Topic: Proggy To Encode And Then Replaygain? (Read 2051 times) previous topic - next topic
Looking for a proggy that'll encode to MPC and then Replaygain them.  Something I can just press Go and come back to encode files that have been Replaygained to my settings.  Speek's frontend requires this in two steps I believe.  Thanks.
Doesn't the MPC encoder support wildcards? If it does, you can do the job via a batch file:
mppenc --quality x C:\Blah\*.wav
replaygain --auto C:\Blah\*.mpc
If mppenc can even scan folders recursively for WAV files, then you can even do the job for multiple albums at once, using Case's Sweep.exe for ReplayGain'ing.
And you could also add a commandline for Tag.exe to tag&rename your files automagically.
