Topic: LyricsDB discussion (Read 424843 times) previous topic - next topic
LyricsDB discussion
Reply #150
http://foobar.s53.xrea.com/up/
panel version. maybe both authors should team up.
some limitations/bugs such as no auto-loading of lyrics,
no highlighting of the current line, and some other minor
things. this was posted in another thread by another user.
Right now, get the lyrics from this plugin in this forum, then
you have to use the panel plugin and reload the lyrics and
it then works fine.
LyricsDB discussion
Reply #151
Couple crashes in 0.9.1 with this version. Also if you select a large group of files, lyricsdb will not always correctly add the lyrics to the file, not sure why this occurs, even if there are lyrics and the processing still occurs.
Also you have some spelling errors "Aply > Apply"
You should have the plugin say "connected to Database but lyrics not found" instead of "it works but there are no lyrics" just doesn't look professional.
Here's the crash dumps, although they won't be that helpful.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 018137D9h
Access violation, operation: read, address: 2778C294h
Call path:
entry=>app_mainloop
Code bytes (018137D9h):
01813799h:  01 8B 50 0C 6A 00 FF D2 8B 0F 8B 55 20 50 8D 44
018137A9h:  24 24 50 8D 0C 8A 51 8B C4 C7 00 00 00 00 00 8B
018137B9h:  09 85 C9 89 64 24 28 89 08 74 07 8B 01 8B 50 04
018137C9h:  FF D2 8B 4C 24 24 E8 8C 78 00 00 8B 07 8B 4D 20
018137D9h:  8B 0C 81 8B 11 8B 42 18 FF D0 C6 84 24 5C 01 00
018137E9h:  00 00 8B 4C 24 14 85 C9 74 06 8B 11 8B 02 FF D0
018137F9h:  8D 4C 24 1C 51 C7 84 24 60 01 00 00 FF FF FF FF
01813809h:  E8 B2 80 00 00 83 7F 0C 00 0F 84 8F 00 00 00 8B
Stack (0012F798h):
0012F778h:  0117DE20 7C9C93A0 77F643DD 7C9C93A0
0012F788h:  00000004 00000000 0117D32C 00000000
0012F798h:  AB2D77FD 01847880 0012F934 07E48E38
0012F7A8h:  7C9105C8 004CCA58 0012F788 018232A8
0012F7B8h:  0184E3E8 07E526B0 00000001 0184B588
0012F7C8h:  00000001 00000000 01848040 07E4B078
0012F7D8h:  00000001 07E52840 00000001 00000000
0012F7E8h:  07E51C30 07E56F88 00000001 018486B8
0012F7F8h:  00000001 00000000 07E407B8 0184D200
0012F808h:  00000001 07E4D458 00000001 00000000
0012F818h:  0184D8D8 07E4BF48 00000001 018493D8
0012F828h:  00000001 00000000 07E5A680 07E5BD38
0012F838h:  00000001 0184F3F8 00000001 00000000
0012F848h:  07E58E68 07E5B4F8 00000001 01848F20
0012F858h:  00000001 00000000 07E573B8 07E42810
0012F868h:  00000001 0184C650 00000001 00000000
0012F878h:  FFFFFFFF 7C91056D 78134B9F 01840000
0012F888h:  00000000 78134BBE AB2EA9BE 01847880
0012F898h:  07E526B0 07E48E38 01840000 00000000
0012F8A8h:  00000008 0184CE98 00000001 00000000
Registers:
EAX: 07E4BF60, EBX: 002A00E0, ECX: 07E5C514, EDX: 004CFFA0
ESI: 0012F7AC, EDI: 0184D8E8, EBP: 01847880, ESP: 0012F798
Crash location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004E0000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D2000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00A10000h - 00A44000h
foo_ac3                          loaded at 00A50000h - 00A7C000h
foo_albumlist                    loaded at 00AA0000h - 00AE1000h
foo_audioscrobbler              loaded at 00B10000h - 00B3B000h
libcurl                          loaded at 00B50000h - 00BA0000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_bitcompare                  loaded at 00C50000h - 00C76000h
foo_burninate                    loaded at 00CA0000h - 00CD6000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00D00000h - 00D2D000h
foo_channel_mixer                loaded at 00D50000h - 00D8A000h
foo_common                      loaded at 00DA0000h - 00DD9000h
foo_converter                    loaded at 00E00000h - 00E61000h
foo_dbsearch                    loaded at 00E90000h - 00EE9000h
foo_dsp_atsurround              loaded at 00F10000h - 01005000h
foo_dsp_bs2b                    loaded at 01140000h - 0115E000h
foo_dsp_continuator              loaded at 01180000h - 011B2000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_dsp_crossfeed                loaded at 011E0000h - 01204000h
foo_dsp_delta                    loaded at 01230000h - 0124E000h
foo_dsp_ssrc                    loaded at 01270000h - 012A3000h
foo_dsp_std                      loaded at 012C0000h - 012FF000h
foo_dsp_tube                    loaded at 01320000h - 01343000h
foo_dsp_vlevel                  loaded at 01360000h - 01384000h
foo_dumb                        loaded at 013B0000h - 0140F000h
foo_freedb2                      loaded at 01430000h - 01470000h
foo_gep                          loaded at 01490000h - 01527000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_infobox                      loaded at 01550000h - 0158E000h
foo_input_shorten                loaded at 015B0000h - 015DE000h
foo_input_std                    loaded at 01600000h - 01713000h
foo_lnk                          loaded at 01740000h - 01759000h
foo_lock                        loaded at 01780000h - 01799000h
foo_lunar2                      loaded at 017C0000h - 017E2000h
foo_lyricsdb                    loaded at 01810000h - 0182E000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
WININET                          loaded at 771B0000h - 77259000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_masstag                      loaded at 01850000h - 018A0000h
foo_osd                          loaded at 018C0000h - 018F6000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_out_asio                    loaded at 01940000h - 0196E000h
foo_out_ks                      loaded at 01990000h - 019BB000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playlist_manager            loaded at 019E0000h - 01A25000h
foo_playlist_name_enhanced      loaded at 01A50000h - 01A6F000h
foo_pqview                      loaded at 01A90000h - 01AAC000h
foo_prettypop                    loaded at 01AD0000h - 01B1E000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_psf                          loaded at 04070000h - 04153000h
foo_rgscan                      loaded at 04160000h - 041A4000h
foo_sid                          loaded at 041B0000h - 04230000h
foo_tradersfriend                loaded at 04250000h - 0428D000h
foo_uie_albumart                loaded at 042B0000h - 042E0000h
foo_uie_albumlist                loaded at 04300000h - 0433F000h
foo_uie_console                  loaded at 04360000h - 0437C000h
foo_uie_lyrics_panel            loaded at 043A0000h - 04403000h
foo_uie_trackinfo                loaded at 04430000h - 0445E000h
foo_ui_columns                  loaded at 04480000h - 0451B000h
foo_ui_std                      loaded at 04540000h - 04597000h
foo_unpack                      loaded at 045C0000h - 045EE000h
foo_utils                        loaded at 04610000h - 04649000h
dciman32                        loaded at 73BC0000h - 73BC6000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
imon                            loaded at 20B00000h - 20B45000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
NTMARTA                          loaded at 77690000h - 776B1000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
ksuser                          loaded at 73EE0000h - 73EE4000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
mlang                            loaded at 75CF0000h - 75D81000h
msdmo                            loaded at 736B0000h - 736B7000h
wmadmod                          loaded at 08120000h - 08184000h
msxml3                          loaded at 74980000h - 74AB0000h
WINHTTP                          loaded at 4D4F0000h - 4D548000h
Secur32                          loaded at 77FE0000h - 77FF1000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
rtutils                          loaded at 76E80000h - 76E8E000h
msv1_0                          loaded at 77C70000h - 77C93000h
iphlpapi                        loaded at 76D60000h - 76D79000h
sensapi                          loaded at 722B0000h - 722B5000h
USERENV                          loaded at 769C0000h - 76A73000h
urlmon                          loaded at 77260000h - 77300000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 004CCA58h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 018232A8h, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 78134B9Fh, location: "MSVCR80", loaded at 78130000h - 781CB000h
Symbol: "free" (+000000CDh)
Address: 78134BBEh, location: "MSVCR80", loaded at 78130000h - 781CB000h
Symbol: "free" (+000000ECh)
Address: 0182327Ch, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 01812378h, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 01820D48h, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 01813BAAh, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 018138D0h, location: "foo_lyricsdb", loaded at 01810000h - 0182E000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 01A54C69h, location: "foo_playlist_name_enhanced", loaded at 01A50000h - 01A6F000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D541E2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D484FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485A4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D54204h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 004CC810h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF0D4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042B63Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042C0C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF7ACh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C910E12h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000383h)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B20F8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004D11C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004D12A0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C917CB7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 1000D469h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10003C9Eh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+0000003Eh)
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 004D1230h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483574h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00483085h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B05C8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 10002D77h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 0049F7FBh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042C29Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004CE2A8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00489035h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483409h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483403h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A3045h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00488720h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049F9EFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00487605h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0048766Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
Database search 1.3.1 beta 10  (foo_dbsearch)
ABX comparator 1.3  (foo_abx)
Live show tagger 0.6.1  (foo_tradersfriend)
AC3 decoder 0.7  (foo_ac3)
Audio CD Writer 2.0  (foo_burninate)
Pause on Lock 0.4  (foo_lock)
Audioscrobbler 1.2.8  (foo_audioscrobbler)
VLevel 20060324.0  (foo_dsp_vlevel)
Pretty Popup 1.2.2  (foo_prettypop)
DUMB module decoder 0.9.7  (foo_dumb)
Standard input array 1.0  (foo_input_std)
Lyrics panel 0.33.3  (foo_uie_lyrics_panel)
ReplayGain Scanner 2.0  (foo_rgscan)
Playlist tools 0.5.5  (foo_utils)
ZIP/GZIP reader 1.0  (foo_unpack)
RAR reader 1.1  (foo_unpack)
Tube Sound 0.5  (foo_dsp_tube)
Playlist Manager 1.0  (foo_playlist_manager)
Channel Mixer 0.9.4  (foo_channel_mixer)
Converter 1.0  (foo_converter)
Default User Interface 0.9acc  (foo_ui_std)
Kernel Streaming Output 1.2.1  (foo_out_ks)
Console panel 0.2  (foo_uie_console)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
foo_lyricsdb 0.7 beta 0  (foo_lyricsdb)
Common services 0.1  (foo_common)
Special file info box v2.0.0  (foo_infobox)
Lunar 2 PCM decoder 0.5  (foo_lunar2)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
CD Audio decoder 2.0  (foo_cdda)
Shell link resolver 1.1  (foo_lnk)
sidplay2 1.13  (foo_sid)
Album Art Panel 0.164a  (foo_uie_albumart)
ATSurround Processor 0.1.3  (foo_dsp_atsurround)
On-Screen Display GDI+ 1.52  (foo_osd)
freedb tagger v0.5  (foo_freedb2)
Track info panel 0.8  (foo_uie_trackinfo)
Playlist Name Enhanced 1.1  (foo_playlist_name_enhanced)
Highly Experimental 2.0.5  (foo_psf)
Crossfeed 0.70  (foo_dsp_crossfeed)
Standard DSP array 1.0  (foo_dsp_std)
Continuator 0.4.0  (foo_dsp_continuator)
Album List 3.2.0  (foo_albumlist)
bs2b 2.0.0b2  (foo_dsp_bs2b)
Resampler DSP (SSRC) 0.53 SSE  (foo_dsp_ssrc)
Game Emu Player 1.3  (foo_gep)
FLAC decoder 1.1.0  (foo_input_std)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
MPEG-4 AAC decoder 2.1  (foo_input_std)
Binary comparator 1.0  (foo_bitcompare)
Masstagger 1.5  (foo_masstag)
Shorten decoder 0.4.2a  (foo_input_shorten)
LyricsDB discussion
Reply #152
Other than the "aplly" spelling error (  ) it looks and works great for me.
EDIT: One quick question though, I have the lyrics displaying in a track info panel using this string:
0CEBA4Lyrics$char(10)$char(10)
D7B997%title% by D7B997%artist%$char(10)$char(10)$replace(%lyrics%,$char(13),)
And the question is, what do I need to add to have it not display "?" when there are no lyrics available?
foobar2000 + EAC + Burrrn = Happiness
LyricsDB discussion
Reply #153
Does it crash on different tracks every time? Are you using beta0, or beta1 crashes too?
I've tryed to run the plugin on groups of files and it worked for me... What setting do you use to store lyrics? Preview window with apply to all, right? It does matter...
And you are not first, who noticed, that plugin misses some lyrics from time to time, I'll try to find why, thanks for the reports.
p.s. Thanks for noticing spelling errors too, it'll be fixed in next version (fixed in developing version already).
update
got it crahed myself, will investigate
dezisehtnys eb lliw noitulover eht
LyricsDB discussion
Reply #154
Will there be a version which downloads and saves the lyrics as .lrc-file?
LyricsDB discussion
Reply #155
Just after already existing funcions will be stable and perform what they should. That feature was requested a couple of times, so I will add it, yes.
LyricsDB discussion
Reply #156
this is my script, without the "?" (basically the same as yours, but i'm using  the %unsynced lyrics% field
FF8000%title% by FF8000%artist%$char(10)$char(10)[$replace(%unsynced lyrics%,$char(13),)]
so just add the brackets [ ]
LyricsDB discussion
Reply #157
can i request to output to a %artist% - %title%.txt into a default directory
this is how evillyrics worked and i got accustomed to it
i play alot of mp3s over a network, which i dont have write access to, so i can't write to the lyrics tag, which is why id like the saving to a txt file
LyricsDB discussion
Reply #158
can i request to …
sure you can
guys, just let me make stable version of the plugin and first thing that I'll do - that feature (storing to the file)
LyricsDB discussion
Reply #159
it then works fine.
Thanks very much, will try out soon.
Break The Rules!!!
LyricsDB discussion
Reply #160
That's a great plugin, combined with lyrics panel, it's perfect  Just one thing, but I don't know if someone even say you : when i'm trying to import lyrics for several files, quickly a bug comes, and the importing and tagging operation stop  I wana import all my database lyrics in one shot  Does that's possible??
LyricsDB discussion
Reply #161
Just wait for a buxfix version this version is a little unstable at the moment.
LyricsDB discussion
Reply #162
just gonna say i really appreciate you for making this, been waiting for a long time for a good lyrics panel for foobar, and its awesome so far
LyricsDB discussion
Reply #163
how do i use the foo_uie_lyrics_panel for foobar v0.9.1 to retrieve lyrics file under my directory of C:\Program Files\foobar2000\Lyrics ?
do i have to change the string
LyricsDB discussion
Reply #164
when i exit foobar2000 it pops a warning window saying: "metadb_handle leaks: x objects" where x is the number of songs that ive played that session
does any1 knows how to fix this problem?
LyricsDB discussion
Reply #165
You're right on time, this has been fixed in foo_uie_trackinfo 10minutes ago ( link here ). Although if you didn't use trackinfo or if you still have leaks, you should report it again.
LyricsDB discussion
Reply #166
Fixed
thx a lot m8
LyricsDB discussion
Reply #167
OK, I am still very much a rookie to the FOOBAR world and I am having a problem. I have the plugin installed and configured correctly, but I cannot figure out how to make it actually display on my FOOBAR. When I right click on the toolbar, it is not one of the panels options. I can't figure out how to make this plugin display. Can someone please explain to me?
LyricsDB discussion
Reply #168
What plugin? LyricsDB doesn't have any pannel/toolbar whatever. It has only three sontext-menu commands (right mouse click on the track).
LyricsDB discussion
Reply #169
OHHH ok, thats what I have been confused about. Because I have seen on some custome FOOBAR's a panel that is displaying lyrics. I did install the    foo_uie_lyrics_panel plugin, but I can't get that to display either
LyricsDB discussion
Reply #170
You use LyricsDB to download (or upload) lyrics. To view them you have to use another plug-in, for example foo_uie_trackinfo (if your interface of choice is columns_ui).
HTH.
Alessandro
LyricsDB discussion
Reply #171
hi i just downloaded lyrics plugin and i'cant download lyrcs. i get information which says: "some networks problems aborting.. can anyone help?
LyricsDB discussion
Reply #172
I unfortunatelly had a crash while tagging:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 30322049h
Access violation, operation: read, address: 30322049h
Call path:
entry=>app_mainloop
Stack (0012F608h):
0012F5E8h:  00000000 0000000C BC69FE68 00DCFE60
0012F5F8h:  00009169 F76BAB60 00009169 F76BAD38
0012F608h:  00F92A4F 3793B579 0012F804 00F923D0
0012F618h:  00000000 048C5150 0012F5FC FFFFFFFF
0012F628h:  00FA2CA0 00000000 00000000 00000000
0012F638h:  00FA2CA0 00000000 00000000 00000000
0012F648h:  004CCA58 007E2DD0 00FA32D8 003E6D20
0012F658h:  048C1A20 00000001 003EAC88 00000001
0012F668h:  00000000 003E6160 048BECB8 00000001
0012F678h:  048B5008 00000001 00000000 003E6180
0012F688h:  003EBE10 00000001 003EB0D0 00000001
0012F698h:  00000000 048BEC88 048C19C0 00000001
0012F6A8h:  003E6170 00000001 00000000 048A05D8
0012F6B8h:  003E4AD8 00000001 048B1B38 00000001
0012F6C8h:  00000000 003EE808 003ED428 00000001
0012F6D8h:  048A0740 00000001 00000000 048C0260
0012F6E8h:  003EBD48 00000001 048B0F90 00000001
0012F6F8h:  00000000 003EBDE0 048B3FF0 00000001
0012F708h:  003E6150 00000001 00000000 773C9408
0012F718h:  0000800A 0051034E FFFFFFFC 00000000
Registers:
EAX: 30322049, EBX: 005903EC, ECX: 048C04B8, EDX: 048C0230
ESI: 048C5150, EDI: 048C32F0, EBP: 0012F79C, ESP: 0012F608
Unable to identify crash location
Loaded modules:
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 773A0000h - 774A3000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1EF000h
ole32                            loaded at 774B0000h - 775ED000h
comdlg32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
LPK                              loaded at 62E10000h - 62E19000h
USP10                            loaded at 75790000h - 757FB000h
lgscroll                        loaded at 10100000h - 1010F000h
NTMARTA                          loaded at 77660000h - 77681000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
SAMLIB                          loaded at 71B70000h - 71B83000h
msctfime                        loaded at 75250000h - 7527E000h
foo_amipwrapper                  loaded at 009D0000h - 009F6000h
foo_autoplaylist                loaded at 00A20000h - 00A52000h
foo_burninate                    loaded at 00A80000h - 00AB6000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_channel_mixer                loaded at 00AE0000h - 00B1A000h
foo_common                      loaded at 00B30000h - 00B6A000h
foo_converter                    loaded at 00B90000h - 00BF1000h
foo_dbsearch                    loaded at 00C20000h - 00C7C000h
foo_dsp_continuator              loaded at 00CA0000h - 00CD2000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
foo_dsp_delta                    loaded at 00D00000h - 00D1E000h
foo_dsp_silence                  loaded at 00D40000h - 00D69000h
foo_dsp_std                      loaded at 00D90000h - 00DCF000h
foo_freedb2                      loaded at 00DF0000h - 00E30000h
foo_input_std                    loaded at 00E50000h - 00F63000h
foo_lyricsdb                    loaded at 00F90000h - 00FAE000h
WININET                          loaded at 77180000h - 7722A000h
CRYPT32                          loaded at 77A50000h - 77AE5000h
MSASN1                          loaded at 77AF0000h - 77B02000h
foo_masstag                      loaded at 00FC0000h - 01010000h
foo_osd                          loaded at 01030000h - 01066000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
foo_playcount                    loaded at 010B0000h - 010D8000h
foo_pqview                      loaded at 01100000h - 0111C000h
foo_rgscan                      loaded at 01140000h - 01184000h
foo_sic                          loaded at 011B0000h - 011E4000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
foo_uie_albumart                loaded at 01210000h - 01240000h
foo_uie_albumlist                loaded at 01260000h - 0129F000h
foo_uie_explorer                loaded at 012C0000h - 012FD000h
UxTheme                          loaded at 5B0F0000h - 5B128000h
foo_uie_trackinfo                loaded at 01320000h - 0134E000h
foo_ui_columns                  loaded at 01370000h - 0140B000h
foo_utils                        loaded at 01430000h - 01469000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E3000h
dciman32                        loaded at 73B30000h - 73B36000h
amip                            loaded at 02350000h - 024FC000h
DSOUND                          loaded at 73E70000h - 73ECC000h
WINMM                            loaded at 76AF0000h - 76B1E000h
serwvdrv                        loaded at 5D100000h - 5D107000h
umdmxfrm                        loaded at 5B420000h - 5B427000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
wdmaud                          loaded at 72C90000h - 72C99000h
msacm32                          loaded at 72C80000h - 72C88000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
KsUser                          loaded at 73E40000h - 73E44000h
shook45                          loaded at 015E0000h - 015E8000h
msxml3                          loaded at 74900000h - 74A30000h
WINHTTP                          loaded at 4D5C0000h - 4D618000h
mswsock                          loaded at 719B0000h - 719F0000h
DNSAPI                          loaded at 76EE0000h - 76F07000h
rasadhlp                        loaded at 76F80000h - 76F86000h
hnetcfg                          loaded at 66710000h - 66769000h
wshtcpip                        loaded at 719F0000h - 719F8000h
Secur32                          loaded at 77FC0000h - 77FD1000h
urlmon                          loaded at 77230000h - 772CE000h
wsock32                          loaded at 71A30000h - 71A3A000h
RASAPI32                        loaded at 76EA0000h - 76EDC000h
rasman                          loaded at 76E50000h - 76E62000h
NETAPI32                        loaded at 597D0000h - 59825000h
TAPI32                          loaded at 76E70000h - 76E9F000h
rtutils                          loaded at 76E40000h - 76E4E000h
msv1_0                          loaded at 77C40000h - 77C63000h
iphlpapi                        loaded at 76D20000h - 76D39000h
sensapi                          loaded at 72240000h - 72245000h
USERENV                          loaded at 76620000h - 766D5000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
Address: 00F92A4Fh, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 00F923D0h, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 00FA2CA0h, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 00FA32D8h, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 773C9408h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000D580h)
Address: 773C8E8Ch, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000D004h)
Address: 773C9998h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000DB10h)
Address: 00FA32ACh, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 773C8EC0h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000D038h)
Address: 00FA0C8Eh, location: "foo_lyricsdb", loaded at 00F90000h - 00FAE000h
Address: 77D18744h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D24ECBh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PostQuitMessage" (+0000027Ah)
Address: 77D4046Fh, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D24EF0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PostQuitMessage" (+0000029Fh)
Address: 77D24D17h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PostQuitMessage" (+000000C6h)
Address: 77D1B51Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 77D18840h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D24C98h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PostQuitMessage" (+00000047h)
Address: 77D194CEh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D1D4F4h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D1B913h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SendMessageW" (+00000049h)
Address: 773C732Ch, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000B4A4h)
Address: 773C740Eh, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000B586h)
Address: 773C9713h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0000D88Bh)
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 77D1F818h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 77D1F96Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 101076D0h, location: "lgscroll", loaded at 10100000h - 1010F000h
Symbol: "UninstallScrollHooks" (+00000FD0h)
Address: 77D1F829h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 77D18826h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D189DDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D31B55h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 77D18A00h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D18A20h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D23635h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042B519h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042B621h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D1DAFAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 7C921BFFh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlInitializeCriticalSection" (+000000D2h)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C927CB7h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 1000D533h, location: "shared", loaded at 10000000h - 1002A000h
Address: 7C921B09h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 0048991Fh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 01000000h, location: "foo_masstag", loaded at 00FC0000h - 01010000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C906000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
Play Count 1.9.2  (foo_playcount)
Playlist tools 0.5.6  (foo_utils)
Post-track silence 0.0.2  (foo_dsp_silence)
AMIP Wrapper 0.90  (foo_amipwrapper)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Database search 1.3.1 beta 11  (foo_dbsearch)
foosic music database 1.0 beta 4  (foo_sic)
freedb tagger v0.5.1  (foo_freedb2)
LyricsDB discussion
Reply #173
There's new beta: foo_lyricsdb_007_beta2.zip: fixes issue with crashes while tagging.
LyricsDB discussion
Reply #174
This is a great plugin! Thanks!
