Topic: madxlib (Read 2668 times) previous topic - next topic
madxlib
I'd like to announce the availability of "madxlib" a C/C++ source code to create a Windows DLL that performs buffer-based MP3 decoding. It allows you to process a given MP3 file in chunks at intervals you specify, and returns the decoded 16-bit PCM samples in a buffer. It uses the powerful open source library libmad for MP3 decoding.
Features:
- Decode from MP3 to PCM or WAV
- Fast, high quality decoding using libmad library
- Flexible buffer based calling mechanism
- Use it to build file-to-file conversion utilities, players, or streaming servers
- Example sources, including C# example
- Download source or pre-compiled demo+DLL
Most current release will always be referenced from http://www.arbingersys.com/concerns.html#madxlib
