Topic: A secure ripper for linux (Read 163595 times) previous topic - next topic
Reply #175
just change the readahead value in p_block.c  and recompile
by default it's set to only 150 sectors so it reads 150+1 sectors at a time, only 302kb
change the value to whatever you need, 1 sector = 2048 bytes/2kb, try to keep it just one sector more then what you need to clear the cache, I've noticed setting it too high makes it just as innaccurate as leaving it unmodified.
Reply #176
so the value would depend on the cache of your specific drive? I wonder if there is a way to collect this information automatically from the drive and have it use that value?
IndieRockSteve
Reply #178
What do you recomend to use instead of 150!?
How do I know what my drive need!?
Reply #179
repackaged version 0.4.1 for rarewares/debian
available at the usual place... thanks again
later
Reply #180
I looked at Rubyripper just now. Good work on the UI, and the library.
The coding style is not 80 col friendly, and indentation suffers. Shell commands do the dirty work, instead of the more portable library extensions. There is no RLE hash implemented for audio sample data.
After all I don't think cdparanoia has seen an update in a long time, the method by which you re-read audio could be served by rbcdio.
Rubyripper is not what I have in mind, and so I am working on my own UI. The features I would like are ripping a disc, verifying, and encoding to FLAC. Making a UI is not my favorite thing to do. Teaser follows.
Besides the UI mockup I've got working code for reading album metadata from MusicBrainz, checking AccurateRip checksums, and platform portable cd reads. There are some key extensions features missing or only partially implemented. If anyone has an interest in contributing, the bits that need fleshing out are:
- rbcdio (add access to the paranoia interface, MMC interface)
- flac handling (metadata read and write, audio "each_byte" uncompressed)
Eric
Reply #181
Eric
Eric,
Do you where can I donwload the MAC OS X version?
Reply #182
Eric
Eric,
Do you KNOW where can I donwload the MAC OS X version?
Reply #183
Rubyripper is at version 0.4.3 in svn and can "talk" English, Dutch and German.
Best,
Morfeus
Edit: corrected misleading information and typos. Sorry for the confusion.
Reply #184
As far as I know 0.4.3 is not yet released. However latest svn is translated into dutch and german indeed. As main developer I oughta know when a release is made, right?
About the changes jnc is proposing. I'm looking forward to see the code. Rubyripper is released under GPL3 after all.
A secure audio ripper for linux: code.google.com/p/rubyripper
Reply #185
LOL
...that's confusing
Reply #186
Possibly stupid question.
Has anyone managed to get Ruby to rip from multiple CD drives simultaneously?  (running ubuntu if it matters)
I tried, it managed to create both sets of directories, but the 'non-default' instance crashed pretty quick.
Should it work?
Reply #187
Eric
i'm really interested in that. about the problems cdparanoia has, some on the net suggested to use libcdio instead. therefore rbcdio should be used if you're doing things in ruby. this stuff is quite new but if it works, then go for it
BUT. it is not a too good idea to duplicate efforts, like so many times in the foss scene...
so why don't you negotiate this and make something great, together. it would really boost development. you could easily make the best & safest gnu ripper ever. grip is dead, and sound juicer is just another simple frontend without anything advanced.
go guys go
Reply #189
Hello,
I'm new to Linux world and I wanted to try out your RubyRipper.
I have followed both RubyRipper wiki and your suggestion:
Now comes what works for me, just open up a terminal and do after me. First cd to the directory you saved ruby-freedb-0.5.tar.gz and then:
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb $ ls
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb $ tar xfz ruby-freedb-0.5.tar.gz
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb $ cd ruby-freedb-0.5
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb/ruby-freedb-0.5 $ ruby extconf.rb
checking for OS... linux
creating Makefile
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb/ruby-freedb-0.5 $ make
i686-pc-linux-gnu-gcc -fPIC -O2 -march=i686 -pipe -ftracer -fPIC -DOS_LINUX -I. -I/usr/lib/ruby/1.8/i686-linux -I/usr/lib/ruby/1.8/i686-linux -I. -c freedb_cdrom.c
i686-pc-linux-gnu-gcc -shared -L'/usr/lib' -Wl,-R'/usr/lib' -o freedb_cdrom.so freedb_cdrom.o -Wl,-R -Wl,/usr/lib -L/usr/lib -L. -lruby18 -lpthread -ldl -lcrypt -lm -lc
frodo@localhost ~/Desktop/Downloads/src/ruby-freedb/ruby-freedb-0.5 $ su
Password:
localhost ruby-freedb-0.5 # make install
The last step I haven't done, cause I've already installed it. Now it should get you started.
... but it doesn't work for me... I'm in the decompressed directory with RubyRipper
kejta@K8-desktop:~/Plocha$ cd rubyripper-0.5.3
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ make install
make: *** No rule to make target `install'.  Stop.
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ ruby-freedb-0.5.3 $ ruby extconf.rb
bash: ruby-freedb-0.5.3: command not found
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ rubyripper-0.5.3 $ ruby extconf.rb
bash: rubyripper-0.5.3: command not found
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ rubyripper_gtk2.rb
bash: rubyripper_gtk2.rb: command not found
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ rubyripper_cli.rb
bash: rubyripper_cli.rb: command not found
kejta@K8-desktop:~/Plocha/rubyripper-0.5.3$ make install rubyripper_cli.rb
make: *** No targets specified and no makefile found.  Stop.
I have no idea what am I doing wrong...?
Thanks in advance for any help.
Cheers, K8!
Sorry for my poor English, I'm trying to get better... ;)
"The greatest trick the Devil ever pulled, was convincing the world he didn't exist."
Reply #190
The Hydrogenaudio wiki is outdated. Follow the instructions on the README file and you should be fine.
Reply #191
I can update the page to include new information and link it to your Google Code page.
budding I.T professional
Reply #192
If you looked at the second code section from my command line you'll see, that I've tried to follow the readme. Unfortunately my GNU / Linux knowledge is too small to understand how to use make install or something like that.
Reply #193
I've checked the RubyRipper Google Code page and I haven't found any instructions regarding the instalation...
So, ReadMe is the only way and I have no idea how to accomplish the instalation.
Reply #194
You probably should mention the Linux distribution you use. I use Ubuntu and I could install Rubyripper fine using these instructions http://ubuntuforums.org/showthread.php?t=799621
The instructions in the "readme" are generic in order to work on any Linux system. I guess that once you have ruby (the ruby programming language interpreter) installed, it is in fact possible to run rubyripper directly from the code, i.e. without "installing":
Run from directory:
(1) ./rubyripper_gtk2.rb or
(1) ./rubyripper_cli.rb
from the directory where you untarred the archive.
Reply #195
@ chromium: I run Ubuntu Linux 8.04 LTS and when I doubleclicked the unTARed *.rb files nothing happened.
I have followed the instructions from either wiki or readme and installed also the dependency packages that were known to me.
Reply #196
Answering from the perspective of 10.2, this alone does not fix the problems in pre 10.2, although it does fix one of them.  That will cause it to always read the cache overfull, but if the next desired read location begins within the currently cached area, as will usually be the case when beginning the next large read section (last verified location- 16 sectors) you still get cached data
Reply #197
Thanks to the above mentioned instructions I finally made it!
It works like a charm:
This log is created by Rubyripper, version 0.5.3
Website: [url=http://code.google.com/p/rubyripper]http://code.google.com/p/rubyripper[/url]
Cdrom player used to rip:
HL-DT-ST DVDRAM GSA-4165B DL04
Cdrom offset used: 667
Ripper used: cdparanoia -Z
Matches required for all chunks: 2
Matches required for erroneous chunks: 2
Codec(s) used:
-mp3 -> -V 2 --vbr-new
(LAME 32bits version 3.97 (http://www.mp3dev.org/)
CDDB INFO
Artist = Savatage
Album = Gutter Ballet
Year = 1989
Genre = Metal
Tracks = 12
01 - Of Rage and War
02 - Gutter Ballet
03 - Temptation Revelation
04 - When the Crowds Are Gone
05 - Silk and Steel
06 - She's In Love
07 - Hounds
08 - The UnHoly
09 - Mentally Yours
10 - Summer's Rain
11 - Thorazine Shuffle
12 - All That I Bleed
STATUS
Starting to rip track 1, trial #1
Starting to rip track 1, trial #2
Analyzing files for mismatching chunks
Every chunk matched 2 times
MD5 sum: ddcaff7b28dae772e0edbf9af08778ec
Starting to rip track 2, trial #1
Starting to rip track 2, trial #2
MD5 sum: 3f62ff08b5f94023f37a9382d1a3c053
Starting to rip track 3, trial #1
Starting to rip track 3, trial #2
MD5 sum: 507f280a35b900a09a11e555ccd84cc2
Starting to rip track 4, trial #1
Starting to rip track 4, trial #2
MD5 sum: 01df52044de00c8e890abd23fdec296f
Starting to rip track 5, trial #1
Starting to rip track 5, trial #2
MD5 sum: 0abc972e7b58bd86d14ba726f7cff08c
Starting to rip track 6, trial #1
Starting to rip track 6, trial #2
MD5 sum: 61078782e9f3a0cf594e0711a28f2f97
Starting to rip track 7, trial #1
Starting to rip track 7, trial #2
MD5 sum: 46f76024fb48f399f82fafd8a932cc72
Starting to rip track 8, trial #1
Starting to rip track 8, trial #2
MD5 sum: 45eef43445f0e1c7580dfc0b70421093
Starting to rip track 9, trial #1
Starting to rip track 9, trial #2
MD5 sum: 06d422614f8239fe53f6fb8a5e6a8908
Starting to rip track 10, trial #1
Starting to rip track 10, trial #2
MD5 sum: 08eac61dceb0295e3aebc5fd7e3d272e
Starting to rip track 11, trial #1
Starting to rip track 11, trial #2
MD5 sum: 9007714af78a1989582688658305a986
Starting to rip track 12, trial #1
Starting to rip track 12, trial #2
MD5 sum: 5169a5df71a02c3b28d63a043a34e301
RIPPING SUMMARY
All chunks were tried to match at least 2 times.
None of the tracks gave any problems
Thank you very much!
I wish there was an available binary for Lame 3.98 ...
Edit: I haven't found any TAGing option, I want to use just ID3V1.1 TAGs, not the ID3V2.3 . Is it possible?
Reply #198
Add --id3v1-only to your command-line options.
Reply #199
You mean in "Preferences > Codecs > Lame Mp3" add:
-V 2 -Y --id3v1-only
...right?
