Topic: iTunes won't play all my mp3 files (Read 2640 times) previous topic - next topic
  • Snire
iTunes can not find, and list in its library window some of my mp3 files. And it will not play this files either. All files are tagged and I cant find anything that says they not should work. They plays fine in WMP and Winamp.
Can anyone help ? please, because I want to use iTunes.
Once I used Maxell XLIIs, now I use cdr.
  • Crissaegrim
[a href="index.php?act=findpost&pid=350083"][{POST_SNAPBACK}][/a]
Do you have Quicktime installed?
  • Snire
Yes, should I reinstall it or remove it?
Tried to reinnstall, but the problem is still the same.
Now I have been reading a lot and tried out different things. And here is my conclusion:
I use dbPoweramp musicconverter and rightclick a mp3 file and choose edit tags, and choose remove all. This removes only the ID3v1 tags. I keep the ID3v2 tags ok, and iTunes read them all and plays the file. Yippiii!
But a strange thing is that when I remove the ID3v1 tags with Tag&Rename, the files are still not to be wieved in iTunes. I dont care about this because dbPoweramp musicconverter made it for me.
I think the tagging problem depends on some files are tagged with ANSI and some with UNICODE, and iTunes dont like ANSI.
Now I have marked about 8500 files for ID3v1 tag removing, so I hope it works well...
  • Last Edit: 14 December, 2005, 09:59:31 AM by Snire
