Topic: EAC not so trustworthy after all (Read 3510 times) previous topic - next topic
  • Veej007
Hey guys,
I'm running EAC having followed Chris Myden's setup guide; In "drive options," accurate stream checked, caches audio checked, and c2 correction unchecked.  This should be secure, no?  I'm getting weird crackling distortions ripping a number of different CDs to both FLAC and LAME.
Where should I be looking for the problem?
  • Acid8000
Sometimes heavily clipped (loud) records are so bad they make crackling sounds. How do your CDs sound in a CD player?
Other things to consider:
Is there some sort of copy protection on the discs?
Are you using the correct drive read command?
Acid8000 aka. PhilDEE
  • Audionut
Caches audio, shoult be UNchecked.
  • ExUser
  • Read-only
[a href="index.php?act=findpost&pid=311746"][{POST_SNAPBACK}][/a]
Checking "Drive caches audio" should have no negative side-effects on any drive other than slower ripping. Unchecking it on a drive that does cache audio data can negatively affect quality, and was the reason for the option's existence in the first place.
