320
MPEG-2   layer III sample frequencies (kHz):  16  24  22.05
bitrates (kbps):  8 16 24 32 40 48 56 64 80 96 112 128 144 160
MPEG-2.5 layer III sample frequencies (kHz):   8  12  11.025
fatal error during initialization
If you really want your file as 320kbps, although given the quality I don't know why, you should apply resampling before conversion, by checking the DSP checkbox on foobar's Converter dalogue, and selecting "Resampler (PPHS)".  Obviously resampling to 44100Hz is adequate - but you'd need someone who knows what they're talking about to say whether you would do better to use 48000Hz, for example.
I'm on a horse.
@Synthetic Soul
Thanks, using the Resampler worked fine.
I just wanted 320 because I want to compare those files with the versions I made with -V 0.
