could it be possible to have the field COPYRIGHT shown in the DATE field? (something like a redirection of meta fields)
i'd like to see the date of a playing sid and if it has a field like "COPYRIGHT = 1993 Lamex"
it would be cool to redirect this info (maybe with some regEx...) to another field, like DATE.
@fuffi: Wouldnt it be possible to play around with the string-manipulation-functions listed in the document above to get your date-field?
Quite a long time passed, but i finally made it :-)
in ColumnUI, i set up the Comment-column with this display-script:
$if($stricmp($ext(%filename_ext%),SID),$if([%COPYRIGHT%],$trim($substr([%COPYRIGHT%],5,$len([%COPYRIGHT%]))),---),[%COMMENT%])
and
this data-script:
$if($stricmp($ext(%filename_ext%),SID),$if([%COPYRIGHT%],$cut([%COPYRIGHT%],4),----),[%DATE%])
which both will now, if the file has an extension "SID", split the %COPYRIGHT% field into the DATE part and a COMMENT part.
![](http://www.bilder-hochladen.net/files/8p2s-5x.png)
this looks ok to me :-) and i ignore such special cases like "1970-71" ...
