Topic: LAME 3.97b2 (Read 48413 times) previous topic - next topic
  • rjamorim
LAME 3.97b2
Gabriel Bouvigne just commited LAME 3.97 beta 2 to the CVS repository.
Quoting him: "There are only a few changes compared to b1, so I think that we should be able to release 3.97 soon."
http://lame.sourceforge.net/
Binaries are available at RareWares.
  • Last Edit: 27 November, 2005, 06:10:48 PM by rjamorim
http://www.rarewares.org
  • guruboolez
  • Members (Donating)
LAME 3.97b2
Binaries should be available at RareWares soon.
[a href="index.php?act=findpost&pid=345429"][{POST_SNAPBACK}][/a]
Could someone wake up John33?
  • rjamorim
LAME 3.97b2
Here's a stop-gap compile for win32 until John compiles proper, ICL-optimized binaries:
http://www.rarewares.org/rja/Lame-Win32-3.97b2.zip
  • ysoya
LAME 3.97b2
I noticed slight modification on V5 ATHaa sensitivity.
from presets.c (line 370, 388)
Lame 3.97b1
  V5 athaa_sensitivity = -16
Lame 3.97b2
  V5 athaa_sensitivity = -12
  • Last Edit: 27 November, 2005, 12:07:11 AM by ysoya
  • john33
  • Developer
LAME 3.97b2
The base compile is now at Rarewares MP3 page. The other compiles will follow.
If I have understood communications on the lame-dev mailing list correctly, this beta may change a little later after Gabriel has backported some stuff from the CVS head (ie., the alpha).
John
  • kurtnoise
LAME 3.97b2
AS switch has been reintroduced in the cli...good to know.
  • jkml
LAME 3.97b2
[a href="index.php?act=findpost&pid=345529"][{POST_SNAPBACK}][/a]
lameACM.acm of beta 2 is 181 KB while lameACM.acm of beta 1 is 269 KB.  Is the size difference normal?
  • john33
  • Developer
LAME 3.97b2
[a href="index.php?act=findpost&pid=345537"][{POST_SNAPBACK}][/a]
The difference is due to the b2 ACM compile being an MSVC6 one rather than the ICL9.0 of b1. It seemed from the lame mailing lists that people were having difficulties with the ICL compile so I thought it was worth trying a standard VC6 version.
John
  • 5paz
LAME 3.97b2
Is there a apt-key signature key for your debian RareWare repositories. I'm using sid and I can just use --allow-unauthenticated with apt-get but I like to use aptitude and it just looks ugly  with all those U's splattered all over the place.
thanks
  • jamesbaud
LAME 3.97b2
Looking forward to the version with the INI setup.
  • frodoontop
LAME 3.97b2
Another step towards a stable new lame version  I'm looking forward to that, since all linux distributions will update lame too.
I know, I could compile it myself, but since I'm rather lazy...
A secure audio ripper for linux: code.google.com/p/rubyripper
  • john33
  • Developer
LAME 3.97b2
I will post a 'final' beta, plus derivative compiles, once the beta 2 version is announced at Sourceforge. Only then can we be sure that we have the full beta 2 release.
John
  • jaybeee
LAME 3.97b2
Quoting him: "There are only a few changes compared to b1, so I think that we should be able to release 3.97 soon."[a href="index.php?act=findpost&pid=345429"][{POST_SNAPBACK}][/a]
I think it's always useful to detail the changes made for any software update.
I'm sure it's detailed in the lame cvs (somewhere), but since you went to the effort to tell us about the update, it would've been nice to have stated the changes made in the same post.  Or maybe Gabriel could/should do that?
  • Digga
LAME 3.97b2
I guess Roberto also doesn't know what the changes are (yet), otherwise he probably would have written them down.
I'll glady see a newsflash with just some notes or brief descriptions rather than no news at all as far as I am concerned
Nothing but a Heartache - Since I found my Baby ;)
  • jaybeee
LAME 3.97b2
[a href="index.php?act=findpost&pid=345911"][{POST_SNAPBACK}][/a]
Agree, and I'm not saying we shouldn't have had any update.  Thanks to Roberto for posting.  Just a prompt really for someone to update it with the changes that's all
  • Alex B
LAME 3.97b2
From another thread:
@halb27:
You may find the information here of intrest to you:
http://cvs.sourceforge.net/viewcvs.py/*che...y.html?rev=HEAD
LAME 3.97 beta 2   November 26 2005
    * Gabriel Bouvigne:
          o Fixed an initialization error when input is not using a standard sampling frequency
          o Fixed a possible assertion failure in very low bitrate encoding
          o Slight change regarding ATH adjustment with V5
          o Reinstated bit reservoir for 320kbps CBR
          o ReplayGain analysis should now be faster when encountering silent parts
    * Takehiro Tominaga:
          o Fixed a possible link problem of assembly code
[a href="index.php?act=findpost&pid=345793"][{POST_SNAPBACK}][/a]
some archived old tests: http://listening-tests.freetzi.com
  • halb27
LAME 3.97b2
@halb27:  .... Reinstated bit reservoir for 320kbps CBR   ...
[a href="index.php?act=findpost&pid=345914"][{POST_SNAPBACK}][/a]
Thank you, grreat news.
lame3995o -Q1
  • burnett_s
LAME 3.97b2
Since LAME 3.97 beta 2 is out, should we use it instead of LAME 3.97 beta 1 or not yet ?
Gabriel Bouvigne:
- Fixed an initialization error when input is not using a standard sampling frequency
- Fixed a possible assertion failure in very low bitrate encoding
- Slight change regarding ATH adjustment with V5
- Reinstated bit reservoir for 320kbps CBR
Takehiro Tominaga:
- Fixed a possible link problem of assembly code
Gr.
Greetings
Sonny Burnett.
  • ChiGung
LAME 3.97b2
[a href="index.php?act=findpost&pid=345927"][{POST_SNAPBACK}][/a]
Congratulations Halb! and +Respect to Gabriel for hacking it out with you and taking it onboard
no conscience > no custom
  • user
LAME 3.97b2
I suggest to change the recommnded settings topic & recommnded compiles topic, to recommend now 3.97b2 inseatd of 3.97b1.
www.High-Quality.ch.vu -- High Quality Audio Archiving Tutorials
  • Echizen
LAME 3.97b2
[a href="index.php?act=findpost&pid=345966"][{POST_SNAPBACK}][/a]
Yes, we should do that.
[span style='font-size:8pt;line-height:100%'](User: Please answer to my PMs next time.)[/span]
  • Last Edit: 28 November, 2005, 10:04:31 AM by Echizen
  • user
LAME 3.97b2
[a href="index.php?act=findpost&pid=345970"][{POST_SNAPBACK}][/a]
[span style='font-size:8pt;line-height:100%']Sorry, I answered, when there was time. Unfortunately, we aren't paid for HA-work  Changes from various persons were suggested, so I decided to watch the daily or even hourly proposed changes. Now it has settled down a bit, and I have time again for the moment to work on mp3, but the topic is closed and i cannot edit. If the topic is opened for edition of the lame 3.97b2, I will look for incorporation of layout/wording changes, also.[/span]
  • CiTay
  • Administrator
LAME 3.97b2
[a href="index.php?act=findpost&pid=345981"][{POST_SNAPBACK}][/a]
Okay, opened. Please take note of the changes you make so it can be edited in the Wiki as well.
LAME 3.97b2
Maybe related, but awhile ago I created a silent sound file in soundforge and encoded it with: mppenc, LAME, and Nero AAC.
I noticed that LAME took approximately 7x longer to encode pure silence than the others. I thought it was a little strange.
  • CiTay
  • Administrator
LAME 3.97b2
[a href="index.php?act=findpost&pid=346012"][{POST_SNAPBACK}][/a]
Hehe, maybe it's those denormals again?
