Topic: Winamp2 Problems (Read 3111 times) previous topic - next topic
Winamp2 Problems
I am unable to play my audio cds .cda in winamp2 whats going on.  The audio cd actually plays because I can see the seek bar moving, but theres no sound.  Help!
Winamp2 Problems
Two choices:
1. Connect the audio cable from the CD-ROM to the audio card...
2. Download the digital playback plugin for Winamp from Winamp's plugin site...
Winamp2 Problems
Or CD Audio is simply muted or at 0%, check the mixer .
Winamp2 Problems
hmm
This is a bit of a mystery
Winamp2 Problems
You won't get any audio with Winamp and the standard CD-Audio plugin unless you connect the audio connector from the CD-ROM to the sound card... Trust me... B)
Winamp2 Problems
Maybe you should try the plugin cd-reader...
Winamp2 Problems
CDReader Plugin for Winamp
What papadoc said.
Be sure to read the documentation fully - you will need to disable winamp's default CD plugin first.  This is really easy, just rename c:\program files\winamp\plugins\in_cdda.dll to ...\in_cdda.dll.off.  Easy!
[span style=\'font-size:9\']\"Do not go gentle into that good night,
Rage, rage against the dying of the light\"[/span]
