Topic: Experimental 3.93 Release -- Needs Testing (Read 3305 times) previous topic - next topic
  • Dibrom
  • Administrator
I've made a compile of Takehiro's experimental branch of LAME 3.93 and added 3 new presets which need testing (along with the old presets as well).
You can download the compile here: http://static.hydrogenaudio.org/extra/LAME/dm-lame.zip
For more information, read my comments in this thread:
http://www.hydrogenaudio.org/forums/index....=ST&f=15&t=3836
I'll be posting sources before long.
  • IGOR][X
No optimization for -q0 switch?
  • IGOR][X
And...another question...why don't make an option like -nods (old Mp+ encoder) for delete the silence at the beginning and at the end of the files?
  • rjamorim
Not Found
The requested URL /extra/LAME/dm-lame.zip was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Get up-to-date binaries of Lame, AAC, Vorbis and much more at RareWares:
http://www.rarewares.org
  • ChS
Should we just go ahead and test the build that Robert released yesterday or is this one going to be available again?
  • robert
There was no real release yesterday. It was just to get you an idea of what will be there soon. At least, some nasty bugs showed up and are fixed.
  • Q!
Not Found
Yeah, same here.
EDIT: Ok, so where's the version we're supposed to test?
  • Dibrom
  • Administrator
Go to this thread:
http://www.hydrogenaudio.org/forums/index.....t=0&entry39593
The files are listed there.
I'm closing this thread so that the discussion is not split across threads.
[span style='font-size:7pt;line-height:100%']edit by roberto: bork character in the url[/span]
