Topic: Joining multiple files into a single mp3? (Read 9114 times) previous topic - next topic
Is it possible to join/concat multiple files into a single mp3 file using LAME? prefarbly using a wildcard (i.e - c:\temp\*.wav ==> c:\temp\combined.mp3)
[a href="index.php?act=findpost&pid=336395"][{POST_SNAPBACK}][/a]
The only solution I've found is to rip multiple tracks from a CD into a single file using Adobe Audition.  From Audition's File menu -> Extract Audio From CD and put a check in the box labeled "Extract to Single Waveform".  Save as a WAV and convert that to MP3 with LAME.  Of course Audition doesn't do secure ripping like EAC, but then I haven't been able to find a way to do it in EAC.  If anyone knows I'd be interested in hearing about it too.
If you want to combine multiple WAV files that are already on your drive you could use any NLE like Adobe Audition or Sound Forge to combine them into a single new WAV file, and then encode that with LAME as noted above.  Or if there's an editor that supports LAME natively you could avoid the intermediate step of saving to WAV, but I'm not sure if any editors have that support.
It sounds like Carnivore's solution involves decoding and then re-encoding (so, transcoding). This is straightforward, and you could do it with any decoder --> wave editor --> Lame.
However, if you want to join mp3's without quality loss, you should stay away from transcoding. The main option would be to use mp3directcut to join mp3's in a stream. You might need to use mptrim or foobar to repair the header afterwards.
God kills a kitten every time you encode with CBR 320
Encode the WAV files using the --nogap option (--> see lame --longhelp)
Be careful not to use any tags!
After that you can copy the files together:
copy /b file1.mp3 + file2.mp3 ... + filex.mp3 result.mp3
Foobar2000 has "Run Conversion, single file output" for multiple selected files.
If you replace the standard diskwriter component with the one modified by Synthetic Soul (version 2.1.3 here), it will also spit out a nice cuesheet.
Cheers
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
There is also another way to join multiple MP3 files: you can use WinZip (or WinRAR) adding the files to an archive (without compression) and renaming the file to .mp3. Now the file will be playable and the files can be splitted in any moment renaming the .mp3 back to .zip.
Howewer it's an old trick and I don't remember how to set the right order of the files to be merged. You cannot TAG the resulting file, too.
[ Commodore 64 Forever...! ]
[a href="index.php?act=findpost&pid=337347"][{POST_SNAPBACK}][/a]
Except for the splitting part, this just looks like a bad way to do a "copy /b a.mp3 + b.mp3 new.mp3" ....
Does this work with any player, or is it just foobars archive reader kicking in?
Kristian
I tested (and it works with) Windows Media Player 10 and Winamp
I'm embarrassed to have to ask this, but in using LAME help, what is the switch that is equivalent to the DOS /p switch so that only one page of information is shown at a time?
LAME --longhelp | more
[a href="index.php?act=findpost&pid=337471"][{POST_SNAPBACK}][/a]
Just pipe it through the 'MORE' filter.
lame --lognhelp | more
You coule also redirect help to a text file.
lame --lognhelp > lame.txt
You could read the text file with any editor.
Thanks guys, much appreciated.
[a href="index.php?act=findpost&pid=337441"][{POST_SNAPBACK}][/a]
no added gap between tracks?
Sergio
Appending process using matroska tools :
1. Convert all MP3 to MKA with mkvmerge/mmg or amg
2. append the MKA
3. extract the MP3 from the final MKA with mkvextract.exe (mkvextractgui)
Christian
matroska project admin
http://www.matroska.org
<hypothetical>
Let's assume a simple program exists, which strips RIFF headers off from .wav files, and outputs raw PCM samples to stdout. Let's call that program wavcat. If the .wav files don't have raw PCM inside, or if there are problems, then wavcat exits with an error code, and outputs EOF.
wavcat *.wav | lame -r -s 44100 -m j - out.mp3
</hypothetical>
I always set the default DOS box to 2000 lines/160 columns. So almost every output fits well
