Topic: foo_dirwatch (Read 137391 times) previous topic - next topic
foo_dirwatch
This plugin allows you to specify directories to monitor, and notifies the Media Library of any changes (additions, renames, deletions) that occur.
Latest version: 0.2 beta 3 (2007-12-08)
REMOVED
Known issues
- a subset of directory removes are not handled
- moved files' playlist entries are not updated (renamed files' entries are, though)
foo_dirwatch
I it doesn't seem to be doing anything for me
I have set the paths of my directories, ticked the remove deleted files from the database box and set the filters to: *.mp3;*.wma
if I then add or remove files from the directories and and select directory watcher from my components menu, the database isn't getting updated.
foo_dirwatch
I like the idea of this plugin
However, the plugin reuqires  MSVCR70.dll to run, and I already have MSVCR71.dll in my foobar directory. I don't know what other foobar plugin uses MSVCR71.dll. I think its ColumnsUI.
Wouldn't it be better to use the newer dll?
foo_dirwatch
I uploaded a new version that fixes a crash bug and removes that menu item (because it doesn't do anything).
donnie - it's not working because you have include filters set -- currently they filter out directory notifications (whoops!). To see what I mean, try renaming an mp3 -- it should receive the notification.
I'll fix the include filters as soon as I can.
metal_termite - Not really. I only have MS Visual Studio.NET 2002. A lot of other plugins also require MSVCR70.DLL, so it's not like this is a unique situation.
EDIT: I uploaded a new version that fixes the include filters.
foo_dirwatch
 Great plug-in
thanks for your job
on every time does foo_dirwatch monitor the directories ? every x minutes?
foo_dirwatch
Please test files that are named with multi-byte character sets (e.g., Chinese, Japanese etc.); they should work fine but I want to be sure.
[a href="index.php?act=findpost&pid=363053"][{POST_SNAPBACK}][/a]
I tested files with Chinese names, and it worked like a charm.
However, directories to be monitored cannot contain Chinese characters.
I tested a directory with a Chinese named sub-folder. The console displayed a warning quoted below.
WARNING (foo_dirwatch) : Please check directories to monitor list in options, because "E:\music\诅咒(the sub-folder)" is not a valid directory on this system.
Please fix it. THX for such a good plugin.
Sorry for my poor English.
foo_dirwatch
this is a good idea, but it doesn't seem to actually do much. when i add files to the directory, it doesn't detect them. i've tried disabling foo_dir and re-enabling it, i've tried closing and opening foobar - nothing. the only thing it does is remove a file from the database after foobar has tried to play it and discovered the file wasn't there.
foo_dirwatch
it seems that foo_dirwatch doesn't work  perfectly
directory to monitor
I:\Music;G:\music mp3
include mask *.mp3;*.wma;*.m4?
exclude blank
I tried to add some dirs inside music , but nothig it did not add new mp3 in the database
in the console i get only these messages
INFO (foo_dirwatch) : Added "G:\music mp3\" to directory monitor list.
INFO (foo_dirwatch) : Added "I:\Music\" to directory monitor list.
INFO (foo_dirwatch) : Started monitoring directories
DATABASE setting
G:\music mp3\;I:\Music\
Restrict file type
BLANK
foo_dirwatch
Not working here either.
foo_dirwatch
To clarify some things:
foo_dirwatch does not poll for changes; instead, it uses the Win32 API function ReadDirectoryChangesW to tell the OS to notify foo_dirwatch when changes occur. This function does not exist on Windows 9x/Me and so the plug-in will not work on those OS versions.
If the plug-in is not working for you, please list the following info:
- directories to monitor string
- include filter string
- exclude filter string
- amount of files/folders in each directory being monitored
I'll fix the directory to monitor multi-byte problem as soon as I can.
foo_dirwatch
Awesome  This is just what I wanted!
foo_dirwatch
falling down the stairs i'm really  grateful for the plug in
Could you make an example  that i can come true ,realize,  so i can know if the plugin works to me??
i tried to add directory , tried to save mp3 in new directory , tried to move directory /mp3 , but nothing , this doen't update my database
i have 817 files in 91 subfolders in one directory and 1.580 files in 176 subfolders in another directory
for me could be better  , a plug that every x minutes ,can scan the database(the whole) and remove dead entries
foo_dirwatch
My setup is as follows:
Directories to monitor: F:\music;G:\music
Include filter: *.mp3;*.mp2;*.shn;*.flac;*.m4a;*.mpc;*.ogg
Exclude filter: *.jpg;*.gif;*.png;*.nfo;*.txt;*.tmp;*.bmp;*.ini
Does anything show up in the console? The plug-in prints a console message every time it adds/updates/removes something from the database.
[a href="index.php?act=findpost&pid=364203"][{POST_SNAPBACK}][/a]
That is not the intent of this plug-in. I don't want it to thrash the hard drive just to update the database - that would be a lot slower, plus you can already do that in foobar (Preferences /  Database / Remove dead entries from database).
foo_dirwatch
after several  testes
i get only this info from dir watch plug
INFO (foo_dirwatch) : Added "I:\mp3" to directory monitor list.
INFO (foo_dirwatch) : Added "G:\music mp3" to directory monitor list.
INFO (foo_dirwatch) : Started monitoring directories.
only 1 time, i got foo_driwatch found new songs , but it did not add to the database
foo_dirwatch
I've uploaded a new version that fixes the multi-byte problem with the "directories to monitor" field.
I did notice some problems with the plug-in myself (a directory move was not caught for some reason).
If you are having problems please help me track them down with these test cases:
1. Copy a file into one of the monitored directories. (Should trigger a "Precached..." note).
2. Copy a directory into one of the monitored directories. (same as above)
3. Rename a single file in one of the monitored directories. (Should trigger a "... was renamed to ..." note)
4. Rename a directory in one of the monitored directories. (same as above)
5. Move a file from one subdirectory to another in one of the monitored directories. (Should trigger one "Precached..." and one "Removed..." note)
6. Move a directory from one subdirectory to another in one of the monitored directories. (same as above)
Be sure to list the settings you are using in the foo_dirwatch preferences.
To see if database changes did actually occur I recommend the foo_dbsearch plug-in.
foo_dirwatch
[a href="http://imageshack.us" target="_blank"]
foo_dirwatch
Works at deleting at least  Thanks!
foo_dirwatch
falling down the stairs,
An excellent plug-in - works seamlessly with my removable drive.
I do have issues with UNC paths, but I understand that ReadDirectoryChangesW is only for drives - can you confirm?  I haven't been able to deduce whether mapping the UNC path to a drive works either.
Not being a foobar developer myself (dumb question approaching!) is it possible to perform a start-up inventory in the 'background' i.e. with a low priority thread?
Once again, thanks.
c0utta
foo_dirwatch
What issues are you having? ReadDirectoryChangesW is compatible with UNC paths. There are some limitations, but the current code should work with UNC paths. I don't think mapping a drive would change anything.
Yes, that's probably the best way to do it. I haven't implemented the inventory scan because I haven't yet decided on the best way to store the relevant data.
foo_dirwatch
I uploaded a new version. This one actually uses foobar's built in reader functionality, so when a file is added to the database its metadata is also automatically added.
No leads on the mysterious missing notifications, though.
foo_dirwatch
Fantastic plugin ... it makes foobar perfect.
thank you
foo_dirwatch
tha last version works like a charm !!!
Great plug in
only 1 time it did not work i renamed a folder placebo to placebo c , and dirwatch detected the change ,  after immediately i re-renamed to placebo , and it did not catch it
by the way , i did several several tests and dirwatch works really like a charm
with the feature Perform startup & shutdown inventory , this plug in makes foobar really perfect without rivals
thanks falling down the stairs
foo_dirwatch
Installing it now. If it works it's pretty much what I've been looking for in a year or so.
One question: for it to work the changes to the monitored directories must happen when foobar is active?
foo_dirwatch
[a href="index.php?act=findpost&pid=363143"][{POST_SNAPBACK}][/a]
Another question, sorry. Can I have both DLLs in my components directory? I currently have only version 71, but when I launch foobar I don't get any error message from this component.
foo_dirwatch
i installed the 2/16 version, but i can't turn on "Perform startup & shutdown inventory" feature. i can't tell that this component is actually doing anything.
