Topic: Lossless audio compression with VirtualDub? (Read 6605 times) previous topic - next topic
  • Digisurfer
Hey all, quick question. I Just entered the world of video capture recently and am wondering if there are any lossless audio codecs that work with VirtualDub for capture. Thanks!
  • stephanV
Nope, PCM is your only choice.
"We cannot win against obsession. They care, we don't. They win."
  • Digisurfer
[a href="index.php?act=findpost&pid=325087"][{POST_SNAPBACK}][/a]
Thanks, figured as much. How about transcoding the PCM to (for example) Wavpack, and then replacing the PCM audio track in the video file with it? I know there are Directshow filters for the playback of Wavpack and FLAC (haven't checked the others) so playing the final file shouldn't be a problem.
  • stephanV
You can do that (FLAC, Wavpack or TTA) if you don't mind using Matroska. With AVI no such thing is possible.
  • Digisurfer
[a href="index.php?act=findpost&pid=325330"][{POST_SNAPBACK}][/a]
Great, thanks for the heads up. Learning as I go, hehe.
  • Digisurfer
One more quick question. If PCM is my only choice, why are there compression options, including MP3? I can even install the Directshow filters that come with LAME and use those in VirtualDub as well. Not trying to be a pain, only trying to understand. Thanks again!
  • stephanV
I meant to say: If you want to have lossless audio, PCM is your only choice.
Using MP3 is of course possible (watch out to not use ABR/VBR modes, as they wouldn't work in VirtualDub also), but that wouldn't be lossless.
  • Last Edit: 07 September, 2005, 07:14:29 AM by stephanV
  • isidro
From here: http://forum.videohelp.com/threads/343407-...l=1#post2188956
Now you can import it.
First remux the flac file to mkv (using mkvmerge) then import with the Matroska input plugin: http://forums.virtualdub.org/index.php?act...f=7&t=19488
(and Use Audio Direct Stream Copy to generate AVI even if you can't hear it in vdub)
