Topic: Bug: Blank seek pts in Flac when using Convertr (Read 6180 times) previous topic - next topic
  • Silverbolt
Flac files created with the Converter have an excessive number of seek points (max out at 1217).
metaflac.exe --list encoded_from_cmdline.flac:
METADATA block #0
 type: 0 (STREAMINFO)
 is last: false
 length: 34
 minumum blocksize: 4608 samples
 maximum blocksize: 4608 samples
 minimum framesize: 14 bytes
 maximum framesize: 13645 bytes
 sample_rate: 44100 Hz
 channels: 2
 bits-per-sample: 16
 total samples: 173531736
 MD5 signature: fe037483aed4f9b799a80eaf3f01288b
METADATA block #1
 type: 3 (SEEKTABLE)
 is last: false
 length: 7074
 seek points: 393
   point 0: sample_number=0, stream_offset=0, frame_samples=4608
   point 1: sample_number=437760, stream_offset=839360, frame_samples=4608
   point 2: sample_number=880128, stream_offset=1735713, frame_samples=4608
   point 3: sample_number=1322496, stream_offset=2587232, frame_samples=4608
   point 4: sample_number=1764864, stream_offset=3451039, frame_samples=4608
   point 5: sample_number=2207232, stream_offset=4350277, frame_samples=4608
   point 6: sample_number=2644992, stream_offset=5193427, frame_samples=4608
   point 7: sample_number=3087360, stream_offset=6045617, frame_samples=4608
   point 390: sample_number=172205568, stream_offset=432912851, frame_samples=4608
   point 391: sample_number=172647936, stream_offset=433971129, frame_samples=4608
   point 392: sample_number=173085696, stream_offset=435016634, frame_samples=4608
METADATA block #2
 type: 4 (VORBIS_COMMENT)
 is last: false
 length: 40
 vendor string: reference libFLAC 1.1.2 20050205
 comments: 0
METADATA block #3
 type: 1 (PADDING)
 is last: true
 length: 4096
metaflac.exe --list encoded_from_foobar.flac:
METADATA block #0
 is last: false
 length: 34
 channels: 2
 bits-per-sample: 16
METADATA block #1
 type: 3 (SEEKTABLE)
 is last: false
 length: 21906
 seek points: 1217
   point 4: sample_number=1760256, stream_offset=3441619, frame_samples=4608
   point 5: sample_number=2202624, stream_offset=4341444, frame_samples=4608
   point 391: sample_number=172486656, stream_offset=433586111, frame_samples=4608
   point 392: sample_number=172924416, stream_offset=434631868, frame_samples=4608
   point 393: sample_number=173366784, stream_offset=435642974, frame_samples=4608
   point 394: sample_number=173810299, stream_offset=0, frame_samples=0
   point 395: sample_number=174251442, stream_offset=0, frame_samples=0
   point 396: sample_number=174692585, stream_offset=0, frame_samples=0
   point 1214: sample_number=535547471, stream_offset=0, frame_samples=0
   point 1215: sample_number=535988614, stream_offset=0, frame_samples=0
   point 1216: sample_number=536429757, stream_offset=0, frame_samples=0
METADATA block #2
 is last: false
 length: 40
 comments: 0
METADATA block #3
 type: 1 (PADDING)
 is last: true
 length: 4096
Won't speculate on cause, but figured it was worth mentioning. Can anyone else confirm? Thanks.
f to c to f to c
  • ssamadhi97
  • Developer (Donating)
Are you sure that you used the exact same settings to create both files?
I have a hunch that you encoded encoded_from_cmdline.flac from a wave file, while for the creation of encoded_from_foobar.flac flac.exe was fed via pipe.
  • kjoonlee
I can recreate the output with foobar2000 0.9's converter; %s -o %d gives normal results but - -o %d results in lots of seek points.
However, I can't reproduce the abnormal behaviour when I run
cat input.wav | flac -V8 -s - -o from_stdin.flac
  • Peter
  • Administrator
Apparently handling of truncated source WAV files in FLAC tools is broken - encoding from stdin causes WAV file with header signaling maximum possible length to be generated, since exact total length of stream being encoded is not known in advance; then "truncated file" behavior is simulated when out of data to encode.
This behavior will not be changed on our side; use %s if this problem disturbs you.
  • Bourne
  • Banned
does this make the file lossy?
or it doesn't matter for quality?
  • guruboolez
  • Members (Donating)
No.
Yes.
Your file has simply more seek points (and a few additional/unecessary Kb).
  • Last Edit: 07 February, 2007, 02:04:40 PM by guruboolez
  • Bourne
  • Banned
so this is more of an esthetical file issue than quality issue that is (user not liking 1217 seek points). why wvpack has a astronomical speed when it seeks?
