Topic: Creating a Speex Recorder (Read 3472 times) previous topic - next topic
  • lda_mdc
I'm trying to create a speex recording app for Windows Mobile Pocket PCs. My PPC mic can record waveform audio at 8 kHz, 16 bits per sample so I'm using the narrowband mode of speex.
Which (constant) bit rates would you recommend I use for encoding to speex? I'm planning to provide options called Poor, Good and Best (quality) respectively or something like it for the less tech-savvy. =)
Also, if you guys have seen any open-source speex recorders for Pocket PC's I'd appreciate the tip. I'm in this more for learning how to program than just using the recorder, though i honestly can't wait to have a spx recorder on my device.
thanks everyone!
  • hazza
Not open source or even free but Resco Audio Recorder can record into Speex.  Should give you some ideas on bit rates.
A free equivalent would be good to see though.
