Topic: Composer and other missing tags in LAME (Read 6326 times) previous topic - next topic
  • huh-hah
Is there a resource that lists all ID3V2 tags and their LAME command line equivalents?
I'm asking because the Wiki's recommended command line parameters seem to be missing some potentially useful (to me) tags.
The first one is genre, which I found after some (well, lots of) searching. It looks like this for those interested:
--tg "%m"
The other tag I'd like to add is composer. Anyone care to help?
Also, are there any other non-recommended/non-default tags you'd like to share?
P.S. I'm using EAC 0.95b3 with LAME 3.97b1 (just noticed b2 is out, will try layer today)
  • huh-hah
Well, I have had better response rates
Let me know if there are better places to ask.
  • Sunhillow
  • Members (Donating)
Hi huh-hah,
there are only cmd-line equivalents for ID3V1 tags.
See the output of lame -?
  • huh-hah
Thanks Sunhillow. No, I haven't checked LAME's output, will do the next rip. But that basically explains it then. I must have missed that part of the documentation
So how do folks around here add V2 tags?
  • Never_Again
See one of the numerous "What is your favorite/the best tag editor" here and in General Audio.
  • AutumnRain
the tag switches are in the lame documentation, same for eac.
are you able to add the genre tag for ID3V2 ?
it only gets written for ID3V1 for me. (while using EAC & Lame)
  • clintb
[a href="index.php?act=findpost&pid=346781"][{POST_SNAPBACK}][/a]
The GodFather is an awesome tagging program.
  • huh-hah
[a href="index.php?act=findpost&pid=347586"][{POST_SNAPBACK}][/a]
this is the lame command i'm using:
-V 2 --vbr-new --id3v2-only --pad-id3v2 --...
the --tg "%m" comes after all the other parameters. i'm probably a bit confused, but as far as i understand this should add v2 tags and only v2 tags.
clintb, thanks for the tip, but isn't it possible to add more v2 tags with LAME?
  • wynlyndd
I do not think it is possible to have LAME append the composer field even when writing v2.X tags when ripping with EAC because EAC isn't capturing the composer info. EAC is a great program but the interface only captures basic information (the traditional v1.1 tags). This information is available for LAME when LAME writes the v2.x fields but LAME cannot add what it isn't told about.
except I bet maybe you could get it to write blank composer fields (I'd have to check the switches)
  • Last Edit: 05 December, 2005, 02:56:39 PM by wynlyndd
"Droplets of Yes and No, in an ocean of Maybe"
  • k.eight.a
I'm using a command line:
-V 2 --vbr-new -Y --id3v1-only --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" %s %d
...and the resulting MP3's are missing the genre Tag, why?
Note that I'm using only those from the ID3V1 list of genres!
Sorry for my poor English, I'm trying to get better... ;)
"The greatest trick the Devil ever pulled, was convincing the world he didn't exist."
  • huh-hah
[a href="index.php?act=findpost&pid=347959"][{POST_SNAPBACK}][/a]
%m is for genre. Try adding --tg "%m just before %s %d
%m is for genre...
[a href="index.php?act=findpost&pid=348018"][{POST_SNAPBACK}][/a]
Not that I doubt you, but where did you find out that %m is for genre?  I cannot find that documented anywhere on EAC's site.
From the EAC options dialog in the Filename tab, I find that what seems to make the most sense for genre is either %I or %B.  (See this posting
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=39462]http://www.hydrogenaudio.org/forums/index....showtopic=39462[/url]
for a related discussion.)
  • k.eight.a
I have found this:
%d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" LAME.exe -V 2 --vbr-new %s %d
...on the HA wiki from the configuration of APEv2 Tags.
@ huh-hah: Do I have to try --tg "%m or --tg "%m" ?
Edit: Sorry, I've just found
--tg "%m"
in your first post.
  • Last Edit: 06 December, 2005, 07:04:12 PM by k.eight.a
  • AutumnRain
huh-hah wrote..
this is the one am using atm
-V 1 --add-id3v2 --pad-id3v2 --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" --tg "%m" --tc "%e" %s %d
- ID3V1 all tags get written properly
- ID3V2  all tags, except the Genre tag, get written.
(using 'ext encoder' & commandline in eac)
if i do the tagging routine through EAC the genre tag for ID3v2 gets written proper
checked tags with mp3utility
captainmidnight wrote..
its in eac documentation in the EAC folder
[edited] just tried from the winxp 'cmd' - same problem
lame.exe -V 2 --add-id 3v2 --pad-id3v2  --tg "blues" --tc "hello" "inputfile" "outputfile"
the id3v1 genre tag got written , the ID3v2 one didn't
comment tag one got written for both q;)
  • Last Edit: 07 December, 2005, 07:25:30 AM by AutumnRain
