Topic: AAC - 96 kbps, Intensity Stereo Test (Read 19059 times) previous topic - next topic
  • Ivan Dimkovic
For the upcoming brand new AAC encoder from Nero we just implemented Intensity Stereo, too
This was the very old discussion in AAC-Tech forum whether IS should be used or not - and, indeed, how much it degrades sound image and how much it brings in improved overal distortion-level...
So, here is the first test with Nero's new encoder which is currently in development (signalled as 4.9.9.9 this time
Files are encoded in 96 kbps CBR - to maximize the "pressure" on the codec psymodel/bit-rate-allocator - and following files are covered:
castanets -> pre echo clip
dr4  -> trumpet with strong harmonic components
es02  -> German speech
French_ad -> French Ad, also speech but with music in background
Layla -> strong applause in both channels that makes lossy stereo very tricky
Si02 -> pre echo clip
Sm01 -> highly tonal clip
Velvet -> speciality for stereo coding  almost completely uncorrelated channels
Waiting -> we all know what is it...
youcantdothat -> also strong channel separation
I chose 96 kbps to measure how much IS degrades the quality, at bit rates of 64 kbps it is clear that IS definitely outweights any of its disadvantages... but as we go up, it is interesting to check.
Also I selected very worst test items, just to make it even harder for the codec
Note - IS implementation in this version is still not final, and it will for sure be improved even more before the launch.
Attached are packed IS and non-IS files (1.65 mb each)... original flacs coming soon
Edit - added files with better IS perceptual control
  • Last Edit: 25 December, 2005, 01:37:42 PM by Ivan Dimkovic
  • Ivan Dimkovic
And... the flacs
  • Ivan Dimkovic
Another note - most likely, IS won't be used at this bit rate, or it will be used in much reduced way than it is in this test -  purpose of the demo is to check amount of stereo reduction (if any) and some other artifacts it might introduce.
Few of those are already known and we are working on them
So, at lower bitates (e.g. 48-80 kbps) we might improve listening experience over common LC-AAC implementations even more for those without ability to use HE-AAC
  • Last Edit: 24 December, 2005, 08:46:08 PM by Ivan Dimkovic
  • guruboolez
  • Members (Donating)
Short ABX tests before jumping in a warm bed.
Keep in mind that I haven't PCM files as reference; I only compared both encodings and tried to find encoding artifacts.
foo_abx 1.3 report
foobar2000 v0.9 beta 12
2005/12/25 03:08:59
File A: C:\HA - noël 2005\NERO Intensity Stereo\french_Ad.mp4
File B: C:\HA - noël 2005\NERO Intensity Stereo\french_Ad_IS.mp4
03:08:59 : Test started.
03:09:40 : 01/01  50.0%
03:09:47 : 02/02  25.0%
03:09:54 : 03/03  12.5%
03:09:59 : 04/04  6.3%
03:10:05 : 05/05  3.1%
03:10:11 : 06/06  1.6%
03:10:16 : 07/07  0.8%
03:10:25 : 08/08  0.4%
03:10:27 : Test finished.
Total: 8/8 (0.4%)
The IS encoding sounds noisier on the beginning (little pshhh audible on both encodings but slightly higher with IS). Difference is rather small.
foo_abx 1.3 report
2005/12/25 03:13:19
File A: C:\HA - noël 2005\NERO Intensity Stereo\dr4.mp4
File B: C:\HA - noël 2005\NERO Intensity Stereo\dr4_IS.mp4
03:13:19 : Test started.
03:13:44 : 01/01  50.0%
03:13:52 : 02/02  25.0%
03:14:02 : 03/03  12.5%
03:14:08 : 04/04  6.3%
03:14:18 : 05/05  3.1%
03:14:37 : 06/06  1.6%
03:14:44 : 07/07  0.8%
03:15:04 : 07/08  3.5%
03:15:10 : 08/09  2.0%
03:15:15 : 09/10  1.1%
03:15:17 : Test finished.
Total: 9/10 (1.1%)
[11.00 - 13.00] The loudest trumpet note is distorted (it sounds like ringing on a very short moment) with IS encoding. The other one is less disturbing.
Additional note: the distortion is also audible on the beginning (two first seconds). This time both encodings are concerned, but IS is really more unpleasant to my ears. It's not really ringing, but noise or fat sounding.
Additional note No.2: sample sm01 suffers from ringing (more with IS), but I haven't ABXed it yet.
foo_abx 1.3 report
2005/12/25 03:15:48
File A: C:\HA - noël 2005\NERO Intensity Stereo\castanets.mp4
File B: C:\HA - noël 2005\NERO Intensity Stereo\castanets_IS.mp4
03:15:48 : Test started.
03:16:12 : 01/01  50.0%
03:16:18 : 02/02  25.0%
03:16:24 : 03/03  12.5%
03:16:38 : 04/04  6.3%
03:16:43 : 04/05  18.8%
03:16:50 : 05/06  10.9%
03:17:00 : 05/07  22.7%
03:17:05 : 06/08  14.5%
03:17:10 : 07/09  9.0%
03:17:23 : 07/10  17.2%
03:17:34 : 08/11  11.3%
03:17:46 : 08/12  19.4%
03:17:54 : 09/13  13.3%
03:18:30 : 09/14  21.2%
03:18:35 : 10/15  15.1%
03:18:38 : 10/16  22.7%
03:18:43 : 10/17  31.5%
03:18:45 : Test finished.
Total: 10/17 (31.5%)
I heard more smearing for IS during the introduction (guitar + ta-ta-ta-ta) but I decided to ABX something which isn't located on the very beginning. I failed :/
This is all for this night. Now, bed. Tomorrow, some other files
P.S. The german speech sample sounds really bad, with aggressive whispering I can sometimes heard on TV. Are your encodings transcoded from a lossy source?
P.S.2: hardware setting = AC97 component  + Philips HP910 headphone
  • Last Edit: 24 December, 2005, 09:33:57 PM by guruboolez
  • Ivan Dimkovic
Thanks Guru for the quick test!  Also warm bed is waiting me, too
Regarding ES02... please download the .flac file - it is not transcoded or processed in any way, and encoded files are very close to it.
  • guruboolez
You're right: the reference disturbs me as well (only the 00.600-04.600 range - the rest sounds OK).
  • Ivan Dimkovic
Some more perceptual optimizations are done - I'll try to post new IS clips at the same bitrate soon.
  • Ivan Dimkovic
Ok, here are the files with refined IS algo (more perceptual control)
  • IgorC
It's test really not for 10$ edifier 6631 and generic  audio card
ABC/HR Version 1.1 beta 2, 18 June 2004
Testname: IS2 and NO_IS
1L = C:\music\waiting abx\1 Waiting is2.wav
2L = C:\music\waiting abx\2 Waiting no is.wav
 0 of   1, p = 1.000
 0 of   2, p = 1.000
 1 of   3, p = 0.875
 2 of   4, p = 0.688
 3 of   5, p = 0.500
 4 of   6, p = 0.344
 5 of   7, p = 0.227
 5 of   8, p = 0.363
FINISHED
General Comments:
ABX Results:
C:\music\waiting abx\1 Waiting is2.wav vs C:\music\waiting abx\2 Waiting no is.wav
   5 out of 8, pval = 0.363
  • Last Edit: 25 December, 2005, 04:43:22 PM by IgorC
  • IgorC
[a href="index.php?act=findpost&pid=352244"][{POST_SNAPBACK}][/a]
CT supports HE-AAC up to 128 kbit/s. After  some abx test (  Winamp 5.12 CT encoder vs Nero 4.9.9.9 for the samples of this topic  ) I found that CT encoder can be on par with LC-AAC at 96 kbit/s or even beter on some samples like Waiting and Layla
Indeed there should be a test to determine  if statement that  SBR is usefull only up to 80 kbit/s  is still truely.
  • Last Edit: 25 December, 2005, 11:35:27 PM by IgorC
  • Ivan Dimkovic
For 96kbps there is also choice of single-rate SBR (downsampled SBR) - where AAC codec would operate at 44.1 kHz - thus eliminating SBR pre-echo issues a lot.
Our new codec also supports that, and it would be very interesting to check if this mode outperforms LC-AAC and usual dual-rate HE-AAC at this bit rate.
  • Last Edit: 26 December, 2005, 05:30:34 AM by Ivan Dimkovic
Some quick tests:
No IS vs. Original:
foo_abx 1.3 report
foobar2000 v0.9 beta 13
2005/12/26 11:53:21
File A: D:\Neuer Ordner\aac_96kbps_cbr_no_is\Layla.mp4
File B: D:\Neuer Ordner\Layla.flac
11:53:21 : Test started.
11:53:33 : 01/01  50.0%
11:53:39 : 02/02  25.0%
11:54:44 : 03/03  12.5%
11:54:48 : 04/04  6.3%
11:54:57 : 05/05  3.111:55:00 : 06/06  1.6%
11:55:11 : 07/07  0.8%
11:55:19 : 08/08  0.4%
11:56:01 : Test finished.
Total: 8/8 (0.4%)
IS vs. Original:
foo_abx 1.3 report
2005/12/26 11:59:29
File A: D:\Neuer Ordner\Layla.flac
File B: D:\Neuer Ordner\aac_96kbps_cbr_with_is\Layla.mp4
11:59:29 : Test started.
11:59:37 : 01/01  50.0%
11:59:44 : 02/02  25.0%
11:59:47 : 03/03  12.5%
11:59:51 : 04/04  6.3%
11:59:54 : 05/05  3.1%
12:00:03 : 06/06  1.6%
12:00:06 : 07/07  0.8%
12:00:09 : 08/08  0.4%
12:00:10 : Test finished.
Total: 8/8 (0.4%)
IS2 vs. Original:
foo_abx 1.3 report
2005/12/26 12:00:42
File B: D:\Neuer Ordner\aac_96kbps_cbr_with_is2\Layla.mp4
12:00:42 : Test started.
12:00:51 : 01/01  50.0%
12:00:54 : 02/02  25.0%
12:00:57 : 03/03  12.5%
12:00:59 : 04/04  6.3%
12:01:01 : 05/05  3.1%
12:01:03 : 06/06  1.6%
12:01:04 : 07/07  0.8%
12:01:06 : 07/08  3.5%
12:01:12 : Test finished.
Total: 7/8 (3.5%)
No IS vs. IS:
foo_abx 1.3 report
2005/12/26 12:02:00
12:02:00 : Test started.
12:02:14 : 01/01  50.0%
12:03:00 : 02/02  25.0%
12:03:18 : 03/03  12.5%
12:03:22 : 04/04  6.3%
12:03:33 : 05/05  3.1%
12:04:04 : 06/06  1.6%
12:04:10 : 07/07  0.8%
12:04:13 : 07/08  3.5%
12:04:15 : Test finished.
Total: 7/8 (3.5%)
No IS vs. IS2:
foo_abx 1.3 report
2005/12/26 12:06:10
12:06:10 : Test started.
12:06:31 : 01/01  50.0%
12:06:34 : 01/02  75.0%
12:06:38 : 02/03  50.0%
12:06:40 : 03/04  31.3%
12:06:54 : 03/05  50.0%
12:07:09 : 04/06  34.4%
12:07:13 : 04/07  50.0%
12:07:16 : 05/08  36.3%
12:07:18 : Test finished.
Total: 5/8 (36.3%)
IS vs. IS2:
foo_abx 1.3 report
2005/12/26 12:07:47
File A: D:\Neuer Ordner\aac_96kbps_cbr_with_is\Layla.mp4
12:07:47 : Test started.
12:08:33 : 00/01  100.0%
12:08:36 : 00/02  100.0%
12:08:41 : 00/03  100.0%
12:08:44 : 01/04  93.8%
12:08:47 : 01/05  96.9%
12:08:51 : 02/06  89.1%
12:08:53 : 03/07  77.3%
12:08:56 : 04/08  63.7%
12:08:58 : Test finished.
Total: 4/8 (63.7%)
Conclusion: all are more or less distinguishable from the original. When it comes to IS vs. no IS, no IS sounds better to my ears. For IS vs. IS2, no idea. I think IS2 was a bit better, but as you can see from the ABX logs, I didn't manage to get an acceptable result.
I also noticed that IS has an artifact during the first few seconds of applause. It produces something like a "Krr".
  • Last Edit: 26 December, 2005, 06:21:47 AM by Sebastian Mares
  • Ivan Dimkovic
Thanks IgorC, Sebastian,
We will continue to improve IS (some more things are left to be done) - but I also think IS should be used at bit rates lower than 96 kbps - perhaps 80 and definitely 64 kbps.
Interesting is that I definitely found out that IS in AAC is much better than IS in MP3 - because AAC has TNS tool, which should shape the noise to avoid IS articacts of bad noise positioning in the R channel (thus generating failed stereo image)
  • freelancer
Glad to hear Nero is doing something new to AAC, I've a question that is the AAC+IS require the IS support from AAC decoder just like SBR and PS does?
My new mobile phone seems to only support LC-AAC, so I can't get any benifit from HE-AAC, if LC+IS doesn't require decoder's special support, that could be cool to me.
  • Garf
  • Developer (Donating)
IS is a part of the original, very first, MPEG 2 LC-AAC spec, so *all* AAC decoders have support for it.
  • Last Edit: 07 January, 2006, 06:12:45 AM by Garf
  • freelancer
[a href="index.php?act=findpost&pid=355252"][{POST_SNAPBACK}][/a]
Thanks Garf, glad to hear that. But why IS is already supported by decoders but no encoders support IS till now?(except the coming Nero encoder  )
And when can we expect to have a public test version of Nero AAC encoder that supports IS?  And did you do any internal comparison about LC+IS and HE-AAC at 64/80 Kbps? I'm interested at which one could win
Or it is possible to use HE+IS+PS in the future?
  • Last Edit: 07 January, 2006, 07:05:51 AM by freelancer
  • Garf
It appears to be quite tricky to use correctly.
[a href="index.php?act=findpost&pid=355262"][{POST_SNAPBACK}][/a]
We are still looking into this. For close calls we may do further public tests here.
[a href="index.php?act=findpost&pid=352418"][{POST_SNAPBACK}][/a]
so does single rate/downsampled sbr mean that the lc-aac part would be 44.1khz and the sbr part would also be 44.1khz?
if so, i think it would outperform lc-aac and dual rate he-aac
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
  • Garf
SBR runs at 88.2kHz but gets downsampled (hence the name).
[a href="index.php?act=findpost&pid=369061"][{POST_SNAPBACK}][/a]
I don't think anything, I am SURE it needs to be TESTED.
  • Last Edit: 05 March, 2006, 04:39:40 AM by Garf
thanks, I get it now
sure it would need testing... but if the lc-aac part isn't forced down to half the samplerate (22.05khz) then sbr wont have as much bandwidth to cover (instead of the entire top half, maybe just the top fourth)  my speculation here is based on plusV fullrate (44.1khz mp3 + 44.1khz plusV)... we shall see how it goes when it gets tested though
Vorbis-q0-lowpass99
