Topic: foo_autofield (Read 2804 times) previous topic - next topic
foo_autofield
Hello.
With the help of foosion, I've done my first little foobar2000 component.
It's an action added in masstagger to autonumber any wanted field.
The options windows contains 2 entrys :
- The field to put number
- The grouping pattern
The usage is simple, the script works like autotracknumber, but the number is writen into the specific field. When pattern differs between two tracks, numbering restarts to 1.
The file is here :  http://membres.lycos.fr/soltan/foo_autofield.dll
The source here : http://membres.lycos.fr/soltan/foo_autofield.rar
foo_autofield
Thank you
Without having tested it, the pattern for a directory-based numbering should be:
$left(%_path%,$sub($len(%_path%),$add($len(%_filename_ext%),1)))
foo_autofield
Hello,
There is a way to do that with actual FB version and available pluggins?
