Topic: Parallel Installations for Multizone Audio (Read 2590 times) previous topic - next topic
  • mikegray
Hi guys -
I'm running foobar2k under XP with two different sound cards for multizone audio. For a while I had parallel installations going - one for each card - and everything was fine. Then after a crash I had to reinstall, and now I can't seem to keep them separate anymore. That is, I've copied the installatoin to a new directory, but any settings changes I make in installation 1 (\foobar2000\foobar2000.exe) are saved to installation 2 (\foobar200office\foobar2000office.exe) as well.
Aaargh!
Whatever I'm doing wrong has to be pretty simple, but I just can't figure it out. I must have done something different before, but I can't remember what.
Can someone help me here?
Mike
  • foosion
  • Moderator
Disable user profile support. Just delete the user_profiles_enabled file in your foobar2000 installation directories.
http://foosion.foobar2000.org/ - my components for foobar2000
  • mikegray
[a href="index.php?act=findpost&pid=321114"][{POST_SNAPBACK}][/a]
Thanks - that did the trick. Should I have read that somewhre??
Best,
Mike
