Topic: Can't encode ac3 to ogg (Read 3944 times) previous topic - next topic
Hi
I had 2 ac3 files which I joined together using the following script in cmd:
copy audio1.ac3 + audio2.ac3 /b
Now when I try to encode the new audio1.ac3 it gives me an error halfway through the encoding process?
Is there a fix or a way around this problem?
Ax
  • john33
I would guess that ac3 doesn't accomodate file chaining in that manner. However, ogg vorbis does, so why don't you just transcode the separate files and then chain the ogg files as you're trying to do with the ac3 files.
John
My compiles and utilities are at http://www.rarewares.org/
  • riggits
Hi
Ax
[a href="index.php?act=findpost&pid=325034"][{POST_SNAPBACK}][/a]
You concatenated two files, each with their own header information.....
An easy way to do it right:  use foobar2000, select both files and convert with Single File Output.
I deleted the original 2 ac3 files, is it possible to extract them again from the 1 ac3 file I have now?
  • rjamorim
Yes, if you're really good at hex editing...
Get up-to-date binaries of Lame, AAC, Vorbis and much more at RareWares:
  • Gambit
I was bored, so I wrote this:
http://www.burrrn.net/stuff/AC3.exe
Select the joined file and click "Split". If successful, you will get the original two files.
It's just my modified AC3 test application, but it should work. It's pretty simple, it scans the file and splits from the frame that has a different bitrate/samplerate/channels number.
  • Last Edit: 11 September, 2005, 11:35:28 PM by Gambit
Burrrn - http://www.burrrn.net/
MPEG Audio Collection - http://mac.sourceforge.net/
Thanks for that program.
I tried it and it does not seem to find the join.  So I clicked "scan" instead and it gave the following results:
Does this mean that it could not find the join?
Thanks again
Ax
  • Gambit
Sorry, you will have to split it manually. Try decoding the file and split at the position where you get the error. You can use BeSplit, or I can upload a modified version of my tool that can split manually.
  • Last Edit: 18 September, 2005, 11:43:47 AM by Gambit
Please can you upload a modified version of your program!
But don't do it if its gonna take to long.  If its a simple thing for you to do then excellent!
