Topic: Converting to OGG with EAC (ERROR!) (Read 4062 times) previous topic - next topic
'm having some problems encoding into Ogg with EAC.  I'm getting an error when it tries to convert the wav to ogg, supposedly from oggenc.exe...
I set it up normally, had it detect drive settings, etc, and just changed it to Ogg Q6...  I downloaded the vorbis-toolki 1.0.1 (and tried 1.1.1) from vorbis.org, extracted it, moved it to another directory, and pointed EAC to oggenc.exe ( and oggenc2.exe ).  When I tell it to extract to compressed, it extracts the wav, but then says:
The external compressor returned an error!
Options: -q 6 -N 1 -t "YMCA" -a "INFORMATION ETC"... -q 6 -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s -o %d -o "Long path\Ytmp60-!5.ogg" "Long path\Ytmp60-!5.wav"
File: LongPath\YMCA.wav
What am I doing wrong???
What is your arguments line in the setup? This looks weird as heck:
You have -q 6 there twice, you have an extra -a, -t, you have a couple of -o's, there's that weird "..." there...
What's the actual line in the config?
Program ... used for compression: E:\ogg\oggenc2.exe
Additional Command Line Options:  -q 6 -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s -o %d
Yeah, I thought it was wierd too... I just copied this from somebody's example ( on this forum I think)...
Do I have a wierd version of the encoder or something???
Ogg Vorbis:
3. Set file extension to .ogg
4. Locate 'oggenc.exe'
5. Use command line -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s
taken from case's site found HERE
any use to you? notice it doesn't specify output -o %d
Kristian
Ogg Vorbis:
Kristian
[a href="index.php?act=findpost&pid=315845"][{POST_SNAPBACK}][/a]
FIXED!  It works only when I delete all the parameters, I included what you just mentioned, and got the same error, but now it works
Why?  How can I change the parameters without adding copies of them (which is what looks like what was happening)  Notice it is an "Additional Parameters" field.
