Topic: Multiformat Listening Test @ 128 kbps - OPEN (Read 166838 times) previous topic - next topic
Reply #200
(of course other than the case when ABX results are "against" ABC/HR ones   )
[a href="index.php?act=findpost&pid=353123"][{POST_SNAPBACK}][/a]
It can't happen with schnofler's ABC/HR. If a file is correctly ABXed, the bad slider is automatically frozen
Reply #202
Happy New Year to everyone; three hours left in Germany.
[a href="index.php?act=findpost&pid=353658"][{POST_SNAPBACK}][/a]
Congratulations, it's 12:40 PM where I live.
Reply #204
2006 finally arrived here, too!
[a href="index.php?act=findpost&pid=353672"][{POST_SNAPBACK}][/a]
8 hours and 47 minutes to go...
Reply #205
OK, I have at least 10 results for all samples now.
Is that enough?
Do not taunt audiophiles; they may bite.
Reply #207
Is it possible to reset an ABX test after having pressed the "Finish" button? I pressed Finish after the 6th try but would like to test more.
PS: are ABX results included in the results of the listening test? How low the probability has to be to disable the bad slider?
Reply #208
All I can say is that ABX results are included in the logs. No idea about the other questions, though.
Anyways, how's testing going, guys? Slowly reaching the second deadline and I can't say I received a lot of new results.
Reply #209
[a href="index.php?act=findpost&pid=355690"][{POST_SNAPBACK}][/a]
The ABX "probability if guessing" that you must reach is set by the person making the test.
So if you don't remember, I'll guess it's the default <0.05
Reply #210
[a href="index.php?act=findpost&pid=355697"][{POST_SNAPBACK}][/a]
Ah, then yes, 0.05 is correct.
Reply #211
[a href="index.php?act=findpost&pid=355055"][{POST_SNAPBACK}][/a]
No, it's not possible. Otherwise you could just keep resetting and finishing the test until you get the desired result (pval<0.05) by chance.
Reply #212
[a href="index.php?act=findpost&pid=355746"][{POST_SNAPBACK}][/a]
Isn't such cheating already possible by "forgetting" to save the session, re-opening the test and trying again?
Reply #213
[a href="index.php?act=findpost&pid=355799"][{POST_SNAPBACK}][/a]
The likelyhood of being able to get a significant ABX on *all* samples with this method isn't very good
Reply #214
ok, started testing, some doubts:
1) can i use a pair of sony u$s 10 headphones? (i have no better)
2) as far as i can see, i rate all 5! (i must be deaf) should i try anyway?
3) when i press "ref" button, is it allways the unencoded sample?
thanks.
Reply #215
thanks.
[a href="index.php?act=findpost&pid=356575"][{POST_SNAPBACK}][/a]
1) Probably yes if you still can spot artefacts, but it certainly won't make testing any easier for you
2) Same here, except for one sample, and that with Sennheiser HD600's
But you do recognise the low anchor, don't you? Otherwise you really should consider having your ears checked
3) Yes
Proverb for Paranoids: "If they can get you asking the wrong questions, they don't have to worry about answers."
-T. Pynchon (Gravity's Rainbow)
Reply #216
cant even recognize the f*#$g low anchor
mmm ... so maybe for me 128kbps = CD quality is true!
Reply #217
[a href="index.php?act=findpost&pid=356585"][{POST_SNAPBACK}][/a]
I can ABXed low anchor  in the almost all samples. But it's hard for  anothers
Reply #218
so the question still remain, should i send an all 5 test result?
Reply #219
Well, yes, why not? It IS a result showing that the encoders performed well.
Anyways, no offense, but you could have checked if you can spot differences before telling me to extend the test.
Reply #220
never thought it could be this dificult ... maybe i should had tried ... but it bet you didn't do it just for me
Reply #221
Well, as I said in a previous post, I didn't receive a significant amount of new results which makes me feel a bit upset. It's not your fault, don't get me wrong.
Oh, by the way, thanks a lot to all of you who participated and helped me out during these weeks!
Reply #222
check sample #12 IMHO quite easy to detect low anchor ...  but other encoders for me mission impossible  and sample #1 annoying in original  haven't checked others.. anyway can't recognise anything except low anchor...
Reply #223
i would check sample 12 right away. i suppose my cheap earphones could be the culprid also?
Reply #224
Well I just attempted to try to help with that, but I don't hear any sound when I try to play the a sample.  In fact, I get no indication they're actually being played (is that normal)?  I tried listen to just part of the sample with the same result.  I believe I followed all the directions.  When I play the WAVs with Windows Media Player I hear them.  I upgrade to the lastest java (as I had an old version) but also didn't help.  I also verified my directory structure is correct.  Any ideas?
