Topic: Split from 1.01j encoder vs 1.15u - controversy (Read 22731 times) previous topic - next topic
Guru, take serious consideration to being one hell of a lot less argumentative and confrontational - I was only trying to summarize in such a way that both parties can meet an argumentative compromise
Seed does need to take the critisism though.
What codec should I use? AAC? Ogg?
hi
OK, fine. But could you explain your summary. You said that my attitude wasn't creative enough. I repeat: I don't understand. I made a test, which was intended to be the first step to further investigation. What did I miss according to you?
P.S. It's not a cynical reply: I really don't understand what you tried to say previously.
You are probably missing some flowers and a little bit more of blue color. This would have been more creative...
I see. For the next test, what is better: writing the report in alexandrine or in haiku style?
Guru I didn't mean to imply that Seed was justified, just that he responded agressively when he interpreted your listening test as an attack on his "baby". At least that's my impression. He's totally wrong in doing so of course, and I hope your (highly enlightening) listening tests continue, since I read each and every one of them avidly.
I say many thanks to Guruboolez' continued efforts, great publishing work !
And subscribe the old answers of Roberto and Guru to the aggressive posts of Seed.
But I don't wanna heat the discussion up again, it is really time to cool down (yeah, maybe it is the weather, very hot days recently in germany and Europe). Of course it is difficult to to view his own work from a distance, but necessary in technical questions, as especially the work on the best lossy encoder of the world will never be finished... (regard the different profiles, bitrates, from "really transparency" to 99.999% population of critical ears at higher bitrates down to "transparency for 95% of the population", down to best compromises for low bitrates for portable devices, where bitrate counts.
So, we see here, that the work on an encoder is hard work, and needs to be apprecited a lot, so many thanks to all previous developers and the current dev.-team, especially Seed.
[a href="index.php?act=findpost&pid=307264"][{POST_SNAPBACK}][/a]
Blind alexandrine?
